Closed windows with AC or windows down no AC?
Discussion in 'Prius c Fuel Economy' started by DKTVAV, May 30, 2014.
  1. DKTVAV
    DKTVAV Active Member
    510
    101
    Which way will have better MPG?
  2. JC91006
    16,470
    8,383
    Windows open. However at over 40mpg, comfort would probably take the top spot over mpg
    SM-N900P ?
  3. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Above 40 MPH, windows closed, A/C (that is always best for battery life)
  4. HotDogWater
    HotDogWater Junior Member
    70
    17
    There's a Mythbusters episode about this, I'm sure you could look it up easily on YouTube.
  5. minkus
    minkus Active Member
    369
    125
    Cleveland, OH
    It likely varies a lot based on the car, especially with hybrids. Also, IIRC they tested with all windows all the way down on the highway, which is excessive. I have them maybe 1/4 of the way down when driving 50+ mph.
  6. Easy Rider
    Easy Rider Active Member
    982
    210
    N. Central Florida
    Another case of OCD.
    Do whatever you are comfortable with and don't worry about it.
    The difference likely will be very small.
    Or.......run your own tests......over several weeks and several tanks of gas.
    Keep very accurate records of possible skewing factors; temperature, wind, elevation.....etc. and of the gas used.
    Then pay a major university to analyze the data for you.
    :whistle:
    coyote303 likes this.
  7. Mendel Leisk
    38,207
    I opt for windows open most of the time. One thing to be cognisant of though: it's good to run the A/C periodically, say at least monthly, to circulate oil in the lines, keeping the seals from drying out.
    minkus likes this.
  8. SageBrush
    SageBrush Senior Member
    11,627
    2,530
    Southwest Colorado
    Winter too ?
  9. Mendel Leisk
    38,207
    ^ Not sure what you're asking. I opt for windows down instead of A/C in hot weather, especially for lower speeds and short trips, when increased drag is not an issue, and it's not going to be that effective anyway.
    On extended highway runs yeah turn on the A/C. That is unless we're with our younger son, who hates A/C. I do try to run the A/C at least a few minutes every so often, year 'round. Think I actually use A/C more in winter, for dehumidifying.
    minkus likes this.
  10. SageBrush
    11,627
    2,530
    Southwest Colorado
    thanks
