can't get it out of Park
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ArizonaPriusOwner, Feb 10, 2008.
  1. ArizonaPriusOwner
    ArizonaPriusOwner
    Expand Collapse
    Junior Member
    Chandler, Arizona
    Hi, I'm new here.
    All of a sudden my 2005 Prius is stuck in Park, and won't go into Drive, Reverse, or Neutral. It seems to turn on OK - the Ready light comes on, and no warning lights on the dash. But when I try to put it in Reverse or Drive (with foot on brake), it just gives 2 little beeps, and it stays on 'P'.
    I've tried using the manual key as well as the remote key in pocket method when pressing Power. I've tried with the foot parking brake on and not. I've tried pressing the brake all the way down. I've tried holding the power button down for a minute. I've tried pressing the P button before trying to shift into Drive.
    Any other suggestions?
  2. Rae Vynn
    Rae Vynn
    Expand Collapse
    Watch out, I have a degree in BS!
    6,021
    699
    Tumwater, WA USA
    Call a dealer, have it hauled in to a certified Toyota service center.
    That's my advice...
  3. patsparks
    patsparks
    Expand Collapse
    An Aussie perspective
    10,667
    547
    Adelaide South Australia
    I think you may have a failed brake light switch. Have someone check the brake lights are working.
  4. TonyPSchaefer
    TonyPSchaefer
    Expand Collapse
    Your Friendly Moderator
    14,554
    1,981
    48
    Far-North Chicagoland
    Yeah, that's an odd duck.
    Sorry but I think that's one for the pros.
    Keep us posted as to what was wrong.
  5. qbee42
    qbee42
    Expand Collapse
    My other car is a boat
    18,040
    2,981
    Northern Michigan
    My guess is also the brake light switch. Without it, the computer doesn't know you have your foot on the brake.
    Tom
  6. Slartibartfast
    Slartibartfast
    Expand Collapse
    Senior Fjord Architect
    61
    Twin Cities, MN
    Third that also. That polite little double beep is exactly what happens when you try to shift out of park without the brake. So it makes sense that the car thinks the brake pedal is not depressed.
  7. patsparks
    patsparks
    Expand Collapse
    10,667
    547
    Any news?
  8. TonyPSchaefer
    TonyPSchaefer
    Expand Collapse
    14,554
    1,981
    48
    It's still Sunday on this side of the world. Won't know anything until tomorrow at the earliest.
  9. Jack66
    Jack66
    Expand Collapse
    Kinda Jovial Member
    766
    Stafford, Virginia
    The Prius is such a high-end piece of electronics -- you wonder how long it takes for some of these technical glitches to surface and get solved...
  10. miscrms
    miscrms
    Expand Collapse
    Plug Envious Member
    2,060
    503
    Phoenix, AZ
    If it is the brake light switch, this same failure can happen on a lot of auto transmission cars. At least in US they are required to have an interlock on the transmission to keep from shifting out of Park unless your foot is on the brake. Most cars just use the brake light switch to sense this.
    Had the same thing happen on my land rover a few yeas back. Funny thing, on the rover the rear defrost and rear third brake light connectors are right next to each other and have the same connector. If your brake swicth goes out, you can swap the connectors and use the rear defrost switch to turn the brake lights on and shift out of park :D
    rob
  11. richard schumacher
    richard schumacher
    Expand Collapse
    shortbus driver
    7,652
    899
    United States
    Try pressing real hard on the brake pedal. The switch can fail partially.
  12. ArizonaPriusOwner
    ArizonaPriusOwner
    Expand Collapse
    Junior Member
    Chandler, Arizona
    Still no luck with this. (fortunately it's my carpool buddy's turn to drive this week)
    The brake lights do actually do go on when I press the brake. I've tried mashing the pedal as far down as it will go. And I tried putting the rear defroster on.
    I guess I'll have to have it towed to the dealer.
    Thanks for all your thoughts on this. I'll let you know what the dealer says fixed it.
  13. patsparks
    patsparks
    Expand Collapse
    10,667
    547
    Good luck, thanks for keeping us in the loop.
  14. RobH
    RobH
    Expand Collapse
    Senior Member
    1,767
    369
    24
    Sunnyvale, California
    Attached is the diagram of the stop light switch. Note that there are actually two switches ganged together. If only one is defective, then perhaps the brake light could be OK, but the shift control could still be disabled.
    Or maybe one of the connectors is loose.
  15. ArizonaPriusOwner
    ArizonaPriusOwner
    Expand Collapse
    Junior Member
    Chandler, Arizona
    Thanks. Where in the car would that be located? I'm sorry if this is a dumb question.
  16. RobH
    RobH
    Expand Collapse
    Senior Member
    1,767
    369
    24
    It's at the top of the brake pedal arm. You'll have to remove the lower dash panel to get to it.
    Hope you have small hands. Or maybe you could enlist an 8 year old. Access is really tight, at least for my 10 thumbs...
    You could unplug the switch, and install a wire jumper across the black and blue wire connections. That should be electrically the same as having pressed the brake. If that corrects the situation, then the problem is the switch.
  17. ArizonaPriusOwner
    ArizonaPriusOwner
    Expand Collapse
    Junior Member
    Chandler, Arizona
    That did it! Just pulling on the dash cover and getting my fingers under there was enough to get the wire to touch, and I got it in gear long enough to get the car in the garage. Now I should be able to fix it, now that I know where the problem is. I think a connector on that brakeswitch came loose.
    Thanks everyone.
  18. patsparks
    patsparks
    Expand Collapse
    10,667
    547
    You just gotta love teamwork!!
    Well done, a good result.
  19. Winston
    Winston
    Expand Collapse
    Member
    614
    SF Bay Area, California
    Cool! One less trip to the dealer. Plus, they probably would have charged you to replace the switch anyway.
