Check Hybrid System - pull over !
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by fortytwok, Jul 9, 2014.
  1. fortytwok
    fortytwok Active Member
    467
    139
    Hopkinton MA
    2013 Prius Plug-in
    Sitting at the dealership right now waiting for the tech's analysis...
    Came on after I used my key to activate the AC - for the first time I should add.
    Roadside assistance said it was fine to drive although the warning and check engine lights remained.
    2 hrs later both messages were gone but they said the computer could let us know what happened.
    anyone else with this ? I was parked, not driving when it happened - 90 degrees
  2. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Were you in Park or Neutral?
  3. mrstop
    mrstop PWR Mode
    742
    329
    109
    Cincinnati, OH
    Do/did you have a OBD adapter plugged? I found that it can sometimes cause the car to throw errors. I removed it and the car reset itself.
  4. fortytwok
    467
    139
    Hopkinton MA
    2013 Prius Plug-in
    nope
    Toyota just finished up - says the multiple codes were confusing and they think it possible that there was radio type interference prompting this given I was at the train station. No inverter codes came up. We'll see if it ever happens again...
    as an aside - the tech says they were very interested in my car due to the almost 91%lifetime EV. He said once they hooked it up to the computer they were requested to go down some different paths - whatever that means is beyond me
  5. GregP507
    GregP507 Senior Member
    3,002
    480
    I had the same warning, but it went away after a few minutes. I'm sure it was caused when I had some things unplugged while the dash was dismantled when I was doing some wiring for my extra cameras.
  6. vvillovv
    vvillovv Senior Member
    3,529
    1,241
    NY
    the a/c refused to come on several times in my month old car the other day while charging, using the fob a/c button. It went through all the pre stages of switching on, then shut down, everything was just off again. The only thing I can think of which might have caused it was that the outside temp was around 75 and the a/c was set at 79.
    I'm not sure how I had my a/c set at 79 either.
    Do you remember if the pack was fully charged when you activated the a/c? How many ev miles was your gauge showing were available?
    Those different paths they were talking about were most likely the techstream ODB diagnostics. That stuff is pretty advanced these days.
    Just look at what you can get out of the torque app a bluetooth doggle and your cell.
    It's incredible.
    #6 vvillovv, Jul 9, 2014
  7. GregP507
    3,002
    480
    I hope these aren't tell-tale signs of a buggy computer system. I've had minor irregularities, but nothing that wasn't rectified by turning something off and on again. I haven't read about any major problems with it so far.
  8. vvillovv
    3,529
    1,241
    NY
    I'm not worried about mine. I most likely asked the car to do something it knew I shouldn't have asked it to do.
    Understanding what that is/was will help me use the car more efficently, if I can figure it out.
    That is why I'm also interested in what fortytwok remembers about the car when it happened.
    Things like what the a/c temp was set at, how much charge was in the pack, was it 90 in full sun or partly shaded, etc?
  9. rxlawdude
    rxlawdude Active Member
    701
    219
    So Calif
    2015 Tesla Model S
    For the remote to work,
    1. Car must be locked
    2. Must have adequate traction battery state of charge
    3. Ambient temperature must be greater than setpoint
    I think your situation failed point 3. :)
  10. bisco
    48,945
    i've never had any bugs.
  11. Gruvin2
    Gruvin2 Junior Member
    45
    16
    Baltimore, MD
    iirc I tried to use the remote AC start to no avail to find out you must have the headlights turned off.
    Tracksyde likes this.
  12. fortytwok
    467
    139
    Hopkinton MA
    2013 Prius Plug-in
    AC was set at 68 and I had roughly 11 miles left as the train station is close.
    It was 90 full sun.
    I have the error codes at home - traveling now...
  13. Camfab
    Camfab Member
    118
    35
    2014 Prius Plug-in
    Interesting, I tried the A/C button the other day, it was well over 90. It was the first time I tried it and nothing happened. I pressed it multiple times and got frustrated. I figured there must be something I'm doing wrong. I'll give it a go again tomorrow.
  14. fortytwok
    467
    139
    Hopkinton MA
    2013 Prius Plug-in
    Sad because it is an option but I'm not so sure I'm gonna try the key AC again ! Car is garaged and I've prob only used AC a few times anyway. I'd feel differently if I was in a different locale but this was a pain in the butt !
  15. JamesBurke
    JamesBurke Senior Member
    1,222
    493
    27
    Morgantown, WV
    Stuck motor/piston/relay do to lack of use? A/C inverter power supply over or no current detected? Low refrigerant level cutoff? Or for others oxidized FOB contacts from lack of use?
  16. Camfab
    Camfab Member
    118
    35
    2014 Prius Plug-in
    Ok just went out stood next to the car and it worked. It figures because I'm taking the car in for its fist service, it probably got nervous.:)
  17. bfd
    bfd Plug-In Perpetuator
    659
    172
    Close to SDSU in the Far Southwest Corner of Cali
    In my case, what you described ended up being a blown sensor in the inverter. Even though it was just a sensor, it required the entire inverter to be RnR'd. Since it happened over the holidays, delivery of a new unit took longer than expected. I was without my car for about two weeks. At least the dealer covered the rental. Never learned what caused it or how to prevent it happening again.
    A second fault, a few months later, was said to be due to Scan Gauge being hooked up. That was solved by changing to a read only plug.
    vvillovv likes this.
  18. vvillovv
    3,529
    1,241
    NY
    If you do try again set your a/c much higher in 90 degrees full sun.
    Test a few times while plugged in at lower outside temps before using the pack to run the a/c.
    a/c set at 75 will probably turn the car into an icebox at 90 degrees outside temp for the 10 minutes it runs,, at least that is what it felt like for me.
    Sorry to hear about the codes, I know how frustrating they can be to understand and deal with..
    rxlawdude: when I us the a/c button the car locks itself, and if I open a door the a/c shuts off and screws with the charge internals if it is charging while a/c runs. Once a/c is set on while charging or plugged in before or after charging, it's probably a good idea to let it run the full 10 minute cycle unless an emergency.
    At least that is what it looks like in my car.
    As always, YMMV
    #18 vvillovv, Jul 10, 2014
  19. vvillovv
    3,529
    1,241
    NY
    Ask the shop manager for the techstream data next time. They might not give it to you but at least you can try.
    My scangauge is all over the place with it's normal ICE gauges. And so far the only gen 3 gauges I've gotten working are SOC, bcw and bdw ( State Of Charge, battery charge watts and battery discharge watts ).
    I still have a long list of gen 3 gauges to test.
  20. rxlawdude
    701
    219
    So Calif
    2015 Tesla Model S
    Yeah, I'd be nervous about getting fist service, too. :D
    JBumps, mrstop and Tracksyde like this.
