Connecting iPhone 4 or iPod to Prius base model
Discussion in 'Newbie Forum' started by janie, Aug 31, 2010.
  1. janie
    janie Precious Prius Plug In
    163
    37
    Hi there- I just got a 2010 Prius (base model, no navigation/bluetooth) on Sunday, and I used to own a 2004 Prius (fully loaded), which is very different than the new one :)
    I am not sure how to connect my iPhone and or iPod Nano - does anybody know what type of cable or something I might need to get?
    Also, I have no idea how to get my display to show the actual miles driven, instead of the Trip A, which it seems to be set on.
    Any information on how I can do these things, would be greatly appreciated.
    Thanks bunches in advance for any help :)
  2. janie
    163
    37
    Ok - after some other research and trial and error, got my answers:
    - i found out what type of cable from another prius group - i was told to get to Radio Shack and get an AUX cable. Yes, it worked- i had an old one that didn't work because it wasn't stereo, so i had to buy a stereo aux cable.
    In terms of figuring out how to get to the ODO on the display, i just had to keep clicking on display several times, until it finally showed up to display how many total miles i have driven . . .
  3. Canard
    Canard Member
    170
    17
    Ontario, Canada
    I've got maybe a dumb question that some more research would figure out (but I suspect you'd like to know the same thing as I!), and that is - is there any kit out there to digitally connect an iPod to the OEM head unit (30-pin connector) on cars not equipped with this hardware from the factory (and without Nav)? I know the analogue AUX-IN exists, but obviously a digital connection would be superior. :)
    Cheers,
    -Iain
  4. janie
    163
    37
    hmmm- good question - i have no clue how to research that information- but the place where i got my info on my initial question was from the Prius 3G yahoo group. So, if you post your question there, someone might give you an answer :)
  5. Paul58
    Paul58 Mileage Miser
    1,126
    125
    Atlanta
    The AUX Port is inside the armrest, on mine it has a USB Port and an Audio In plug-in (Looks like the jack where you plug in the headphones on your iPod). If you have the USB Port, you can plug your iPod in using the white charge/sync cable that came with it, if you don't have the USB Port you'll need to purchase the cable (it has the earphone type plug on both ends). Be sure to get a Stereo Cable, it will have a tip and two additional rings, if it just has the tip and the shaft, it won't work. Plug one end into the jack on your iPod and the other into the jack in the armrest. You have to control it from the iPod...
    Shop around, you should be able to find one for no more than a couple bucks... I'm pretty sure Target and WalMart carry them as well...
  6. Kerwin
    Kerwin New Member
    HOUSTON
    i am also looking for the answer and i tried yahoo forums but no response yet , if you find please inform me also
  7. Paul58
    1,126
    125
    Atlanta
    Kerwin,
    I'm a bit confused on which Model Prius you have, your info under your user name says Prius IV w/AT, The AT Package here in the US is only available on the Prius V.
    Regardless, the IV and V have BlueTooth, so you can connect an iPhone via Blooth and stream audio as well as send/receive phone calls. Use the Phone/Info button to set it up. You also have the USB Port I described in my previous post, an iPod can be connected to this port.
    Not sure if there is another question you're looking to have answered...
  8. Saruman!
    Saruman! New Member
    Netherlands
    A better solution than the standard Toyota bluetooth (which the base model doesn't even have anyway) is something like the Parrot MKi9200 - which I have. It can take iPod with an iPod connector in the glovebox, and send it to the car stereo (note that this requires an extra cable, for Toyota Prius a PC000005AA); it can also be controlled by the steering wheel controls using a Parrot box called Unika.
    I myself have the MKi9200 but am waiting for the dealer to install the cable; as of now, the 9200 sends the iPod sound directly to the speakers, but since its amp is not very good, I get 2 speakers of slightly distorted sound, instead of 6 speakers of glorious 320kbps progressive rock... I'll probably not be installing the Unika, since I don't mind the Parrot control on my steering wheel.
  9. Marc Pachtman
    Marc Pachtman New Member
    Philadelphia, PA
    Janie,
    In your question you state that you had a fully loaded Prius 2004. That is what we have. We have considered getting a 2010 but have started shopping. You say the 2010 is very different. In what ways is it different and are those differences an improvement? (One things that bugs me about the 2004 is that there is no visor over the GPS so it is very difficult to view during the day.)
