1. Offline
    pdxrose New Member
    Jul 5, 2009
    Message Count:
    174
    23
    Vancouver, WA
    Your Vehicle Year:
    I opened another case yesterday as the Toyota service rep said there was still NO TSB. Today the person assigned the case said there has been since the beginning of this month and gave it to me3. When I had asked a local dealer about a week ago, they did not have it yet.
    Danny had mentioned that the fix was out in another thread but I did not see a TSB number (or anywhere else). As several people have asked what it is, to educate their dealer, here it is :D
    PS very similar number to new net part number
    6 people like this.
  2. Online
    HTMLSpinnr Gen III Forums Moderator
    Dec 8, 2003
    Message Count:
    4,975
    717
    Surprise, AZ (Phoenix)
    Your Vehicle Year:
    I'm contemplating whether to get mine replaced under the TSB, even though the dealer did do an "initial fix" of drilling through additional panels. I'd probably be left w/ plugs. :-(
  3. Offline
    SlowTurd I LIKE PRIUS'S
    Aug 22, 2009
    Message Count:
    1,067
    274
    nj
    Your Vehicle Year:
    this is how mine came from the factory
    [IMG]
    1 people like this.
  4. Offline
    maomao New Member
    Aug 7, 2009
    Message Count:
    96
    DC
    Thanks. But did your net also comes with hooks to attach to the rings on cargo floor?
  5. Offline
    PearlieGirl New Member
    Jul 13, 2009
    Message Count:
    53
    Syracuse NY
    Your Vehicle Year:
    Does this fix mean that you wouldn't be able to secure the pull-out cargo cover anymore? It looks like the new arrangement would be in the way...
  6. Offline
    rrolff Prius Surgeon
    Aug 19, 2009
    Message Count:
    1,602
    219
    So Cal
    Your Vehicle Year:
    The cover fits fine - no interference.....
    1 people like this.
  7. Offline
    a priori Canonus Curiosus
    Aug 14, 2007
    Message Count:
    2,668
    313
    Chicagoland (West)
    Your Vehicle Year:
    I think you're right, Rick. I have the same concern.
  8. Offline
    • Admin/Founder
    Danny Admin/Founder
    Nov 24, 2003
    Message Count:
    6,064
    821
    Charlotte, NC
    Your Vehicle Year:
    I would personally fight to have the dealership replace the panels they drilled into.
  9. Offline
    hot_wasabi New Member
    Nov 15, 2009
    Message Count:
    Your Vehicle Year:
    Mine came this same way and was purchased in mid-October. The cargo net that was included with the car has clips that attach to the two D-rings on the floor directly below. It doesn't interfere with the cargo cover functionality at all.
  10. Offline
    32kcolors New Member
    Jul 14, 2009
    Message Count:
    4,515
    536
    Redondo Beach, CA
    Your Vehicle Year:
    So some of you actually had the dealer do a make-shift fix and allowed them to drill holes, before Toyota came out with a TSB fix? :eek:
  11. Offline
    Mar 8, 2008
    Message Count:
    9,152
    1,793
    Your Vehicle Year:
    T-SB-0347-09 Cargo Net Trim Panel Gap
    Here's the TSB. Plastic plugs are used to fill the original holes.
  12. Offline
    thbjr New Member
    Nov 15, 2009
    Message Count:
    326
    61
    Phoenix
    Your Vehicle Year:
    Can I, should I, have my dealership do this repair, even though I don't currently have a cargo net?
    Is it something that would need to be addressed before the warranty expires?
    Well, reading the TSB answered the second question. It has to be done while unde warranty.
  13. Offline
    Joe166 New Member
    Dec 19, 2009
    Message Count:
    721
    95
    South Florida
    Your Vehicle Year:
    If you don't have the cargo net, how could the panel have been damaged and why would you need holes patched? Just wondering since I don't have a cargo net either and don't want one, and so I am not exactly sure what the problem is if we haven't installed a cargo net.
  14. Offline
    thbjr New Member
    Nov 15, 2009
    Message Count:
    326
    61
    Phoenix
    Your Vehicle Year:
    My point was that if I choose to add a cargo net 3 days after my warranty expires..., or trade the car in and the next owner is a cargo net nut, I thought it would be wise on my part to plan ahead. While certainly not every Prius owner uses a cargo net, a good percent do and of that percent, from what I read here, it seems to me that almost all of them are having this panel seperation issue.
  15. Offline
    ggood ggood
    Jan 17, 2004
    Message Count:
    1,917
    276
    Houston, Texas
    Your Vehicle Year:
    with the new kit, there won't be any repair needed. they'll simply install the net correctly, without any holes.
  16. Offline
    thbjr New Member
    Nov 15, 2009
    Message Count:
    326
    61
    Phoenix
    Your Vehicle Year:
    OK, my mis-understanding. I thought one just purchased the cargo net, like the floor mats, and then stretched it between the pre-installed factory anchor points, pulling the panels askew. I believe my mistake is in that those anchor points are NOT pre-installed. Is that correct?
  17. Offline
    Mar 8, 2008
    Message Count:
    9,152
    1,793
    Your Vehicle Year:
    Yes. Two anchor points need to be installed when the cargo net is added.
  18. Offline
    emPG New Member
    Oct 24, 2009
    Message Count:
    Virginia
    Your Vehicle Year:
    I purchased my Prius in late September (unsure of manufacture date). It came with the cargo net installed with the new fix. No holes to plug. It works great and no problems with it whatsoever.
  19. Offline
    Texas911 New Member
    Feb 24, 2007
    Message Count:
    401
    16
    Houston, Texas USA
    Your Vehicle Year:
    Won't the plastic around the hook eventually get scratched and worn? I think that's why the original flawed placement had it away from the plastic? Mine came with a cargo net, but only for the floor. Would like to get the upright one but maybe will wait.
  20. Offline
    Terrell New Member
    Feb 10, 2010
    Message Count:
    26
    Wisconsin
    Your Vehicle Year:
    Re: T-SB-0347-09 Cargo Net Trim Panel Gap
    Thanks! When I ordered my Prius, I ordered the cargo net. When I took delivery, they told me to not use the cargo net until they found a fix, because the net could pull out the side panels. But they never contacted me to let me know about the fix. So I'm glad I found it here!
    I called my dealer, they know nothing about the fix. They checked with the shop, and the shop knew nothing about the fix. So I gave them the TSB number, which they Googled, and they found this Forum!
    I'm surprised they didn't have it from Toyota. I printed out the TSB and will give it to them. My guess is that the fix was applied to new cars being built, so not too many were built with the hooks in the wrong place.
    Thanks for this Forum!
Share This Page
