1. Offline
    ericbecky Active Member
    Start a Conversation
    Mar 12, 2004
    852
    241
    Madison, Wisconsin
    Your Vehicle Year:
    Some people on this forum have previously purchased A123 lithium pouch cells and used them for their PHEV projects.
    I know that others are considering purchasing these cells for their own PHEV projects but are unsure of how to connect the cells since they have tabs rather than regular battery post terminals.
    I wanted to start this thread so we could specifically talk about the connections.
    Hopefully some of our experienced members will chime in and possibly share the pros and cons of how they did it. I'll also see about throwing in some info I've seen posted elsewhere on the web. No need to recreate the wheel.
    JJay and dave77 like this.
  2. Offline
    Mar 12, 2004
    852
    241
    Madison, Wisconsin
    Your Vehicle Year:
    Here is one example of connections done by member planetaire Can | PriusChat
    His cells were a bit different only because they did not have full tabs to work with.
    But you can still get a general idea of the connections.
    He, and almost everyone I talk to, says buying cells with full tabs is recommended.
    It is too much of a pain to work with the short/cutoff tabbed cells.
  3. Offline
    Mar 12, 2004
    852
    241
    Madison, Wisconsin
    Your Vehicle Year:
  4. Offline
    Dec 29, 2007
    4,111
    264
    Your Vehicle Year:
    10... yes sure 700 dollars just for the connectings...
    what you call useless...
  5. Offline
    Mar 12, 2004
    852
    241
    Madison, Wisconsin
    Your Vehicle Year:
    Exactly.
    Another guy down at our shop is considering using an accordion fold to connect the tabs and then crimping a piece of metal over top of the accordion fold. Seems reasonable. Lots of surface area touching, reversible if necessary.
    Other person here at the shop put holes through the tabs and bolted together.
    I also have some specialty connectors I have been researching. Unfortunately they are a custom order item with a minimum order and they only make a run of them periodically. 6 week lead time. I have some samples and they look promising. I'm waiting to get some other engineering opinions on them before ordering any.
    NortTexSalv04Prius likes this.
  6. Offline
    NortTexSalv04Prius Active Member
    Nov 14, 2009
    543
    45
    Your Vehicle Year:
    I want to make my own 8 cell with 3.2v 10ah tenergy(24v80ah) from allbattery(cali) however I neither have talent or shop tools to make these connections for the tabs to have decent connections or leads.
  7. Offline
    Mar 12, 2004
    852
    241
    Madison, Wisconsin
    Your Vehicle Year:
    I have been researching some options for a while.
    Here is a pre-made crimp connector for foil tabs
    51943 Product Details - TE
    It seems like a very easy solution for most of the needed connections for foil packs.
    The current would be carried between the tabs by the crimp connection.
    The spade connector could be used for balancing & monitoring.
    Here is a link to the technical specs pdf I downloaded.
    EV_Powers_Termifoil_51943_Connector.pdf - Google Docs
    I still want some confirmation that they can handle the current that we will be drawing. Any engineers want to weigh in?
    Downside is that there is a (6-week) lead time on ordering these plus a minimum order.
    Depending on cost I'll probably be putting in a group buy/large order for these as well. That way we can get them into the hands of people who need them.
  8. Offline
    Nov 14, 2009
    543
    45
    Your Vehicle Year:
    what would be min qty purchase and how many should I get for 8qty 3.2v 10ah in series?
  9. Offline
    Mar 12, 2004
    852
    241
    Madison, Wisconsin
    Your Vehicle Year:
    These are not a stocked item anywhere. The factory makes them only when there are orders for them. Minimum quantity I must order is 2,000.
    They would probably cost something like $1.25.
    Now they are saying 12-14 lead time.
  10. Offline
    chenyj Member
    May 22, 2009
    96
    114
    Troy, Michigan
    Your Vehicle Year:
    Yes, that works. We are doing that as well. It is very inexpensive, taking little space, reliable and never get loose under vibration like screws. The same way that people crimp Anderson connector pins.
    We roll the tabs three full cycles or more tightly, then slide a 1/4 copper tube which is cut open loop into the tab. Crimp the copper tube, tabs and BMS harness wire at least three spots using the Anderson cable crimping tool. Tape the terminal with electrical tape and use isolation material to separate each terminal from each other.
    dave77 likes this.
  11. Offline
    Nov 14, 2009
    543
    45
    Your Vehicle Year:
    Can you share images that would be nice you know too share...
  12. Offline
    chenyj Member
    May 22, 2009
    96
    114
    Troy, Michigan
    Your Vehicle Year:
    Here are some pictures. The more times you roll the tab the better.
  13. Offline
    Mar 12, 2004
    852
    241
    Madison, Wisconsin
    Your Vehicle Year:
    Great pictures!!
    How thick is the copper you are using to crimp around the tabs?
  14. Offline
    lopezjm2001 Test guinea pig #9
    Apr 14, 2009
    978
    338
    Sydney Australia
    Your Vehicle Year:
    How easy would it be to replace a bad cell?
  15. Offline
    Mar 12, 2004
    852
    241
    Madison, Wisconsin
    Your Vehicle Year:
    With the crimping method it is not too bad to replace a cell.
    Just wanted to note that the hole in the pouch cells Jack showed is there from a previous connection method. The hols is not needed for the crimping method.
    The old method involved a three nut/bolt combo. Plates on either side of the tabs, a nut/bolt combo through the center of the tabs, and two nut/bolt combos just past the edges of the tab.
  16. Offline
    Sep 6, 2005
    1,887
    285
    N.Babylon, Long Island, NY
    Your Vehicle Year:
    I have a question for the better informed users of this Real Force batteries assemblies..
    Is the phenolic board above the cells a "jig" for the alignment/isolation of the tabs while making the connections or part of the finish product.
    Also I noticed that there is some sort of dark gray foam/sponge in between the cells. Maybe an isolator/cushion?
  17. Offline
    chenyj Member
    May 22, 2009
    96
    114
    Troy, Michigan
    Your Vehicle Year:
    The board is not required. But it does align the tab battery and isolation the tabs from touching each other. It also put even pressure on the cells for supporting force.
    The foam is used as isolator so that the tabs do not touch each other and the cover.
    dave77 likes this.
  18. Offline
    chenyj Member
    May 22, 2009
    96
    114
    Troy, Michigan
    Your Vehicle Year:
    1/16 in or 1.5mm
    dave77 likes this.
  19. Offline
    chenyj Member
    May 22, 2009
    96
    114
    Troy, Michigan
    Your Vehicle Year:
    It is relatively easy. You can use a flat screw driver to open it from the outside edge inward.
    dave77 likes this.
  20. Offline
    Sep 6, 2005
    1,887
    285
    Your Vehicle Year:
    chenyj, thank you for the detailed information...(y)
Share This Page
