Cannot for the life of me figure out!
Discussion in 'Gen 3 Prius Accessories and Modifications' started by mizzaxer, Jun 19, 2011.
  1. mizzaxer
    mizzaxer New Member
    28
    Northeast PA
    How to change my domelight? How do I remove the plastic cover without damaging it?! As goes with the rear and cargo light?? I cannot find a how-to? Anyone? please??
  2. JACoH
    JACoH Enjoying the mileage
    193
    40
    Oregon
    Well, I have the CD manual on how to do it, but can't figure out how to copy it to here, but it looks like there are 4 plastic clips at each corner that need to be pried carefully down, but not too far or forcefully, because there is a wire harness attached. Then the harness is unplugged to change bulbs or insulate or whatever you need to do. Reinstallation looks like just pushing back up into roof (!) Looks easy, but it is only pics and not real clear.
  3. Judgeless
    Judgeless Senior Member
    1,821
    255
    Cleveland, OH
    What page?
  4. JACoH
    193
    40
    Oregon
    If you have same CD, it is pp 6483-6485, basically says wrap a screwdriver and pry.
  5. taxachusetts
    taxachusetts Junior Member
    39
    Boston
    What CD is it?
  6. JACoH
    193
    40
    Oregon
    Says Toyota Service Manual, got it from ebay last year. No other info on it.
  7. Judgeless
    1,821
    255
    Cleveland, OH
    I could not find it in the owners manual. I also have the repair manual. Here is the section that you mentioned.
    http://mbu.com/prius/domerepair.pdf
  8. mainemanx
    mainemanx Member
    355
    40
    State O' Maine
    No suggestions to drill down thru the roof? Remove the headliner? Loosen the traction battery?
    Oh well, Judgeless has the solution... tell us how it went :)
    Edit: Judgeless, interesting URL you got there...
  9. Judgeless
    1,821
    255
    Cleveland, OH
    I created that domain in 1994 as Mail Boxes Unlimited. My goal was to offer free email with small ads at the bottom. My marketing skills were not as good as Hotmail. Microsoft bought Hotmail for 500 million. I still have mbu.com. I have been offered $20,000 for the domain. I declined. This is another one of my domains.
    www.happyhourcleveland.com
    We have fun getting out and checking out all the great restaurants and bars in Cleveland.
  10. windstrings
    windstrings Certified Prius Breeder
    6,278
    373
    Central Texas
    That pdf didn't help at all.. still feels like you have to rip the thing out to get it loose... can't believe its so ridiculously hard... I"d rather work on the engine.
  11. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    23
    Maine
    It is a finesse thing not a strength thing. If you are having to work hard, you haven't found the spots yet. They are admittedly hard to find. I struggled with it. Then I found the exact spot where you need to put a little tiny bit of pressure, popped right out. Patience is I think required. Good Luck.
  12. windstrings
    6,278
    373
    Central Texas
    I finally got it.. one side came out then I could pull that direction and it helped the other... once it comes out once its a little easier the second time.....
    Guess they didn't want it coming out in case you flipped your car, rolled down an embankment and tossed end on end for a while!.... lol!
    Anyway..... have you simply replaced the bulb or did you put the "bank" of led's inside?
    Once you get the cover off there is much more to get released..... amazing they made something so simple so hard!.... wow!
    Too many engineers I think!
