Complete stereo overhaul with Navi and custom subwoofer enclosure
Discussion in 'Gen 3 Prius Audio and Electronics' started by riptide1, Jan 3, 2013.
  1. riptide1
    riptide1 Junior Member
    I wanted to share the results of my stereo upgrade project after learning much of what was needed from the forum and the documents created here.
    I have to start off by saying that this project couldn't have been done so well if it wasn't for John at Modern Kustom Classics (MKC in Concord, NC 704-787-6523 ), an excellent installer and fabricator. He did most of the installation and sound tuning and 100% of the subwoofer enclosure. The subwoofer sounds amazing. While John was building the box I had the JL sub in a Atrend 10SQL .75 cu ft. and it sounded good. Honestly, I was expecting less performance out of the custom box, but it actually sounds much better, way cool!
    For the headunit I went with the Toyota panel assembly part# 55405-47080 with Metra side trim 95-8202 kit which works great. with either side trim kit you will still have to grind the metal dimples off of the factory bracket. I used the Metra 70-1761 Wiring Harness and Metra Axxess ASWC Steering Wheel Control Interface. I didn't need a relay to override the parking brake circuit to use the dvd player and Nav. on this Kenwood unit while driving. The wire is just grounded to the metal frame.
    The interior except for the roof was done with Dynamat, except from the two front seats forward, there I used Stinger Roadkill carpet pad. I also used Dynamat under the factory hoodliner. This resulted in 30-40% less road noise, significant enough for my father who drives a Lexus to comment on how quiet the cabin is. Here's a funny story. When I got done all the matting I closed all the doors, but couldn't get the final door to close as easily as before. I messed around with the door panel, the plastic kick panel and the door sill trim thinking that something was bulging and causing a tighter fit. It wasn't until I openned the truck to relieve the positive pressure and then closed the driver door, did I realize what was going on. I haven't experienced that since then, but I am usually only openning and closing one door at a time.
    I figure it is easier to list the parts used:
    -Kenwood DNX-7190HD in dash unit
    -Kenwood CMOS-210 Back Up Camera
    -Toyota panel assembly part# 55405-47080
    -Metra side trim 95-8202 kit
    -Metra 70-1761 Wiring Harness
    -Metra Axxess ASWC Steering Wheel Control Interface
    -Kenwood KCA-iP202 iPod Adapter (iPod control using the touch screen is awesome)
    -JL Audio XD500/3 amp for Subwoofer (only the subwoofer output is being used - 300W @ 2ohms)
    -I choose this because it fits so nicely under either seat behind the air vent but before the hump
    -JL Audio 10W3V3-2ohm 10" Subwoofer
    -Alpine SPX-17REF 2-way component speakers 6.5" mid and 1" tweet -front
    -Alpine SPR-60 6.5" -rear doors
    -JL Audio XD400/4 amp - 60-75W @ 4ohms - amp for door speakers
    -Custom all fiberglass with mdf bottom subwoofer box. -approx. .62 cu. ft. no polyfill.
    -2x Dynamat 10455 18" x 32" -72 sq. ft. total
    If I were to do it again I would choose the cost savings of using only the JL Audio XD500/3 amp for the front component speakers and sub and not change out the rear door speakers, but just power them off of the head unit. Sitting in the front seats the rear door speakers don't add to the sound. I also would use Hertz Dieci DSK 165.3 components because the sound quality is comparable to the now discontinued Alpine Reference components. The Alpines I used are slightly better but the Hertz Dieci are a great value ..I have had excellent experience using them in a Toyota Corolla.
    IMG_20130103_114908_758.jpg IMG_20130103_115233_590.jpg IMG_20130103_115035_325.jpg IMG_20130103_114614_097.jpg
    Bmr4life, EdyJun, ockevin and 2 others like this.
  2. 1ULV2H8
    1ULV2H8 Member
    66
    25
    Columbia, SC
    Nice install! Everything looks really good, so I'm betting those connection cables at the center console must be bugging you lol
  3. riptide1
    Here are some more pictures taken about midway through the project.
    001.JPG 002.JPG 004.JPG 005.JPG 006.JPG 007.JPG 008.JPG 009.JPG 011.JPG 012.JPG 014.JPG 015.JPG
    Bmr4life, Want A Hybrid and ockevin like this.
  4. riptide1
    yeah always striving for perfection lol. The Kenwood DNX7190HD only has one USB input, so I needed a way to unplug the iPod Adapter cable and plug in a USB drive to ocassionally play movies. Movie watching is great in low light like at night, and of course the sound is very nice. FYI 2 channel audio is the way to go with movies. If the unit had a second USB input it would have been nice to recess mount it in that center console blank.
  5. Ragin Cajun
    Ragin Cajun Junior Member
    52
    16
    Where did you order your dash kit from?
  6. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Nice job, well done! Really like the color matched sub.
  7. riptide1
    Toyotapartszone.com it's 59.89 + shipping. Be prepared for it to take up to 2 weeks if you are on the east coast.
  8. riptide1
    John at Modern Kustom Classics in Concord, NC 704-787-6523 sent pictures he took throughout the subwoofer box building process.
    IMG_2637.PNG IMG_2639.PNG IMG_2640-1.png IMG_2636.PNG IMG_2635.PNG IMG_2634.PNG IMG_2543.JPG IMG_2544.JPG IMG_2545.JPG IMG_2546.JPG IMG_2641.PNG IMG_2547.JPG IMG_2548.JPG IMG_2549.JPG IMG_2553.JPG IMG_2555.JPG IMG_2593.JPG IMG_2607.JPG IMG_2608.JPG IMG_2609.JPG IMG_2610.JPG IMG_2611.JPG IMG_2612.JPG IMG_2613.JPG IMG_2618.JPG IMG_2614.JPG IMG_2631.JPG
    Bmr4life and ockevin like this.
  9. EdyJun
    EdyJun Junior Member
    58
    Los Angeles
  10. riptide1
    As long as you are comfortable taking off the door panels, interior trim and paneling you will be fine. I would recommend going to Harbor Freight or somewhere else and pickup a set of plastic pry bars for removing trim. Dynamat is easy to cut with a razor blade, and you can punch holes through it easily. A little roller will be helpful in the corners. Also you can cut little strips of it to secure any lose wiring you find along the way that might rattle otherwise.
    DROID RAZR HD ? 2
  11. frodoz737
    frodoz737 Top Wrench
    4,297
    2,347
    33
    Very Nice! (y) Decided on a grill for the sub?
  12. riptide1
    Yeah JL Audio sells one designed for the speaker it's a black mesh type. In my opinion it won't look as nice as it does without, but it will provide good protection.
    DROID RAZR HD ? 2
  13. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    EMT shears AKA Trauma Shears really work well on Dynamat and other sound deadeners. Don't get the cheapest and you don't need the high end ones. About $6 will get you a good pair.
    If anyone has trouble finding a roller, look for a wallpaper seam roller. A couple of dollars at a hardware store. I prefer the one inch wide ones to the wider ones. You get more pressure on the material and they work better in tight places.
  14. vdek
    vdek New Member
    How much do you think all that Dynamat added in weight?
  15. riptide1
    Dynamat added 40 lbs. Also the sub and two amps were another 40 lbs.
    DROID RAZR HD ? 2
  16. emorydptt
    emorydptt Junior Member
    17
    Hills of Florida, Clermont
    Looks amazing. I went the more simple route and carpeted over painting the front so that I didn't have to worry about the smoothness.
    A+ :)
  17. Bmr4life
    Bmr4life Member
    131
    56
    Atlanta, GA
    2014 Prius v wagon
    HECK YEAH. Now that is what I'm talking about.
    Also, I agree with you about the rear speakers. In most of my installs, I usually remove the rears all together. They screw up staging. Also, in a sedan the open deck holes let me bass in the cabin.
    riptide1 likes this.
  18. Want A Hybrid
    Want A Hybrid New Member
    Nice set of pics.
    How did the Stinger Roadkill carpet pad work for you? Are you able to just put these under the mats or do you need to remove the carpet and put it under the carpet and under the mats?
  19. Bmr4life
    Bmr4life Member
    131
    56
    Atlanta, GA
    2014 Prius v wagon
    So where is the camera mounted? Close to the stock location?
  20. riptide1
    I put it under the carpet from the front seats going forward until the carpet ends under the dash. I didn't use dynamat where I used the Roadkill, imo it works good by itself. It's thick so in places like where there is a styrofoam form under the pedals or in the corners where the plastic kick panels are, I cut away the Roadkill material.
    DROID RAZR HD ? 2
    Want A Hybrid likes this.
