Clanking sound.
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by EvanB, Oct 20, 2014.
  1. EvanB
    EvanB Junior Member
    39
    Phoenix, Arizona
    2014 Prius Plug-in
    Hello,
    On my 2014 pip. (4500 miles)
    I notice when I go over expansion joints on the freeway with my window open I can hear a bit of a clank sound. I do not hear it with the windows closed.
    Also it must be done at speed > 55mph.
    I do have a trailer hitch but it seems quite tight.
    Is this normal? Is it an issue I should bring up at the 5k service?
  2. Rebound
    Rebound Senior Member
    3,961
    2,609
    Portland, OR
    It could be a stone in the tire tread
  3. GregP507
    GregP507 Senior Member
    3,002
    480
    It could be a missing bushing somewhere in the undercarriage. If you don't get it fixed, it may wear through.
    48,990
    i would climb under and give it a good look see. maybe the exhaust system or an under panel. better if you can get it up on a lift.
    Okinawa likes this.
  5. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    I hear something like this when I "drive by Braille" (driving over the dots on the road). I always thought it was a heat shield or something like that. I dont recall when I first noticed it, but I would say its done it since it was new.
    I rarely hear it (since I dont drive by Braille that often and my window is rarely down) so I never thought to bring it up at a service appointment. And like you, I never hear it with the windows up. But I've been under the car a few times and never noticed anything that looked like it would make noise.
    It definitely wouldnt hurt to bring it up at a service appointment.
  6. Dex
    Dex Junior Member
    Warner Robins, GA
    Have you installed lowering springs recently? or modified the suspension in any way?
  7. CARspec
    CARspec Junior Member
    53
    Eden Prairie, MN
    2014 Prius Plug-in
    It is your brake pads moving around in the fitment kits. There is a bulletin for older cars, new ones do it sometimes too. Both the shop 2011 and 2014 do it. NBD.
    Bulletin is T-SB-0136-11.
    SAronian likes this.
  8. LakeMichBoatGuy
    LakeMichBoatGuy Junior Member
    Bloomfield Hills, MI
    2013 Prius Plug-in
    Michigan roads are not in the best shape, so I hear this sound all the time from our 2013 pip base. Clanking seems like a good description. It's a solid, predictable sound; not wild or worrisome. We have one "good" hybrid tech at a nearby Toyota dealer, and he said his personal non-pip does the same thing...although he has never mentioned any cause. The brake pads moving around seems like a good explanation. It's that kind of sound.
  9. css28
    css28 Senior Member
    1,566
    442
    Suburban Detroit
    rxlawdude likes this.
