charging prius battery pack?
Discussion in 'Gen 2 Prius Technical Discussion' started by omega II, Aug 1, 2008.
  1. mrbigh
    3,686
    699
    Long Island, NY
    So,what ever happened to the HV charger...?
  2. wester
    wester New Member
    Europe
    Ok lets imagine the situation that sombody has a problem with the battery and is buyning used one form wrecked car.
    Than he realize that battery that he bouth is empty. What to do?
  3. bwilson4web
    15,400
    • remove the modules
    • get a smart, battery charger (see RC hobby units)
    • cycle charge/discharge and read out each module capacity (clamp sides of modules)
    • re-use the modules with closest capacity to rebuild pack
  4. wester
    wester New Member
    Europe
    Thanks for advice.
    Can you please link an exaple of this kind of charger? Or just give some information about what requirements he should meet.
  5. bwilson4web
    15,400
    The technology changes and the first one I read about was in Europe. The characteristics:
    • automatic discharge and charge with readout or a record of Ahr
    • handle six, NiMH cells at one time (aka., a module)
    • detects charge voltage drop of NiMH cells to limit charge
    • backup, temperature rise detection charge override
    Expect to spend at least $100 (US). The one I use is an MRC 989 but there are others.
    wester likes this.
  6. Dxta
    Dxta Senior Member
    1,932
    766
    Lagos
    Ca
    Can a clamp meter be used to measure such a capacity (Ah) of the modules?
  7. edthefox5
    edthefox5 Senior Member
    10,096
    4,795
    Clearwater, Florida
    No it's D.C. You have to get an ammeter in series to measure D.C. Current.
  8. Dxta
    Dxta Senior Member
    1,932
    766
    Lagos
    Are you saying I could use an ammeter to actually know the current capacity of the modules if I'm charging them?
  9. Dxta
    Dxta Senior Member
    1,932
    766
    Lagos
    What I meant was can I use that same meter in series to measure the current capacity of the modules?
