1. Offline
    TrailRider New Member
    Start a Conversation
    Feb 16, 2011
    Aliso Viejo, CA
    Your Vehicle Year:
    It never rains in Southern California so I am considering removing the windshield wipers primarily because I think the Prius looks cleaner with out them and it provides a bit more visibility in the front and rear.
    Are there any aerodynamics to be gained by removing them and thus better gas mileage? They do seem to be shaped efficiently. Perhaps this may cause more harm than good??
  2. Offline
    jdenenberg EE Professor
    Nov 21, 2005
    2,059
    508
    Trumbull, CT
    Your Vehicle Year:
    Your car will be unsafe and not pass inspection in most states. The Prius is very aerodynamic and the small impact of wipers ( or side view mirrors ) is not noticeable at reasonable speeds.
    JeffD
  3. Offline
    rrolff Prius Surgeon
    Aug 19, 2009
    1,609
    222
    So Cal
    Your Vehicle Year:
    A year back, someone did a scientific study - and showed removing the wipers actually lowered mileage by 3.14%.
    Adding mudguards also increased mileage by 2.72% (odd as it may seem)...
    2 people like this.
  4. Offline
    Feb 16, 2011
    Aliso Viejo, CA
    Your Vehicle Year:
    That is quite odd, both opposite of what I would have envisioned. I'll try searching for it, but any links to this?? Was this for a Prius or general study?
  5. Offline
    Aug 19, 2009
    1,609
    222
    So Cal
    Your Vehicle Year:
    They also found adding the 'shark fin' antenna will increase mileage (something to do with aero dynamics).
  6. Offline
    Nov 21, 2005
    2,059
    508
    Trumbull, CT
    Your Vehicle Year:
    Actually it is the removal of the existing antenna that helps aerodynamics.
    JeffD
  7. Offline
    Aug 19, 2009
    1,609
    222
    So Cal
    Your Vehicle Year:
    Actually, it was tested at a wind tunnel (JPL), and shown to increase mileage.
    From memory, the mud guards help the most...
    1 people like this.
  8. Offline
    The Electric Me Go Speed Go!
    May 22, 2009
    3,444
    876
    Undisclosed Location
    Your Vehicle Year:
    In short? Benefit vs. Risk? Just back away from the windshield wipers...
    Come on? You never know where you might travel or when you might be in a freak rainstorm. Just keep the wipers.
  9. Offline
    hyo silver Away
    Mar 2, 2005
    14,882
    1,190
    Sunset
    Your Vehicle Year:
    You could probably do without the rear wiper, but no way would I recommend removing the fronts. If you never ever drive where it rains, you need to get out more. :p
  10. Offline
    Aug 19, 2009
    1,609
    222
    So Cal
    Your Vehicle Year:
    I don't use my wipers because they lower your mileage while moving to the right (though when returning, they get back 31.4% of the energy lost due to drag)...
  11. Offline
    hyo silver Away
    Mar 2, 2005
    14,882
    1,190
    Sunset
    Your Vehicle Year:
    But if you live in the Southern hemisphere (No, I don't mean SoCal) the wipers swipe the other way. :rolleyes:
  12. Offline
    xpcman Active Member
    Jun 11, 2009
    682
    110
    California - SF Bay area
    Your Vehicle Year:
    tail lights, air bags, seats, headlights, glove box and just about everything on the car decreases mileage. For top mpg I suggest you get 3 friends to PUSH the car for you.
    1 people like this.
  13. Online
    cwerdna Senior Member
    Sep 4, 2005
    11,664
    1,660
    SF Bay Area, CA
    Your Vehicle Year:
    inspection? huh?
    Inspection? I've seen people refer it here on occasion and I don't know what you're referring to. I grew up in CA and have lived in WA state for ~9 years (split between two time periods). Theses states don't inspect our cars for safety equipment or anything like that. I suppose one could be ticketed for missing or busted safety equipment, if pulled over.
    There are smog tests but that's it. At last check, Priuses are exempt from CA and WA smog tests.
  14. Offline
    Feb 16, 2011
    Aliso Viejo, CA
    Your Vehicle Year:
    Well, I've removed the wipers from some of my other cars in the past and never had a problem with getting stuck in a freak rainstorm. Now, if I lived in Portland Oregon, I would not be considering this, but I live in So Cal. For a minimum 6 months out of the year I can personally gaurantee no rain. :)
  15. Offline
    Feb 16, 2011
    Aliso Viejo, CA
    Your Vehicle Year:
    Really funny response, ha ha ha. :rolleyes:
  16. Offline
    Feb 16, 2011
    Aliso Viejo, CA
    Your Vehicle Year:
    Thanks for the reply rrolff. If it actually reduces mileage than that is certainly not worth it.
  17. Offline
    spiderman wretched
    Jul 5, 2009
    6,749
    1,172
    Alaska
    Your Vehicle Year:
    No, that is only applicable to toilet flushing... shezz.
  18. Offline
    spiderman wretched
    Jul 5, 2009
    6,749
    1,172
    Alaska
    Your Vehicle Year:
    You are truly a genius. I don't understand why you don't have more thank yous. :D rotfl
  19. Offline
    dtuite Silverback
    Mar 25, 2010
    183
    30
    Redwood City, CA
    Your Vehicle Year:
    I knew a guy down in San Diego who removed the fins from his '59 Caddy convertable. (And faired it all in nicely and repainted the yellow paint job). That looked pretty cool, but I didn't find out what it did to mileage. (Caddies of that era actually got better mileage than other GM cars, I mean often as high as 18 -- because they weren't as sloppily assembled.) In SoCal, this was also an era when people were buying perfectly good VWs in order to throw away the original body work so they could replace it with Meyers Manx dune-buggy shells. (which were street-legal) I thought about that myself at the time.
    So this is perfectly in line with a long tradition. But, instead of just throwing away the wipers, I think I'd recommend cutting off the roof instead. Make a Prius un-convertable. If it sprinkles, just drive faster. And turn up the Beachboys on the AM radio.
  20. Offline
    chrisj428 Active Member
    Sep 24, 2009
    598
    114
    Vernon Hills, IL
    Your Vehicle Year:
    What do they put in the water down there? I'm sorry -- I don't usually comment when I don't have anything to add; however, this truly smacks of a complete and total lack of common sense.
Share This Page
