Costco Tires?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by dplatnyc, Oct 28, 2010.
  1. dplatnyc
    dplatnyc Junior Member
    16
    Callicoon Center, New York
    Has anyone bought snow tires at Costco? Michelin Ice X2 are $116. I see that if you buy the installation package you get lifetime rotation and balancing and was wondering how this works when you want to go back to the regular tires--I assume they don't do that switch for free.
  2. geeter
    geeter Member
    208
    16
    Chicago
    I think they switch for 5 bucks a tire or something, but it is a one time fee. There is going to be a Bridgestone rebate coming up in November at Costco, with 70 off a set. Blizzaks should be OTD at around 400 bucks.
  3. A_Man
    A_Man Junior Member
    Mississauga, ON, Canada
    I just got the Michelins installed at Costco (in Canada) this weekend. Rotations are free, but for switching tires (assuming you bought new rims, and don't actually need to remount tires on the alloy rims each season), they will charge $6 per tire, and that will include balancing and topping off with nitrogen if required. The service should probably be the same in the US, though the price may differ a bit
  4. chrisj428
    chrisj428 Active Member
    680
    144
    35
    Vernon Hills, IL
    Here's what doesn't make sense -- and, keep in mind, I'm sure this is what CostCo told you, but what they're saying doesn't add up.
    Assuming you have snow tires mounted on separate rims, they're going to charge you CDN$24 to swap out the snow tires with the summer tires, but rotations are free? During a rotation, four tires are removed and four tires are installed, right? Why would they charge you $24 in order to bolt on four different tires?
    Now, if they were going to charge you $24 for mounting/balancing four tires at each seasonal change, that would be a good deal!
  5. Judgeless
    Judgeless Senior Member
    1,821
    255
    Cleveland, OH
    I bet you can get rims and tires for just a little more online. Tirerack is the best.
  6. Mendel Leisk
    38,106
    We just got Bridgestone Ecopia EP20 at Costco, basically replacing our OEM's. In Canada they were having a $70 off on set of 4 promotion, and their price was good to begin with. Their work was good, they didn't damage our rims, nice hidden weights. I kept it simple by removing our center caps before going in. Also retained the old valve stem caps, don't like their green ones.
    They put 32psi of nitrogren in, we drove off and put a further 8psi of regular air in at our favourite gas station ;)
    I think their road hazard warranty could come in handy, but I don't get too excited about tire rotations: I put my own snow tires on/off, have floor jack etc.
