Center Rear Seatbelt
Discussion in 'Gen 2 Prius Main Forum' started by Karen47, May 27, 2014.
  1. Karen47
    Karen47 Junior Member
    New York
    Where do you fasten it?
  2. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    This sounds like you have pushed the buckle down between the seat cushions
  3. Scallywag
    Scallywag Member
    107
    22
    Columbus, OH
    The buckle should be immediately next to one of the other rear seat belt buckles. I can't for the life of me recall which side, but certainly opposite where it starts (I don't sit back there often).
    I second xpcman, it sounds like the buckle got pushed down between the seat cushion and the seat back.
  4. R-P
    R-P Active Member
    804
    288
    Netherlands
    The middle one has a longer strap to it, so it is easier to loose below the seat. (Strap as in the thing that sits between the mountingbolt and the buckle. I think it is a piece of steel cable for the outer ones and a piece of folded seatbelt-like-material for the middle one) It sits on the drivers side on LHD's.
