Choosing the right gas
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Janis, Jan 12, 2014.
  1. Janis
    Janis Junior Member
    This year my snowblower required expensive service and I was told it was because I used the standard in Michigan ethanol added fuel. So I switched to ethanol free gas for the snowblower. Then I wondered would it be okay to use the same fuel in my 05 Prius?
  2. nh7o
    nh7o Off grid since 1980
    1,686
    338
    Hawaii
    I use ethanol free gas, and it does give a slight boost in mpg in the Prius. You didn't say what it was that was fixed on your engine. Perhaps something to do with rubber parts decomposing? Or more about cold temps? I drain all my small power tools empty every time I use them to avoid that. There seems to be no generic problem with ethanol gas in the Prius, however, as many use it over 100,000's of miles.
  3. Britprius
    Britprius Senior Member
    5,194
    1,912
    Herefordshire England
    Yes you can use ethanol free fuel in the Prius, and you will get more mpg. The downside is that the ethanol free fuel is more expensive so the gain cost wise can cancel out. No harm will come to the car with either fuel.
    John (Britprius)
  4. wjtracy
    wjtracy Senior Member
    11,313
    3,588
    Northern VA (NoVA)
    As mentioned above, Prius is designed to work with E10 no problems. Small engines can have issue as you have seen. Due to EPA regs, many of us have no local access to E0 so we must use E10 at all times. If you have access to E0, you can decide if the extra MPG (~3%) is worth the extra cost.
  5. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    87 Octane (85 in the mountains) E10 or less Gasoline.
    I choose to buy gas at very popular stations when they themselves are not refueling, as I want fresh, clean gas.
  6. Janis
    Janis Junior Member
    Thanks everyone for the input. Fueling up my gas can and car at the same time, same pump would be a matter of convenience. Surprisingly at the one local station selling non ethanol, the price is 3 cents cheaper. Not much but I'll take it.
