1. Couldn't make it to California for the To Go Before conference? No problem - watch it live here.
  1. Offline
    Start a Conversation
    Dec 29, 2007
    4,111
    264
    Your Vehicle Year:
    i want to control the BMS+ i have using the torque app for android
    the app got a send raw command button
    so you just place a button on your app screen and set a command for it to send when pressed
    until now i have no luck yet getting this to work
    i have send 556 2d d2 00 or 5562dd200 or 2dd200 or 2d d2 00 but no luck
    556(PID for BMS+ where it will take messsage from ) 2d (vallue this case 210 ) d2 00
    i did send out a command and the gear lights on the dashboard stated to flicker so i can send out a raw command to the canbus only its not yet getting to the bms+ or execpted by it..
    anyone with a idear about this..
    edit
    maybe i just need to use 2d or 556 2d and nothing more.
    test it later
  2. Offline
    Dec 29, 2007
    4,111
    264
    Your Vehicle Year:
    interesting to see is that even BMS+/2 mis making sure the realy soc does not get on the canbus and does spoofing a higher SOC when i readout the soc with torque app i still get the real OEM ecu reported soc....
    with the bms+ 3cb and 3cd are stopped by the bms+ from the eom battery ecu but torq uses a 21ce to get the soc ???
Share This Page
