1. Offline
    splais New Member
    Start a Conversation
    Nov 17, 2011
    16
    Yuma, AZ
    Your Vehicle Year:
    Does anyone know someone that makes an armrest cover for the center console lid. My is light beige and I can tell it is starting to show some wear and dirt. thanks.
  2. Offline
    2 fas 4 u Active Member
    Oct 25, 2010
    201
    107
    florida
    Your Vehicle Year:
    Go to a local shoe maker like i did, see if he has any extra pieces of leather that will match your color. I paid 10.00 for the piece and he charged me 10.00 to put it on total cost $20
  3. Offline
    splais New Member
    Nov 17, 2011
    16
    Yuma, AZ
    Your Vehicle Year:
    nice tip, thanks.
  4. Offline
    TeacherMan Junior Member
    Sep 2, 2009
    31
    Gahanna, Ohio
    Your Vehicle Year:
    Pictures? :)
    Tom
  5. Offline
    JACoH Enjoying the mileage
    Oct 11, 2009
    147
    Oregon
    Your Vehicle Year:
    I found one on ebay for about $30.00 in leather, fits great, great quality, and I think they have your color, too, mine is grey. I forgot his name but search for Prius cover or google it. He has been selling these for a long time.
  6. Offline
    yyyiiikes Junior Member
    May 11, 2007
    84
    Austin, TX
    Your Vehicle Year:
    Is this the one you have? (from seller lindbergh61)
    2010 - 2012 Toyota Prius Leather Center Console Cover | eBay
  7. Offline
    Azimuth Prius Spotter
    Jun 8, 2009
    123
    27
    Austin, (adjacent to Texas)
    Your Vehicle Year:
  8. Offline
    splais New Member
    Nov 17, 2011
    16
    Yuma, AZ
    Your Vehicle Year:
    Azimuth, that is gorgeous! Could you explain a little how or who you had do that. An incredible add-on to the prius.
  9. Offline
    Jun 8, 2009
    123
    27
    Your Vehicle Year:
    Here are some quick notes: if more detail/guidance is needed please ask.
    Have some Naphtha on hand. It is great for cleaning off adhesive without damaging the pleather.
    I used Heavy Duty Welder Contact Adhesive.
    I used the instructions provided by Dan Bo in this thread to remove the arm rest so Thanks go to him.
    Once I had the top piece removed, I carefully peeled the Microfiber finish off the arm rest. I left the padding in place.
    I then used the leftover pleather that I had purchased at Joann Fabrics from my door mod.
    I cut the pleather to as close a fit as possible using the old MF material I had peeled off as a stencil.
    start on one side in the center and glue down the two middle tabs only.
    once they have bonded to the plastic you can stretch the material to the opposite side.
    Play around with your corners. The important thing is to spread the "pleats" as much as possible, you can stretch the material quite effectively to hide all the pleats under the armrest where you won't see them. once you have a grasp of how you will need to pull the material effectively, continue to use the contact adhesive and pull the material tight towards the center tabs you already glued. you should be able to hold the tabs in place a few minutes while the adhesive dries. If you
    find that it takes too long to dry, you are using too much adhesive.
    -Sorry for hijacking the thread.
    1 people like this.
  10. Offline
    mgb4tim Noob
    Jul 8, 2009
    1,068
    81
    Pittsburgh, PA
    Your Vehicle Year:
    did you add any padding?
  11. Offline
    Jun 8, 2009
    123
    27
    Your Vehicle Year:
    I did not. but the material I used was very thick.
  12. Offline
    May 11, 2007
    84
    Austin, TX
    Your Vehicle Year:
    I agree... that looks fantastic!
  13. Offline
    Oct 11, 2009
    147
    Oregon
    Your Vehicle Year:
    Yep, that's the one, and I just ordered one for my new v!
Share This Page
