Comparison: Plugin hybrid tailpipe and evaporative emission
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by usbseawolf2000, Feb 14, 2012.
  1. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,994
    Fort Lee, NJ
    A comparison of three available plugin hybrids, namely Prius PHV, Volt and Fisker Karma.
    Exhaust Emission
    Evaporative Emission
    Here is the comparison of 2012 Volt that would only be sold in California (for HOV lane access) versus the standard model that would be sold outside California.
    2012 Volt ULEV vs. SULEV (Exhaust Emission)
    2012 Volt ULEV vs. SULEV (Evaporative Emission)
  2. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    I feel like you are hiding how bad the 49 state Volt really is by never comparing it to the Prius and the Karma. But maybe you were avoiding kicking them while they were down.
  3. usbseawolf2000
    14,487
    2,994
    Fort Lee, NJ
    The last two charts show the two Volt emission difference. Yea, it'll be nice to see all in one. Any other cars you want me to throw in? Perhaps, no-plug hybrids?
  4. austingreen
    austingreen Senior Member
    13,525
    4,057
    Austin, TX, USA
    how about a normal small car like fiat 500.
  5. fotomoto
    fotomoto Senior Member
    5,596
    3,770
    So. Texas
    How about the best selling car (camry?) and truck.
  6. Jeff N
    Jeff N The answer is 0042
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    How about the CA SULEV Prius versus the ULEV Prius sold in other parts of the U.S.?
  7. Jeff N
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    Interesting charts. Thanks for making them!
    Can you post links to the underlying emission tests results?
    One thing to keep in mind about the evaporative emissions is that the present diurnal tests include a "hot soak" meaning that the gas engine is run until hot and then a good chunk of the resulting emissions are due to the engine heat and emissions which escape from the exhaust system after the engine stops running.
    Now that we have PHEVs like the PiP and Volt they really need a separate set of diurnal tests which do not include a hot soak in order to measure diurnal evaporative emissions on days when the car is run entirely on battery.
  8. usbseawolf2000
    14,487
    2,994
    Fort Lee, NJ
    There is no such ULEV Prius. I guess that means Toyota sell the same CA SULEV Prius in all 50 states. That is true for Prius c, v, plugin and Lexus hybrids. I have never seen ULEV cert for Toyota/Lexus hybrids.
    PDFs are attached in the first post. You want the URLs, is it?
  9. austingreen
    13,525
    4,057
    Austin, TX, USA
    They are epa bin 3 in other states. We don't have warranty as part of our emissions levels test like CARB.:)
  10. usbseawolf2000
    14,487
    2,994
    Fort Lee, NJ
    telmo744 and giora like this.
  11. SlowTurd
    SlowTurd I LIKE PRIUS'S
    1,156
    333
    nj
    can you throw in a 300lb woman farting on a bicycle?
  12. austingreen
    13,525
    4,057
    Austin, TX, USA
    I've done the VO2Max test on the bike, but... they don't hook anything up to ummm.... the human tailpipe - just the mouth and nose. Can you find a fat woman to try it on?
  13. Jeff N
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    Okay, I see them now. I guess I overlooked them earlier. Thanks!
    So why does fueleconomy.gov list the Prius as having an emissions level of score 9 in California (PZEV) and 7 (bin 3) in Minnesota if the Prius has the same emissions in all 50 states?
    http://www.epa.gov/greenvehicles/summarychart.pdf
  14. usbseawolf2000
    14,487
    2,994
    Fort Lee, NJ
    Use your imaginaion. It wouldn't pass the smell test ;)
  15. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    PZEV is a California standard, it does not apply to non-CARB states. It is less clear why Toyota did not go for a Bin 2 classification, perhaps they had no Bin 8 vehicles to offset?
