1. Offline
    prius4ed New Member
    Start a Conversation
    May 13, 2008
    104
    Irvine, CA
    Your Vehicle Year:
    My check engine light comes on and then goes out occasionally. I bought a scanner at Walmart for $100 and connected it to the DLC. It reads P2238 and P3000 codes. Any help on what to check? I think P2238 means it's running lean. I'm hoping it's simple. Thanks in advance.
  2. Offline
    seilerts Battery Curmudgeon
    Mar 7, 2010
    3,296
    1,414
    Santa Fe, NM
    Your Vehicle Year:
    P2238 is the upstream o2 sensor (A/F sensor). Maybe it is a wiring problem due to the accident or reconstruction? If you have to remove this sensor, please post the socket that you used. OTC makes one specifically for select Toyotas for $75. I had to grind the outside of a cheapie o2 socket to get it to fit. See http://priuschat.com/forums/gen-ii-...ting/89967-oxygen-sensor-collar-around-3.html
    P3000 is a general HV battery fault. How long was the car sitting before you got it running again? Have you had any problems with the car losing power when it codes?
  3. Offline
    prius4ed New Member
    May 13, 2008
    104
    Irvine, CA
    Your Vehicle Year:
    I would guess the wiring is ok, b/c after I fixed everything I drove the car daily for about a month without any check engine light. It only recently started coming on, and later it would go out, etc. I will check the wiring again. There is a procedure for checking the A/F sensor, isn't there? Checking the ohms on the leads I think. Where is the A/F sensor located and it's connector? I'm guessing on the exhaust manifold, the most upstream sensor on it, and accessed from under the car?
  4. Offline
    prius4ed New Member
    May 13, 2008
    104
    Irvine, CA
    Your Vehicle Year:
    how to test the A/F sensor? Can it be repaired?
    Also, if the A/F sensor is bad, can it be cleaned somehow (heat with propane torch, etc) to get it working again? I'm guessing not, since it's heated by the exhaust when it's installed and in use.
  5. Offline
    Mar 7, 2010
    3,296
    1,414
    Santa Fe, NM
    Your Vehicle Year:
    It's all underneath. Take a look at picture below for the A/F sensor location (see O2 socket) and connection. There's not a whole lot to troubleshoot here. You can check the resistance at the sensor to see if there is a problem with the heating element, should be 2-3 ohms. I think you need a bidirectional scan tool to adjust injector volume and see if the sensor output changes accordingly. If it is not the sensor, then it is either wiring harness/connectors or ECM.
    [IMG]
  6. Offline
    prius4ed New Member
    May 13, 2008
    104
    Irvine, CA
    Your Vehicle Year:
    Thanks for the reply and photo of the A/F ratio sensor. In the photo, are we looking up from under the car? How can we determine the sensor is faulty, besides the 2-3 ohm connector check (which leads, please?)? Is there a way to clean the sensor? Mine is acting bad only sometimes; the CEL goes on one day and the next day it's out.
Share This Page
