1. Offline
    Kirkuleez New Member
    Start a Conversation
    Mar 13, 2012
    220
    Oshkosh, Wisconsin
    Your Vehicle Year:
    When setting up blutooth, only a handful of my contacts transferred to the car. Does anyone know why or how to get the entire list to transfer over??
  2. Offline
    Nerdalert Junior Member
    Apr 9, 2012
    Your Vehicle Year:
    I was having the same problem, so i reorganized my contacts my phone/computer and then went to delete the old, but it wont delete contacts for some reason, the button is greyed out. tried to import over them, and now of course i have two of everything. does anyone know how to delete contacts and start over?
  3. Offline
    Bales4 New Member
    Apr 20, 2012
    Missouri
    Your Vehicle Year:
    I couldn't even figure out how to send one contact over :(
  4. Offline
    ProximalSuns Senior Member
    Mar 24, 2012
    1,882
    PNW
    Your Vehicle Year:
    You don't say what phone. Not sure that makes a difference from the Prius side of it.
    You can "Refresh Phonebook" from the Phone/Setup menu. This should transfer your contacts from the phone to the Prius.
    Try that.
  5. Offline
    krneidigh Junior Member
    Mar 18, 2012
    50
    Pensacola
    Your Vehicle Year:
    You might check your phone during setup or transfer, mine actually prompts me about the transfer. I have to authorize the transfer on the phone side.
  6. Offline
    AutoMo Junior Member
    Jun 4, 2012
    48
    Eastern WA
    Your Vehicle Year:
    Same problem with my iPhone, contacts transferred but none of the associated phone numbers. I entered the important ones manually and realized after about 10 that there really weren't any more that were that important.
  7. Offline
    Kmullin80 Junior Member
    May 17, 2012
    33
    New Jersey
    Your Vehicle Year:
    I'm having a problem with only a few names displaying when I have an incoming call. My phone book downloaded and all my contacts are in the radio now but only the number displays when I have an incoming call.
  8. Offline
    BlackPC2 New Member
    Jul 12, 2012
    35
    Your Vehicle Year:
    I had the same problem for the first day...There is a phone menu option called transfer you need to do this after you synced your phone. I have read that some people had to accept the transfer on their phone via a pop-up or something. All I did was use the transfer function and it worked, I have an Iphone 4. I will try and take a photo of the menu option if that will help...
  9. Offline
    May 17, 2012
    33
    New Jersey
    Your Vehicle Year:
    Transfer option in the phone or in the radio? I also have an iPhone 4. I did "transfer" the phone book on the radio is that different than what you ate talkin about??
    Sent from my iPhone using Tapatalk
  10. Offline
    BlackPC2 New Member
    Jul 12, 2012
    35
    Your Vehicle Year:
    I was referring to the transfer option on the radio. I did have to unsync BT then resync then transfer contact list in order for it to work. I will try to replicate the process and give better instructions .
  11. Offline
    BlackPC2 New Member
    Jul 12, 2012
    35
    Your Vehicle Year:
    Go to setup choose phone and then choose transfer histories, worked for me.
  12. Offline
    May 17, 2012
    33
    New Jersey
    Your Vehicle Year:
    Ok great...I will give that a try and let you know if it worked for me. Thanks for the info.
  13. Offline
    brucepmiller Member
    May 31, 2012
    136
    55
    Michigan
    Your Vehicle Year:
    This is how I did it:
Share This Page
