center console cover
Discussion in 'Prius v Main Forum' started by schinia, Apr 29, 2012.
  1. schinia
    schinia Member
    162
    24
    cape carteret,nc
    i finally discovered how to remove the cover from the armrest cover, i think i said that right. i'm going to bring it to a auto upholstery shop to see what he can do to make this thing a lot better.
  2. Chazz8
    Chazz8 Gadget Lover
    645
    146
    40
    Central New York
    Do share please. With pictures if you got em.
  3. TruSound
    TruSound Member
    246
    30
    The 818
    Hurry please...I can't take another day, and either can my right elbow.
  4. junkman
    junkman New Member
    south florida
    Hi Go to priusaccessory.com and check out the console cover.
  5. TruSound
    TruSound Member
    246
    30
    The 818
    Not a fan of that one junk...wanna see a few more options, wearing my old hockey elbow pad for now.
  6. schinia
    schinia Member
    162
    24
    cape carteret,nc
    i found a upholsterer couldn't match the tan soft tex, so i told him to use black (a type of vinyl that is used on marine upholstery. but one thing is important, the material should be about .030 to .040 thousands thick. so that the cover can be snapped back on the piece that snaps on the arm rest cover. cause the original cloth material is thin. i also had him add an additional 1/2 inch of foam on top of the foam underneath the cloth, so it will be 3/4 inch padding all together. i will get back in a couple days when i get it back.
  7. TruSound
    TruSound Member
    246
    30
    The 818
    Looking forward to seeing the results, and of course we'll need the removal procedure...nice work !
  8. schinia
    schinia Member
    162
    24
    cape carteret,nc
    i got my cover back from the upholsterer, and it came out great. i'm going to have to figure out how to download the pictures. also i think i have to put this procedure on the prius section Accessories and Modifications, right ? taking it apart took longer than the (less than 1 minute and 30 seconds) to put it back together.
  9. CLUBGUY
    CLUBGUY Member
    253
    31
    Cincinnati
    Would be nice to know HOW to remove the cover..???
    Thanks...
  10. slazerow
    slazerow New Member
    23
    Il
    As I begin to remove the cover, do I pry upward until I hear a snap? I started prying but didn't want to put too much pressure on it. A picture of the underside (or the removal process) would be great. Thanks.
  11. schinia
    schinia Member
    162
    24
    cape carteret,nc
    i moved the thread to , modifications, and accessories. i described as best i could (under console cover) i tried to download the pictures, but came back with " invalid source" email administrator. which i did to no avail. if i had your email address i could email you the pictures. but there isn't any way i can put arrows on the pictures. i will work with you any way i can.
  12. Wolfchen
    Wolfchen New Member
  13. Wolfchen
    Wolfchen New Member
  14. schinia
    schinia Member
    162
    24
    cape carteret,nc
    go to modifications and accessories for prius v, look under console cover.
  15. soup kitchen
    soup kitchen New Member
    30
    san diego ca
    I do not have a problem with the center console cover. Maybe I'm cheap but it is fine.
