Cost of electricity with plug-in Prius
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by laplante236, Sep 4, 2011.
  1. wjtracy
    wjtracy Senior Member
    11,311
    3,588
    Northern VA (NoVA)
    Keep in mind that, at the moment, electricity is much cheaper than gasoline. At USA average elec rate (~12 cents/kWhr) gasoline costs about 3x (Prius maybe even 4x) more to go the same EV distance. This is not because less energy is being used for EV, but rather because electricity is a cheap energy source right now, compared to gaso. Now then, the Californians here will have to help you re: local costs. You are trading off cheap electricity with an expensive battery.
  2. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    And that's why I think electricity should always be charged using TOU and why I don't like PEVs with AER lower than normal daily usage.
  3. ItsNotAboutTheMoney
    2,287
    460
    Maine
  4. ItsNotAboutTheMoney
    2,287
    460
    Maine
    The LEAF can be set to charge from or charge to a given time.
    I haven't read any mention of a timer. One of its selling points is not needing a special charger. You can get a timer that plugs into a socket easily enough: less than $20 for one that allows you to use a different setting at weekends if off-peak is always off-peak. Of course, it's less convenient than being able to control it remotely.
  5. mitch672
    mitch672 Technology Geek
    1,077
    197
    Randolph, MA
    Its a compromise, some electric range is better than none.
    You can always buy a Leaf, Ford Focus EV, or a Tesla Model S (when those last 2 are eventually availble), of course you give up the range of a PHEV, like the Prius, or Plug in Prius/Volt
    There is no perfect solution yet, unless you can wait until the end of 2012, have $90K+ and get in line for a 300 mile range Tesla Model S.
