chirping noise/smart key malfunction/lowered gas mileage
Discussion in 'Gen 2 Prius Technical Discussion' started by grasshopper537, Dec 27, 2006.
  1. grasshopper537
    grasshopper537 New Member
    We bought our 2006 Prius in June and love the car. We have had 3 "bugs" if you will. The first one is a chirping noise that we hear when we start the car. It's not consistent. It doesn't last more than a couple of seconds, sounds like some type of pump starting. It will chirp when started on electric, no engine started even. Been into dealer 3 times, no resolution. Checks out fine. Just wondering if anyone else has experienced this? Also, 2nd "bug".....smart key function, malfunctioned on cold snap last month. Wouldn't let us in car, had to use the actual "key", and sometimes even put transponder in slot. Very erratic, but once weather warmed up, has disappeared. Pretty sure there was no sticker on this car that said it must be garage kept and heated. Hoping this problem doesn't return. Third "bug".....recently noticed car is about 10mpg under what we used to get for an average. Don't know if the "chirp" problem is related. Have bought gas at several locations. Used to get 47mpg average, and now I can't get above 37mpg it seems. Also noticed on the energy monitor that the "battery" box is usually blue in color. Now we notice it goes to a lime green color. What is the significance to the colors? Does anyone know? We are wondering if the battery is not working as well, causing our average mpg to drop. Any feedback is appreciated. Thank you.
  2. statultra
    statultra uber-Senior Member
    796
    30
    Edison,NJ
    2001 Prius
    the chirp problemthat you hear is just a pump that takes coolant from a thermos andpumps it into the radiator to help warm up the gasoline engine, its not to worry about.
    2nd the possible reason why your transponder didnt work could may as well be the battery in the transponder, ( btw try pressing lock and unlock on the remote when it wont let you in, see if that works)
    your gas mileage might just be down due to the winter blend of gas, or weather changes, or tire pressure / air filter / oil , any of the above.
    also, the lime green is good! ( any color is good as long as theres colors , no bars mean problem) dont worry just drive it!
  3. grasshopper537
    <div class='quotetop'>QUOTE(statultra @ Dec 28 2006, 01:11 AM) [snapback]367542[/snapback]</div>
    Thanks for your reply. Glad to hear my concerns are not bad. As for that transponder, did do the battery thing, and checked both transponders too. Same problem. Will try the lock, unlock for sure if it happens again. Thanks for you advice. Doing the block the radiator with pipe insulation trick to see if that helps. Everyone around me is freaked cause I'm asking about a block heater for this car. Dealer won't have anything to do with it. Napa doesn't show a block heater available for that car. Incidently, asked the dealer about the lime green and blue battery deal, and they claim that when it's green, that means the battery is recovering, and when it's done doing that, it goes to blue. Bars I have, so I'm good like you said. Was just curious.
  4. Bill Merchant
    Bill Merchant absit invidia
    4,096
    81
    Hi grasshopper. To expand a bit on what statultra said, when it's cold, your Prius will run the Internal Combustion Engine (ICE) to heat the cabin, if you don't have the heater turned off, and to warm the catalytic converter to keep emisions low. Running the ICE uses gas, so your MPG goes down. Running the ICE also charges the HV battery, so the display shows green more. Since "winter gas" contains ethanol to reduce emissions in all cars, it has less energy per unit of volume; you'll use more volume (gallons) for the same kind of driving.
    All cars use more fuel in the winter because of greater demand for heat and lower energy fuel. In the Prius you just have a way to see it. Don't worry, it's just winter.
    Do a search on block heater and you'll find lots of discussion. Many people have them, particulary as you move north. I don't know why SKS would be affected by cold unless the cold affected the availability of voltage to power the system, either in the car or in your pocket.
  5. aaf709
    3,862
    2022 Prius Prime
    I just had the SKS problem (wouldn't work, buttons on fob did nothing, needed in slot to start) yesterday, but only when it was parked next to the Midway. The battery is about 1 1/2 years old.
  6. DanMan32
    DanMan32 Senior Member
    3,799
    26
    Tampa Bay, FL
    SKS works by an oscillator at various places in the car triggering the fob to transmit a security code, which is received by the same receiver that the remote lock function uses.
    So, if the buttons on the fob don't work, either the fob is the problem, or the receiver. If you see a red light blink on the fob when you touch the door handle, or when you press a button, then the problem probably is the receiver and ECU, although the fob could be transmitting a weak signal. Also outside interference (radio towers, cellphones, etc) can cause SKS and remote lock malfunction.
  7. fphinney
    fphinney Member
    234
    Walnut Creek CA
    <div class='quotetop'>QUOTE(DanMan32 @ Dec 30 2006, 12:11 PM) [snapback]368675[/snapback]</div>
    We also picked up an '06 last June. One other thing that will make a little red light blink on the fob - is to watch it carefully as you walk up to the car. When you get fairly close to the car, the dome lights will come on. The 'handshake' signal is that the light will blink just as this action takes place.
    I'm embarrased to admit that we had owned the car for over two months, before I discovered that the dome lights will come on automatically as you approach the car!!
  8. tumbleweed
    tumbleweed Senior Member
    4,067
    687
    Eastern Oregon
    <div class='quotetop'>QUOTE(grasshopper537 @ Dec 28 2006, 11:07 AM) [snapback]367717[/snapback]</div>
    Not to long ago someone on here was trying to get enough people for a group buy on block heaters, if the search function still works you may find that topic. Hobbit has an excellent write up on how to install one. Your dealer should be able to sell you one, they are a Toyota accessory.
    The dealer did not give you a good answer about the battery SOC indications, probably because they don't know the answer and are to arrogant to simply say that. If you count the bars you will see that there are 8 of them, they go from approximately 40% to 80% state of charge (SOC). Those numbers are not exact but they are close. Toyota engineers decided to keep the battery between about 40% and 80% to increase battery life. The bottom two bars are pink, the four in the center turn the display blue, and the top two make it all green. The car usually tries to keep the battery in the blue at about 60% to 70%. If you drive in the mountains you will see the SOC in the pink, sometimes with only one bar left, while you are going up long steep hills; when you come down again it will frequently go clear to the top, all green. Both of these conditions (pink and green) are normal. I have never seen the last pink bar go away no mater how long and steep the hill, I do not think that would be normal.
    It is also common to have green bars (70% to 80%) in cold weather because the engine runs more to keep the emissions under control and to keep the car warm. That is also part of the reason why the mileage is down in the winter.
