1. Offline
    wld8hrt New Member
    Jan 23, 2010
    Message Count:
    pasadena, ca
    Your Vehicle Year:
    I have a 2010 Prius IV that came with 15" tires. I decided to put 17" wheels and tires on it. Since then my mileage has dropped from an 47-53 avg MPG to 34-37 MPG!
    Can this small change make that big of a difference? The Prius V comes with 17" tires/wheels and has the same MPG rating....
  2. Offline
    Erikon New Member
    Dec 5, 2009
    Message Count:
    641
    79
    Rochester, NY
    Your Vehicle Year:
    Yeeouch! Not a wheel expert myself, but from what I've read here even the best aftermarket 17" wheels and tires will rob you of a few mpg's, part of the price of looking good. If these are heavy wheels and the tires aren't low rolling resistance (LLR) then yeah, it's possible. Also, maybe they weren't balanced properly?
    1 people like this.
  3. Offline
    bwilson4web 03 and 10 Prius
    Message Count:
    7,495
    1,394
    Huntsville AL with 2003 Prius
    Your Vehicle Year:
    First, you need to check the calibration of your tripmeter distance with the new tires. If you have a GPS, set the car on cruise control at a given speed and check against the GPS. Then for good measure, find a road or highway with mile markers. Reset the trip meter as you approach a mile marker and then drive at least 10 miles and record the tripmeter mileage and 10ths of miles as you approach a mile marker.
    I put larger diameter tires on my 14" wheels, a 2003 Prius, and there is a 3% error because it takes fewer rotations per mile. So when I record my mileage, I have to 'adjust' the distance before I enter the record. I also have to drive using an indicated speed 1-2 mph slower to match the posted speed limit.
  4. Offline
    Erikon New Member
    Dec 5, 2009
    Message Count:
    641
    79
    Rochester, NY
    Your Vehicle Year:
    That's true that calibration could be an issue, but shouldn't the diameter of the 17" wheel and tire be the same as the 15"?
  5. Offline
    Message Count:
    7,495
    1,394
    Your Vehicle Year:
    Check the tire specifications at 'Tire Rack' and you'll find there can be as much as a 10% variance in revolutions per mile. A larger diameter, fewer revs per mile, tricks you into driving faster because the speedometer is reading low, the car will be in a higher drag region, compounding the mileage problem. Worse, the indicate MPG will be lower than true.
    I didn't ask about tire width but this also increases the aerodynamic and often rolling drag. Actually rolling drag is a complex function including tire material, tread, and alignment.
    Our Prius is a well tuned car and it is very easy to make what might seem like minor tweaks that send mileage the wrong way. Don't give up hope but just assume you're in 'test and debug.'
    My recommendations:
    • tripmeter calibration - we need to know if you're seeing a lower indicated mph and smaller than actual miles.
    • alignment - this can rapidly result in a permanent increase in rolling drag and worse, higher tire wear. Fortunately, it can be fixed, even rear wheels.
    FYI, I've long thought about getting four 'donut' tires for some stunt driving. The smaller diameter means the indicated speed will read higher than actual and the indicated mileage will be higher too. <GRINS>
  6. Offline
    Aug 14, 2006
    Message Count:
    13,501
    1,865
    Sacramento, CA.
    Your Vehicle Year:
    It is entirely within the realm of reason if you chose a very heavy wheel and put a tire with a very high rolling resistance rating. I regularly see about about 5mpg avg. drop when swapping between my 15" combo and my 17" combo and I have very light wheels with well worn tires. You also have to factor in the new tire effect which will produce lower MPG even if you had kept the tire size and model the same as original. It takes time for tires to break in. Additionally a new tire has more tread so you will see less revs per mile like Bob already stated.
  7. Offline
    32kcolors New Member
    Jul 14, 2009
    Message Count:
    4,515
    536
    Redondo Beach, CA
    Your Vehicle Year:
    1. Are your rims open spoke design? Could make a difference if you normally drive highway speeds due to increased drag. The V's wheels are more aerodynamics than most.
    2. Are your tires low rolling resistance? The V has LLR tires.
    3. What's the weight of your wheel/tire combo? Unsprung weight can make a difference.
  8. Offline
    JimN P719 of ???
    Nov 26, 2006
    Message Count:
    4,487
    229
    South Jersey
    Your Vehicle Year:
    How does the tp in the 15's compare to the 17's? The max sidewall pressure on the stock 17's is 51psi.
  9. Offline
    V8Cobrakid Green Handyman
    Jun 6, 2004
    Message Count:
    3,703
    110
    Your Vehicle Year:
    55psi on mine... i keep them low though.. really low. 55 psi was fun for a while.. i think i'm running almost as low as 30 right now.
    expect mileage to drop.. in my GenII it did.. i'm 36+mpg. i used to be no lower then 42...
  10. Offline
    max2prius New Member
    Dec 19, 2007
    Message Count:
    78
    Walnut Creek, CA
    Your Vehicle Year:
    Ouch! My mileage went from 49 to 43. Scion TC Rims with 215 45 17 Z Rated tires which are probably high rolling resistance. I just recently switched back to stock. It is hard to hypermile with 17's since the car slows down so quickly from the thick rubber. Just like most things both options have their pros and cons.
    John
  11. Offline
    greenmanJon New Member
    Jan 27, 2010
    Message Count:
    Durham, NC
    Your Vehicle Year:
    I am a newb here and I am also a (former) auto tech.
    Looking at this post, I see a few good thoughts about the cause for the mileage drop.
    Most of them (tire pressure, calibration, rolling resistance) woud have an effect on mileage but not 20%.
    I would suspect that the wheels that were installed are causing the brakes to drag.
    This can happen if the brakes rorotrs/drums are being warped because of the engineering of them, or possibly overtightening of the lug nuts, or both.
    Just my thoughts.
    Good luck.
Share This Page
