Cold driving gen III
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by defrankond, Nov 22, 2014.
  1. defrankond
    defrankond Member
    217
    23
    North Dakota
    ive noticed when temps fell below 27 degrees my prius does something odd. After starting the car I drive off right away after a few seconds of idle time. I can drive a block or two and come to a stop sign, engine still running but when I go to accelerate it starts off ok but it then feels like a loss of power almost like a slow start on EV only. 2-3 seconds later the engine changes rpm and power returns to normal. No lights, no errors and @ 76k miles
  2. Okinawa
    Okinawa Senior Member
    1,333
    317
    Put a container of Chevron Techron in your gas tank and see if that helps.
  3. JC91006
    16,470
    8,383
    this doesn't happen when it's 28 degrees or higher?
  4. Tideland Prius
    16,073
    Well when the engine is cold, it'll run on battery power (even though the engine is running). It'll rev up when the engine is at a minimum temperature or you force it to rev up (accelerate hard, not recommended unless you had to get out of the way of a hazard).
  5. defrankond
    defrankond Member
    217
    23
    North Dakota
    Yesterday it was 34 and today it was 41 and did not do it. But anytime below 30 degrees out it does it. I have ran chevron through it and sadly that caused my mpg to dramatically drop. I went from 52mpg and currently at temps around 19-29 im averaging 34.9-35.4. The 12v battery is the original and idk if it is getting weak. I had it tested and the toyota dealership said it was fine. The only other odd thing I noticed is the footwell lights used to go off when the car was put in drive. Now they don't. They dim slightly but do not turn off and when it is put in park they brighten again. Idk if the two are related in anyway but it just seems kind of odd
  6. Tideland Prius
    16,073
    The footwell lights have always dimmed in Drive, so that's normal.
  7. ForestBeekeeper
    ForestBeekeeper Active Member
    695
    269
    Maine
    This sounds like things well within the warm-up period, before the ICE starts generating power.
    Is your grill blocked?
  8. Former Member 68813
    3,524
    981
    US
    Well, looks like under 27 degrees, the few seconds of warm up is not enough.
  9. defrankond
    defrankond Member
    217
    23
    North Dakota
    Yeah she might be a cold blooded bitch. This is the first winter with this car. Time to learn her quirks I guess. This is the first gen III i have owned my gen II's didn't do this lol
  10. freemandp
    freemandp Junior Member
    Canonsburg, Pennsylvania
    The intake manifold gets clogged up over time (100K) and causes a progressive loss of power. That could be the problem. If it keeps getting worse and chugs a little going up hills thats your problem. There's a thread on the forum of how to fix it. Took me about an hour to take it off and clean it with pipe cleaners and degreaser. I believe its a faulty design on some of the earlier Gen III intake manifolds. Mine was bought in aug 2009.
  11. bisco
    48,989
    block heater?
  12. defrankond
    defrankond Member
    217
    23
    North Dakota
    No block heater installed bisco.
  13. szgabor
    szgabor Active Member
    993
    175
    Oceanside NY
    Nonsense ..... !!!
    As others explained this is the "expected" behavior when ICE is not up to operating temp....
    For OP if you have temp monitoring like scangauge... watch for cooler temp... around 71-74F in idle you can hear a distinct change of engine noise that is when ICE will power the car (unless described as emergency) until then it "tries" to go on EV if enough charge or 'reduced' power ....
    I got this reading PC posts there is a thread on warm up vs mpg loss or something like that with. I believe BobWilson did some measurements on this and had detailed analysis what is going on and had some recommendations based on his findings...
    And as OP said it is repeatable ...
  14. john1701a
    john1701a Prius Guru
    12,749
    5,243
    57
    It's normal for the system to take advantage of the battery-pack when the engine is cold.
    Living in Minnesota, I experienced that on a regular basis with all 3 generations of Prius I've owned... the Classic, the Iconic, and the 2010... especially due to living at the bottom of a large hill and needing to do the climb right away.
    It was no big deal, since there's no concern whatsoever about the battery-pack being stressed. NiMH works quite well when cold.
