1. Offline
    gigabyte Junior Member
    Start a Conversation
    May 15, 2010
    26
    oakland
    Your Vehicle Year:
    thought id share. found a short antenna that still has great fm / am reception. i got it from the dodge dealership and it was only 4 dollars. its about half the size of the stock antenna. part no. is 5064253AB
    4 people like this.
  2. Offline
    BAllanJ New Member
    Dec 9, 2008
    660
    67
    Kingston Ontario
    Your Vehicle Year:
    Same screw thread and everything? Good find. Thanks!
  3. Offline
    macmaster05 Senor Member
    Sep 27, 2009
    3,895
    555
    Your Vehicle Year:
    Very subtle. I like it. :)
  4. Offline
    roverguy78 Elite Lurking Member
    May 9, 2006
    114
    Your Vehicle Year:
    Good info! You can also use a 3rd gen Prius antenna, which is considerably shorter, and not expensive (but not $4!).
  5. Offline
    edgrzy New Member
    Feb 24, 2004
    Wallingford, Pa.
    I never had a problem with FM , only AM . Toyota replaced 3 radio's under warranty for me. The AM would come in clear for 3-4 months and then I would get static. They stated there was nothing they could do about it.
  6. Offline
    par_struggle New Member
    Feb 27, 2011
    ok.us
    Your Vehicle Year:
    I'll step in and second this. The Chysler part really does fit, and gives me slightly improved reception over the stock 2009 whippy antenna. It also looks about a billion times better. Really hard to beat the look at the $4 price point. My local Chrysler dealer took two days to get the part, but there was no shipping charge. As it's a block off the highway on my way home, it was an easy pick. Changed it in about ten seconds right in their lot. I'm going to take it back off and put a small dab of adhesive caulk around the bottom edge, but otherwise I'm digging it as is. Less than half the length of the original mast.
    2 people like this.
  7. Offline
    JeanneFlorida New Member
    Aug 1, 2011
    Your Vehicle Year:
    Thank you. It works great
  8. Offline
    Daves09prius Member
    Nov 20, 2010
    412
    66
    Gettysburg, PA
    Your Vehicle Year:
    Yes the post is a few months old... but I'm gonna keep it alive.
    I just ordered my Chrysler $4 antenna, and should be delivered tomorrow. I can't wait to get rid of the long whip OEM factory antenna, I've been looking for a shorty antenna that didn't loose radio reception for over 6 months now... I'm so glad that I ran across this post!
    If there is anyone out there looking for a inexpensive good looking short antenna, this is probably one of your better choices.
  9. Offline
    caymandiver75 New Member
    Jan 5, 2011
    37
    Northern VA
    Your Vehicle Year:
    Nice! Do you by chance have a part number for the Chrysler shorty antenna?
  10. Offline
    Daves09prius Member
    Nov 20, 2010
    412
    66
    Gettysburg, PA
    Your Vehicle Year:
  11. Offline
    Agape Member
    Nov 1, 2010
    190
    Ireland/Eire
    Your Vehicle Year:
    hi, here is the short antenna made of aluminum which I got from ebay for less than Euro6 :
    Product: Aluminum
    Color: Black
    Dimensions: High 55mm (5,5cm)
    Width (at the bottom): 14mm (1.4cm) narrowed to 7mm (0,7cm) at the top.
    link to the auction on ebay:
    http://www.ebay.co.uk/itm/200602197523?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
    Item number: 200602197523MINI CAR AERIAL ANTENNA BLACK ALUMINIUM 55mm STUBBY
    note: I had to cut the thread about 3mm-4mm off the length ( I should cut 1mm more really to eliminate gap, see picture)
  12. Offline
    MarvinHC New Member
    Jun 21, 2011
    43
    Europe
    Your Vehicle Year:
    I like that one! How is the radio reception after you have fitted it?
  13. Offline
    dhanson865 Expert and Devil's advocate
    May 24, 2011
    477
    62
    TN, USA
    Your Vehicle Year:
    Well, I made the jump today. I think it makes my 2005 Prius look nicer.
    The old unicorn antenna worked fine but the rubber at the bottom was cracking and was pitted. I might take a picture and add it here some time.
    Oh, and yep it was $4 plus tax. Got out of there for $4.37
  14. Offline
    Agape Member
    Nov 1, 2010
    190
    Ireland/Eire
    Your Vehicle Year:
    Hi MarvinHC, I didn't do any proper tests, just ordinary usage, work's fine for me.
    I don't know if this is a real antenna or just written advert on the box (antenna). It looks like it's just a machined piece of aluminum with thread in it, unless there is sort of built in antenna (would question that for this cost). Looks great, isn't it?.
    1 people like this.
  15. Offline
    MarvinHC New Member
    Jun 21, 2011
    43
    Europe
    Your Vehicle Year:
    Cheers, I will give it a try, not much lost anyway for a couple of quid.
    And I agree, it looks good.
    Will let you know how it works over here on the continent.
  16. Offline
    Scotty Danger Junior Member
    Oct 1, 2010
    75
    Scottsdale
    Your Vehicle Year:
    Great suggestion; I'm going to buy one this weekend. I was looking at a shark fin, but $4 is much better than $100!
  17. Offline
    malibucarl Member
    Apr 26, 2005
    237
    Malibu, Ca
    Your Vehicle Year:
    Just to update. I purchased one and it's great--only 4 bucks.
  18. Offline
    Stormz New Member
    Aug 16, 2011
    75
    Perth, Australia
    Your Vehicle Year:
    So what diameter (in mm) is the Prius thread?
  19. Offline
    May 24, 2011
    477
    62
    TN, USA
    Your Vehicle Year:
    The antenna is the male and the car has the female.
    The male is about 5 marks on my tape measure (10ft tape). I'm not good at measuring mm so maybe it's 5mm or 4.75 mm? 3/16" is about 4.75mm so maybe that is it?
  20. Offline
    sfv41901 Blizzard Brigade #164
    May 5, 2010
    2,279
    632
    Palmdale, Ca
    Your Vehicle Year:
    Thx for the info. I'm gonna have to get 1 now.
Share This Page
