Charger plug is very difficult to push in
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Scott Hamilton, Jul 6, 2015.
  1. Scott Hamilton
    Scott Hamilton New Member
    Vermont
    We bought our 2012 Plug-in used. At first the plug was fine, but it is getting progressively harder to plug in. Now, I have to lean on it pretty hard. Any one else experience this or know a solution (other than the dealer which is an hour drive away)?
  2. gallde
    gallde Active Member
    238
    130
    Tarrytown, NY
  3. Chazz8
    Chazz8 Gadget Lover
    744
    234
    61
    Central New York
  4. mrbigh
    3,686
    699
    Long Island, NY
    the orange "O" ring can be removed and the problem is solved.....
  5. hill
    8,068
    Mine is green
    but yea, the dislodged nozzle seal issue has come up several time on PC. Usually it's just not seated properly. Pull it ... then lube it with something non oily (like silicon spray) substance, and it can be re-seated pretty easily. That way you still keep your nozzle water tight if it's raining.
    #5 hill, Jul 7, 2015
  6. bisco
    48,947
    k-y
    F8L, AzWxGuy and rogerv like this.
  7. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
  8. AzWxGuy
    AzWxGuy Weather Guy
    968
    490
    Tucson, AZ
    2021 Prius
    Don't know nuthin 'bout PIP, but any electrical friction-fit plugs and sockets can benefit from a good cleaning and careful application of some dielectric grease. I use the little squeeze packets of spark plug boot grease. Great stuff.
  9. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    Thanks for the tip! My GF's new Volt has a similar problem whereas mine has very little resistance. I'll try the KY. ;)
  10. xliderider
    xliderider Senior Member
    7,848
    3,102
    Honolulu, HI
    Good ol Kentucky jelly. :D
    #10 xliderider, Jul 17, 2015
  11. rxlawdude
    rxlawdude Active Member
    701
    219
    So Calif
    2015 Tesla Model S
    What about Kentucky? (Pharmacist's humor about KY go far beyond appropriateness for this forum.)
  12. hill
    8,068
    The thing is - KY is water soluble - so I hear ;) and that's why I mentioned / recommended silicone grease. BTW . . . . that said, I suppose any lube is better than none. Now don't nobody go ape over that philosophy, either.
    :rolleyes:
  13. xliderider
    7,848
    3,102
    Honolulu, HI
    Water based KY and silicone grease should be safe for the material the O ring is made of. Vaseline and regular grease, or any other petroleum derived product, on the other hand, might swell or break down the O ring.
  14. angelahortega
    angelahortega Junior Member
    26
    Ukiah
    I had to take mine back to the dealer because the charger handle piece was getting stuck they replaced the whole charger. I didn't have an issue plugging in elsewhere
  15. samsdad
    samsdad Junior Member
    40
    Long Beach, CA
    I have same problem. There's nothing loose, it's just near impossible now to plug-in. What about spraying the connector end with WD 40?
  16. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,317
    Central Virginia
    You mean like is suggested in post 2 in this thread?
    Charger plug is very difficult to push in | PriusChat
  17. hill
    8,068
    You mean 2 years ago?
    Anywho - 9 out of 10 times, one should simply ckeck to see if the seal/plastic gasket is out of its seat. Or if you're evse is indoors, & the seal continues to get messed up, just take it out like many have done here, for years ... even before this thread started .
    Prodigyplace likes this.
  18. jerrymildred
    jerrymildred Senior Member
    11,491
    14,100
    Tampa, FL
    If it's the seal (which it usually us), remove it. 2013 and newer don't have a seal and do fine in the rain. Submerge it and you'll have bigger concerns. :D
  19. bisco
    48,947
    anyone seen the o/p lately?
    Raytheeagle likes this.
  20. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,476
    Bay Area, California
    2019 Prius Prime
    No longer figure skating I gather;).
    But that might be a different one:cautious:.
    bisco and Prodigyplace like this.
