Car Cabin Air Filter
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by shrktank, Mar 8, 2012.
  1. shrktank
    shrktank New Member
    56
    Imperial,Mo
    Just purchased a 2012 Prius a few weeks ago. Can anyone tell me if they preinstall a cabin air filter in the new cars?
  2. spiderman
    spiderman wretched
    7,473
    1,450
    Alaska
    Of course. Like the previous years, it is likely a charcoal filed filter. I found that out when I tried to wash it. :)
  3. smokiejoe
    smokiejoe Member
    174
    26
    PA
    Yes, in vehicle. They recommend it should be checked or changed at 25-30K miles. Very easy to change. Located behind lower Glove Compartment.
  4. The Critic
    The Critic Resident Critic
    2,233
    464
    Walnut Creek, CA
    The filter is not charcoal.
  5. Keiichi
    Keiichi Active Member
    808
    75
    Goleta
    If you have seen pictures of Spiderman's car... It's charcoal...
  6. The Critic
    2,233
    464
    Walnut Creek, CA
    Weird, I do not remember my original one being charcoal.
    I have a few replacement ones from the dealer and I do not remember them being charcoal either, but I will check.
  7. jdenenberg
    jdenenberg EE Professor
    2,832
    828
    Trumbull, CT
    Replacement filter media is available with and without charcoal. OE Toyota filters do not have charcoal (at least for my 2004 Gen2). Third party ones cost less but those with charcoal tend to cost a bit more.
    JeffD
  8. spiderman
    spiderman wretched
    7,473
    1,450
    Alaska
    My OE cabin filter is charcoal and I bought a replacement recently to replace it, thank you.
  9. jdenenberg
    2,832
    828
    Trumbull, CT
    So there was a change from Gen2 to Gen3 in the filter media.
    JeffD
  10. jdcollins5
    jdcollins5 Senior Member
    4,909
    1,066
    Wilmington, NC
    My OEM cabin filter was not charcoal. I later replaced it with a Fram charcoal filter. The replacement Toyota filter at my dealership was not charcoal.
  11. Keiichi
    808
    75
    Goleta
    @The Critic:
    I was jokingly referring the time Spiderman posted a picture of how mudflaps do NOTHING for the car... And when you look at his car, it looks like someone threw mud all over it. So I jokingly refer to Spiderman's cabin filter is probably caked as well.
  12. spiderman
    spiderman wretched
    7,473
    1,450
    Alaska
    ^ no need to explain yourself... it worked out fine. :)
  13. The Critic
    2,233
    464
    Walnut Creek, CA
    You were right.
    I checked my invoice and apparently my dealer decided to throw a non-charcoal filter in there at the complimentary 15k service.
    The filter they installed looks completely different than the one which came in the car originally.
  14. Rebound
    Rebound Senior Member
    2,311
    752
    SF Bay Area, California
    I think the interval is more like every 5K or 10K miles, isn't it? At 30K miles, that filter will be black.
  15. The Critic
    2,233
    464
    Walnut Creek, CA
    Toyota only requires it every 30k.
  16. Rebound
    2,311
    752
    Yer right, you clean it at 15 and replace at 30. I just replaced mine at 15 and 30.
    I let one go in my Honda Odyssey, maybe 5 years, and it was totally disgusting. Sooty and black. Yech.
  17. hyo silver
    hyo silver Awaaaaay
    15,204
    1,441
    off into the sunset
    So, you're saying you used to have a charcoal filter.....:rolleyes:
  18. spiderman
    spiderman wretched
    7,473
    1,450
    Alaska
    Yeah, and I am still using it. I read on here where someone washed theirs... boy was my water dirty! :D
  19. jjPrius
    jjPrius Junior Member
    68
    Southern California
    I just replaced my 2011 Cabin Filter with the charcoal replacement at 30k miles, which is part # 87139-YZZ10. The standard replacement is part # 87139-YZZ08 (Electrostatic filter).
    For replacements under warranty, dealers are instructed to use 87139-07010 (High Efficiency Pollen). See the second section of the first attachment below for part number details (first section is for the engine air filter application chart). I think that this was the part number for the factory filter that was replaced, but I am not sure (I can look tonight). The factory filter definitely had many more pleats than the new charcoal replacement (roughly twice as many pleats).
    The second attachment details Toyota's position on Cabin Filter replacement.
    Thanks,
    Jeff
    http://www.toyota.com/toyota-owners-online-theme/pdf/ReplacingAirFilters2011-LowRes.pdf
    http://www.toyotapartsandservice.com/pub/pdf/Common/ASM_Cabin_Air_Filter_Application_Chart.pdf
  20. justana
    justana Junior Member
    64
    What's the benefit of charcoal compare regular one? May i know where did you buy?
