Clicking Noise From Brakes - Chirping Noise When I Press Hard
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Austin Middleton, Apr 5, 2013.
  1. Austin Middleton
    Austin Middleton New Member
    There is a pretty loud continuous clicking noise lasting about 30 seconds (not necessarily a bad one - just annoying) that comes on every thirty seconds to a minute when I'm driving my Prius. It happens more often now than it did 10,000 miles ago.
    It also happens without fail for a few seconds every time I brake. Is this a normal noise? I fear it may be associated with the brake actuator--which the chirping noise is associated with.
    If I press firmly on the brakes (which is rare), they chirp. Toyota released a bulletin on it.
    TSB BR001-07
    I'm really tight on cash and it would be horrifying if I had to spend 2700 on a brake actuator. Will it fail eventually? I know the chirping noise has been brought up before, but because of the clicking noise I also have, I'm posting again. Any ideas what this might be--or what might fix it? Is it worth spending $100 on a brake flush? Would it cause more damage if I didn't flush it? Why would it have air bubbles in the system anyway? Thoughts? :)
  2. jdenenberg
    jdenenberg EE Professor
    3,837
    1,827
    Trumbull, CT
    2020 Prius
    LE AWD-e
    My chirp was eliminated by bleeding the right front brake by the dealer a long time ago and it never returned.
    You don't have to flush the brake fluid, but there is a chance that the actuator has a problem (letting in some air). Air could also come in at any coupling in the hydraulic system, but I would think that there would be signs of brake fluid leakage if that were the case.
    JeffD
  3. Austin Middleton
    Maybe I'll just bleed them and hope it fixes the issue. What about the clicking noise? Anyone have insight on that?
  4. jdenenberg
    3,837
    1,827
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Just realize that bleeding Prius brakes is a bit different than bleeding brakes in a "normal" car. It usually requires being able to input OBDII commands to control hydraulic valves.
    JeffD
  5. Austin Middleton
    Would it work to just use my personal OBD II units to reset the codes on every flush? Or do I need to have toyota use their techstream to do it?
    I'm afraid an OBD II may not open all the valves and make the problem worse.
  6. Austin Middleton
    That isn't, however, going to fix the clicking noise. Do you have the same clicking noise from your prius? Or is that not normal? It's pretty loud and I can hear it unless I'm going at highway speeds.
  7. jdenenberg
    3,837
    1,827
    Trumbull, CT
    2020 Prius
    LE AWD-e
    There are instruction for a DIY brake bleed on PC. Do a search, but I have never done one myself.
    JeffD
  8. jdenenberg
    3,837
    1,827
    Trumbull, CT
    2020 Prius
    LE AWD-e
    I don't have a "Clicking" noise so can't help you there.
    JeffD
