Chip/install kit: Electric Only Mode Option for (Prius 2004-2009)
Discussion in 'Gen 2 Prius Accessories & Modifications' started by ricomada, Dec 5, 2012.
  1. ricomada
    ricomada New Member
  2. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    744
    Delaware
    there is a kit that many have used which apparently works fine. there is no down side that i know of. but i would make sure i bought the same kit that is in the sticky thread about ev mode. not all companies can be trusted.
  3. ricomada
    ricomada New Member
    do you have a link to that thread?
    48,862
    sticky's are in yellow highlite at the top of the gen II forum.
    Edo likes this.
  5. 69shovlhed
    2,170
    744
    Delaware
    yup. the very 1st thread is coastal ev mod, or something like that
  6. bisco
    48,862
    as far as whether it's a good thing or not, i hardly ever used mine after the initial excitement wore off. it's great for moving your car without the ice starting, or showing someone how an electric car would work, things like that. but if you want touse it to drive electric a lot, you'll find it doesn't go very far and will reduce your mpg's because the ice will have to recharge the battery and that is less efficient than powering the car. with few exceptions, you get your best mileage using the ice to accellerate and glide without regen and let the battery take care of itself.
    xpcman and JimboPalmer like this.
  7. ricomada
    ricomada New Member
    Thanks! I really appreciate this kind of info/feedback, Bisco. I think I'll let it ride how it is and earmark that $45 towards a PHEV Kit in a year or so.
  8. Justdidit
    Justdidit LVNPZEV
    1,880
    708
    75
    Carrollton, Texas
    Four Touring
  9. bisco
    48,862
    i have a new one still in the package, that my daughter gave me for Christmas a few years ago. since i hardly used the one on my 04, i never bothered to install it. now she has my 08 and isn't interested either. if anyone wants it, they can have it no charge. pm me your address and i will mail it out to you.
    Neil Dailey likes this.
  10. w8_4_me
    w8_4_me Junior Member
    Do you still have it? Would like to give it a try.
  11. Generaleet
    Generaleet New Member
    Ft. Bliss
    I was not sure if you still had it, I am trying to increase my MPG. Is it inconvienent to use, or annoying? Why not just install it?
  12. bisco
    48,862
    sorry guys, i gave it to ricomada.
    1) it won't increase your mileage, it will decrease it.
    2) it is not inconvenient or annoying.
    3) i had one on my 04, after the thrill wore off, inever used it again. just wasn't worth the time or trouble to install it. it's not hard, but you do have to pull the glovebox apart.
    Justdidit and Generaleet like this.
  13. Presto
    Presto Has his homepage set to PC
    1,326
    24
    Vancouver, BC
    If you're comfortable with some simple wiring work, you can get this mod done for free. Basically, all the mod does is ground a single pin, momentarily, to activate EV mode.
  14. Thadd Dale
    Thadd Dale New Member
    does anyone have the wiring schematic of what wires need to be grounded to make it work?
  15. Presto
    1,326
    24
    Vancouver, BC
  16. trseven
    trseven Junior Member
    58
    Council Bluffs, Iowa
    Did the mod myself with a cheap momentary push button switch on my 2004. Times I use it: from the turn light just before pulling into work, usually have over 60% charge (scanguage I I ). Then I can cruise the parking lot without the engine coming on. Gone from one store to another when they are clustered together, again only if I'm over 60% charge. And use it to shut off the engine when it's still running, coasting down hill, warmed up, and with good charge.
    Gerry
  17. krmcg
    2,592
    2,388
    Whittier, CA
    I use mine everyday on my commute to work. I have a half-mile coast on the freeway off-ramp, and when I hit the traffic signal my traction battery is in the "green". I switch to electric mode and drive the mile and a half to my parking spot at work with no ICE. Just have to stay under 35 MPH.
  18. steve_b
    steve_b New Member
    South Central PA.
    I'm guessing that the ICE will still start and power the car if it really needs to?
  19. krmcg
    2,592
    2,388
    Whittier, CA
    Yes - the ICE will come on if the battery goes "purple" or if you exceed the parameters. (34 mph speed limit, excessive acceleration, etc.)
  20. steve_b
    steve_b New Member
    South Central PA.
    Ok, good information. Thanks Kevin!
