Cig/USB charging issue
Discussion in 'Gen 3 Prius Audio and Electronics' started by MarsMan, Sep 3, 2015.
  1. MarsMan
    MarsMan Junior Member
    34
    Torrance, Ca
    I have a few different cig/USB adapters, whenever I have my Samsung S6 and my wife's Samsung Mega 2 (or her Tab 3) plugged in, it kills the port until I unplug and re-plug in the adapter. (tested it in her Scion xB and it works like it should)
    I even tried using the S6 on the dash port, and her Mega2 on the center console port, same issue. We can only charge one at a time.
    Is anyone else having or seen this issue? I'm looking for a work around. We have three kids with phones/tablets; and I have an anker 5 port adapter I want to use on long trips.
  2. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    My guess is that you are trying to pull too much juice. The owners manual says they are designed for 10a.
  3. MarsMan
    34
    Torrance, Ca
    I feared that, its highly annoying.
    Any idea for a safe spot to tap into the fuse block to bypass that/add a line or two? I would like to avoid going straight to the battery.
    I like the fuse block as it will kill the power when the car is off. I need to keep everyone charged and battery packing it x4 is a pain sometimes.
  4. xliderider
    xliderider Senior Member
    7,842
    3,099
    Honolulu, HI
    I tap my seat heater fuses for all of my power needs because our level 3 Prius doesn't have seat heaters. ;)
    MarsMan likes this.
  5. DoubleDAZ
    DoubleDAZ Senior Member
    1,209
    322
    Peoria AZ (Phoenix)
    I can't believe 2 of those 3 devices are pulling 10 amps. I have a splitter with 2 outlets and 2 USB ports connected to the front outlet and a Stanley inverter with 1 AC outlet and 1 USB port connected to the console outlet. I've had 2 RazRs, 2 iPhone 6S and a Garmin Nuvi 2555 plugged in at the same time with no problems. Are you able to plug ANY 2 devices into the 2 outlets without problems?
