CONS is low
Discussion in 'Toyota Prius Plug-in' started by bielinsk, Jul 13, 2012.
  1. Offline
    bielinsk Gremlin
    Start a Conversation
    May 4, 2012
    466
    98
    Anaheim
    Your Vehicle Year:
    Last few fill ups my CONS was actually 3 MPG lower than my calculated. Everything I have read says it should be about 5% higher.
    Last fill up, CONS showed 49MPG, my calculated was 52MPG (All highway at 73mph and AC on Vegas to LA)
  2. Offline
    12,706
    1,814
    Your Vehicle Year:
    how do you calculate consumption? hv miles divided by gallons added?
  3. Offline
    Andyprius # 1 Member since 2005
    May 30, 2012
    1,012
    88
    Sacramento
    Your Vehicle Year:
    What is full? 10.2' 9.85 10.6 or anything around there. My point is that if you even had a wide open calibrated container and you stopped the pump at ONE gallon, it would still be wrong for multiple reasons. Is the pump accurate? How much gas is still in the hose? Is the mandatory temperature control system in the gas station tank accurate? I have only touched the surface. But instead of concerning yourself with gasoline used, think about how to do better. On one trip to LV from Sacto with my 2005 , I got 69 mpg! Admittedly There was a hellashus wind coming form LA on I 15. This PIP is magic and there are multiple ways to reduce consumption.
  4. Offline
    bielinsk Gremlin
    May 4, 2012
    466
    98
    Anaheim
    Your Vehicle Year:
    I use Fuelly to track all my fills ups. You can see the info in my link.
    Andy, I would love to see you get over 50mpg OC to Vegas in 110 heat. I guess I could have set the cruise at 60 mph and dodged the bullets from pissing people off. I don't like to hypermile, I'll spend the extra $2 in gas.
    Point of this thread was that most people have stated that the CONS is 5% over actual, and I am seeing the opposite.
  5. Offline
    usdmattiphone Member
    Sep 22, 2011
    145
    56
    Your Vehicle Year:
    Last weekend i went from San Diego to LV in 114 degree heat blasting my A/C the whole way, doing 75-80MPH most of the way, and I got 48MPG there, and 49MPG back. This car is like magic!
  6. Offline
    May 30, 2012
    1,012
    88
    Sacramento
    Your Vehicle Year:
    Please don't misunderstand me, I think the last two posters are doing great! But further records will happen.
  7. Offline
    bfd Plug-In Perpetuator
    Mar 19, 2009
    472
    78
    Close to SDSU in the Far Southwest Corner of Calif
    Your Vehicle Year:
    Only way to get better mileage is to travel to LV on a party bus (which is what we did for an Aztecs game earlier this spring!)
Share This Page
