Cruise Control circuit breaker?
Discussion in 'Gen 3 Prius Technical Discussion' started by Harold Bien, Feb 24, 2010.
  1. Harold Bien
    Harold Bien Member
    113
    39
    Stony Brook, NY
    These reports of sudden unintended acceleration remind me of reports of autopilots gone awry. We are usually taught in such a situation (run-away trim, etc.) to simply pull the circuit breaker to the auto-pilot circuit. Is there such an equivalent in the Prius or general car w/CC? Seems to me the red-herring could be that people are all focusing on the accelerator pedal when in fact the computer, could, on its down, decide to open the throttle without accelerator pedal depression as during CC. Of course, it's supposed to turn off w/the brake application, but what if it doesn't? If there isn't a circuit breaker for the CC circuit, then maybe they should consider putting one in and isolating the circuit, i.e. a simple push-button w/software or hardware watchdog don't be sufficient b/c the likelihood of severe ECU malfuction is high if the CB needs to be pulled - it needs to kill the power to the CC logic which (hopefully) is a separate ECU and can be isolated/powered down.
  2. dogfriend
    7,512
    1,189
    Carmichael, CA
    CC is integrated into the HV ECU and Engine Control ECU. It wouldn't be practical to cut power to the CC separately. You can shut down the hybrid system by holding the Power button for 3 seconds. It is faster and more direct to just select N with the shift control in the event of a runaway CC condition.
  3. Susan4ET
    Susan4ET Member
    429
    53
    Central Oregon
    What's wrong with pulling back on the CC control or pushing in the button on its end to disable the CC if it is runaway?
  4. bwilson4web
    16,113
    This is how the cruise control is implemented in the NHW11:
    The principles of operation:
    • normally the interface to cruise control is open and floats at supply voltage
    • sensor voltage comes from the hybrid vehicle ECU
    • momentary contact changes the resistance and lowers the apparent voltage
    • CRUISE ties the sensor voltage to ground
    If you are seriously interested in the cruise control system, I would recommend getting:
    "2010 Prius Repair Manual, Volume 2" RM1291U2, pp. CC-1 to CC-249
    I bought the manual and page CC-4 shows a similar resistor network and switch configuration. However, the name of control computer is now "Power Management Control ECU."
  5. Harold Bien
    Harold Bien Member
    113
    39
    Stony Brook, NY
    Wow, a single point of failure could disable the entire CC circuit (not sure how feasible that is) but I'm shocked that the cruise enable and disable are all one the same input pin (granted it's a schematic) and differentiated by changing resistance (this is probably an industry standard).
    But I'm most interested, I guess, in "software/firmware" of the Power Management ECM as hardware failures would show up in a subsequent diagnostic. I want to know how they program it to ensure that a single point of failure in the software/firmware cannot cause run-away cars, and how do they ensure that, in the event of a CC malfunction, the brake cancel or the CC cancel switch could still reliably disable CC.
    Once I take delivery of a Prius, I do intend on the subscribing and downloading the TIS. Is the manual you mention the printed version of the relevant TIS?
    Thanks for the info.
  6. bwilson4web
    16,113
    Please describe the failure and scenario that causes it. Be sure to include the "open" state required between different resistance values. Assume that any "open" or resistance state must be at least 500 milliseconds duration.
  7. Harold Bien
    Harold Bien Member
    113
    39
    Stony Brook, NY
    It's been awhile since my EE classes, but if I'm interpreting the schematic correctly, a short to ground on the input pin would effectively enable CC while preventing cancellation (and disabling all further input). I find this odd because I would have thought that the CRUISE input should be always ON/OFF and not a momentary switch, but if this were the case then the circuit should be measuring current and not voltage (because enabling the CRUISE switch and keeping it on would be equivalent to short to ground with subsequent very low voltage on the input pin regardless of how many additional resistors are then placed via switches).
    As I wrote earlier, I do not believe this to be a common/likely scenario, and doubtful if it explains any of the SUA reports as there would be evidence left behind. I'm much more interested in learning how the software/firmware interprets the input pin signal and what safeguards are in place to prevent a catastrophic failure of the cruise control circuit - something I would imagine every manufacturer must design against. This question was specifically asked during the webinar, and I felt it was inadequately answered:
    The speaker did not go into any details (as opposed to the accelerator issue) regarding what redundancies or fail-safes are provided except to comment that there are built-in "limits" on the CC circuit limiting acceleration and that it shares the same fail-safes as the ECM, but does not address whether, for instance, the "many things that will cause [CC] to turn off", are separately addressed and lack a common point of failure enabling at least 2 alternative routes to disable.
    My concern is whether or not there exists redundancies/internal checks to ensure that a single-point failure (more likely software than hardware) can result in abnormal functioning of the CC such that it will engage and refuse to disengage (short of shutting down the entire engine, etc.).
    I'm coming at this from a pilot's perspective where we don't assume everything will work perfectly, and in the case of run-away trim/auto-pilot, the procedure is often disabling of the autopilot by cutting power to it via the circuit breaker.
    I'm mildly surprised to learn that the CC is embedded in the ECM, and therefore would like to know what additional safeguards are in place to prevent run-away situations, and whether or not a system similar to that found on autopilot equipped airplanes might provide a higher level of safety at minimal cost (ignoring the cost of re-design, a one-time large expense).
    While I don't own a Prius (yet), I know (for instance) that the cruise control on my Volkswagen can be set to pretty high speeds (80mph) and that it can, if permitted, accelerate aggressively if one "resumes" at a substantially lower speed perhaps giving one the impression of a SUA incident.
    Again, drawing from my pilot training, as much as I love technology and believe it to help more than hinder us, my programming experience have taught me to maintain a certain level of distrust especially for complex systems and would prefer a fail-safe mechanism for the user to intervene should the system malfunction.
  8. bwilson4web
    16,113
    Ok, now we can start with test scenarios:
    1. constant short - replicated by holding the "CRUISE" switch ON
    2. intermittent short - replicated by holding and releasing "CRUSE"
    3. others? - propose a test scenario, preferably one that can be replicated using the existing switches. Note that all switches are "pass through OPEN" or in digital circuits, or tristate.
    The reason I bring this up is we know that in normal operation, the cruise control goes to "OPEN".
    I notice you don't have a Prius. What is the cruise control circuit or system for your vehicle?
  9. kbeck
    kbeck Active Member
    420
    275
    Metuchen, NJ
    OK. Let's have fun with this. I'm used to microswitches that have that little plastic button that causes a snap/unsnap operation inside the switch. Usually these things are good for a couple of million operations or so.
    However, I've seen some cheapie switches from time to time and actually ran into a good one in an old VW Beetle I had. One of the metal strips became worn, freed up at one end, then rattled around like crazy causing the horn to rattle on and off, becoming louder if the horn button was actually pushed, and finally stopped when I reached under the front bumper and unplugged the horn. Had to take apart the steering wheel (pre-airbag days!) and replace the switch.
    I've also run into relays that, when banged against one side, would make and break contact, causing all sorts of fun. (Better relays with 100G specs before breaking/making contact was that solution.)
    Switches are spring loaded. The switch, itself, might actually have a spring unrelated to the one that moves the stalk back and forth. Suppose the spring breaks or becomes dismounted?
    Every bump you hit might cause a make-break contact on one of the positions of the switch.
    I imagine software could detect a switch that's held permanently down, or a switch that makes a fast, intermittent contact.. But the latter is unlikely a check.
    So, the switch is a possibility.
    Next fun: Vote for bad silicon. There's likely an A/D converter out there that polls for changes in the switch value. Suppose the A/D converter happens to be a bad one and starts having rattling outputs? Or one of the pins isn't soldered down quite right (like, say, the reference pin) and, after enough time for some corrosion to kick in, starts having a significant resistance to reference power? Then, the voltages picked up by the A/D converter might be all over the map or steady at the wrong value.
    Pick another one: Dendrites might be growing because of not-quite-right solder. Let one of those semi-short out between ground and the pin in question.
    Lots of possibilities here. I really don't like this kind of design.
    KBeck.
  10. bwilson4web
    16,113
    So far, we're hearing 'buzz' without specifics:
    • Anyone having a repeatable problem?
    • Anyone have a onetime event?
    • Was it someone else you heard about it from?
    • Never happened?
    We'll start the same process used on the brake pause/sag ... find out who is experiencing it and ask for details.
  11. Harold Bien
    Harold Bien Member
    113
    39
    Stony Brook, NY
    I think you mis-understood my query, in all due respect, Bob. First, mine was more of an academic question as opposed to a reference to real physical conditions. Second, again, I'm much more interested in the software aspect of fail-safes and other internal checks on the cruise control. However, as you have so nicely shown us the schematic for the physical wiring of the CC inputs, I did raise the question of why put all CC inputs, including activation and de-activation, on the very same pin? Now if you tell me that the ECM can ignore CC input when it senses brake pedal press on a separate pin (a likely condition, I would hope), then I would be hard pressed to suggest that a CC fault might cause some of the SUA incidents. However, lacking that knowedge, the best I can do is ask if anyone is familiar with how CC cancel operates, and whether or not everything is dependent on that single input pin to the power management ECM, and if so, is it plausible that a simple short on that input pin would enforce the CC to remain in "ON" mode, attempt to accelerate to set speed, and ignore any additional inputs including cancel CC?
    I don't think we should be doing the testing ourselves unless there is a safe place for it, and there really isn't a need to figure out how the "black box" power management ECM is operating when Toyota's engineers should know the answer to these questions.
    For what it's worth, since you asked, I currently have a Volkswagen Golf, 2001 model, with a Bosch Motronic 7.5(?) ECM, and I do not have the Bentley's repair manual with me at the moment (it's at my parent's house because our family has quite a few VWs and the manual covers quite a few models) nor have I taken a close look at the CC circuit so I do not know the answer to this question. However, I have a manual car so I have no fear that if anything should happen - stuck throttle, stuck pedal, faulty CC, the easy and natural thing for me to do would be to engage the clutch and pop it into neutral without any further ado.
    On an automatic with electronic transmission, I cannot say the same because now I have to trust the very same ECM which may or no may not be the source of a CC malfunction (but inside which the CC circuitry also resides) to perform the "gear" change.
  12. Harold Bien
    Harold Bien Member
    113
    39
    Stony Brook, NY
    I might need a refresher on circuits, but if I remember correctly, in the way the circuit above is setup, there is a sort of "hierarchy" in the positions, in that the switches above each other would "dominate" over lower positioned switches by virtue of their lower overall-resistance, is that correct? If that's the case, I wonder why is "CANCEL" at the bottom indicating that if any of the above 3 switches were to remain engaged, one would not be able to signal a "CANCEL" request to the Power Management ECM, or am I missing something?
    I'm going by the very vague/simple recollections of DC circuits and assuming that the ECM is reading voltage referenced to ground and that the voltage will reflect the lowest resistance path but I could be wrong because I do recall something about Wheatstone bridges, etc., and let's not go through Kirchow's voltage/current laws (oh the headaches!)
  13. bwilson4web
    16,113
    Somehow I had suspected that was the case. But since I have 'skin in the game,' it is not academic exercise but flesh and blood reality. Accuracy become a lot more important when one's own family and self are at risk. Certainly, flying taught me the difference.
    Folks are of course welcome to their opinions but not the facts and data. If you are skeptical of computer controlled, automatic vehicles (even as you read this text on your computer,) you join company with my neighbor. But I don't pay his fuel bills . . . so we're all happy.
    Perhaps you might propose how you might to gather accurate data, facts and data, to quantify your speculations? It is measuring the real world that separates us from the superstitious.
  14. kbeck
    kbeck Active Member
    420
    275
    Metuchen, NJ
    Harold, it's a simple voltage divider. Basic idea: Suppose that there's a 1 kOhm resistor to 5V over at the ECU. The bottom of that resistor goes to an A/D converter so the computer over there can read the voltage. The bottom of that same resistor goes to the top of the chain.
    OK. Label the resistor in the ECU as R1; label the three resistors on the column as R2, R3, and R4.
    When no switch is set: V = 5V. The 1 KOhm resistor at the ECU is at VCC, since no current is flowing through the resistor.
    When Cruise is set: V = 0V. It doesn't matter if any of the other switches are set or not, at this point, Cruise is at ground and no current flows through the other resistors.
    When Cruise is not set, but RES/ACC is set:
    V = R2*5/(R1 + R2). Again, the other switches can be set, but they won't do anything.
    When Cruise and Res/ACC are not set, but Set/Coast is set:
    V = (R2 + R3)*5/(R1 + R2 + R3).
    Finally, when Cancel is set, but none of the rest are,
    V = (R2 + R3 + R4)*5/(R1+R2+R3+R4).
    I would presume that the selection of R1, R2, R3, and R4 would be so there's equal steps between 5V (when none are set) and 0V (when Cruise is set), the better for the A/D converter and software to differentiate between the different switch positions.
    Advantage of this scheme: One wire back to the ECU, two if you include the ground. This may be a big issue, since it's not just the copper - it's the connection through a rotating steering wheel.
    Disadvantages of this scheme: You need an A/D converter, which is inherently more complex and liable to failure than a simple on/off detector. You need software to initialize, read, and hit-time the A/D converter, another possible point of failure. (Although admittedly even a digital on/off signal will need hit timing.) And I, personally, don't like running analog signals around like this. EMI, ESD, etc. Although from the webinar they've tested for this. But still.. Finally, it depends upon how the contacts work in that rotating hub. Any additional resistance gets into the chain and offsets the voltage.. But only when a switch is pressed.
    Hmm.. Had a VW Beetle once. A couple of points of metal on the steering wheel itself were connected to the horn button; those points of metal then made contact with a concentric ring that was stationary on the steering column. The ring wore through, broke free, and then made contact with ground, and the horn sounded until I managed to pull a wire off said horn. That was back in '74 or so on a car with ~100,000 miles. I hope Toyota uses a more reliable method these days.
    KBeck.
  15. Harold Bien
    Harold Bien Member
    113
    39
    Stony Brook, NY
    Again, I think you are somehow mis-interpreting my queries. As a pilot of all people, you should be familiar with "trust but verify" approach, and while I'm skeptical of complex systems working perfectly all the time, I'm often the one requesting further automation/technological advances [I'm interested in the Prius soley for the PCS system, not for its hybrid drive, which is just a plus].
    I'm not speculating on any specific event(s), real or alleged, but am posing an academic question of "what-if". You are asking me to demonstrate a particular scenario in the real world - a request I cannot comply. My quest is to determine if a particular scenario is possible, no matter how remote the possibility. The poll you requested is unlikely to yield answers especially for low-probability events, but fail-safes are intended specifically for those unexpected, low-probability scenarios.
    The CC circuit you so generously posted makes me ask the "what-if" question. It's clearly different from the Bosch Motronic ME7.5 on my Volkswagen which has a regular switch (not momentary) that enables/disables cruise control - this type of design I suspect is more robust against wiring/HW problems where a simple toggle of the switch should (again this is all pure speculation as I do not have access to the technical documents of the CC module in the VW, but I do know from reading various forums that the CC module is integrated into the ECM - new for ME7.5 I believe) disable the CC not all that different from "pulling a circuit breaker" to disable it as it's an independent signal (again, so far as I can tell - I could be wrong).
    In the circuit you showed for the Prius (and likely all Toyota's/Lexus), it's confusing to me why the system would be designed for:
    1) Momentary activation of CRUISE request, and
    2) Positioning of the voltage divider circuit (thanks KBeck) such that failures in the switches above CANCEL can then over-ride the CANCEL request?
    As I suspected and I believe KBeck has confirmed, if there is a short of either "CRUISE" or "RES/ACC" switch, then the system will receive as input only the signal to turn ON the CC or (perhaps worse) increase CC setpoint (ACC) even when off (RES) and cannot in such a condition, receive a "CANCEL" signal. Such a setup is inherently dangerous, in my opinion, and would result in a "sudden, unintended acceleration" not unlike Steve Wozniak's situation (except in that case it was user error). Again, I would like to point out that I do not believe hardware malfunction of the CC system is likely to be the culprit in SUA incidents as they should leave behind a trace of their failure. Much more plausible, for me, is a software issue, and hence my quest to identify the software designed fail-safes for CC malfunction, i.e. is there some sort of supervisory circuit that monitors the CC engine request/output and ensures that it makes sense?
    However, again, as I posted earlier, I'm pretty confident that Toyota engineers most likely foresaw this and I'm sure that the CC cancel input can come in from additional sources not documented on the schematic shown, for instance, the brake pedal signal is hopefully a separate pin input into the ECM which should, hopefully, over-ride any CC request or RES/ACC input.
    As an aside, I have really appreciated reading your posts and your technical insights - and you are certainly one willing to go out to perform testing to verify your hypotheses. However, in this particular situation, given the likely rarity of the scenario, I think the answer is best sought from Toyota engineers who wrote the code/engineered the power management ECM.
  16. dogfriend
    7,512
    1,189
    Carmichael, CA
    Some Gen 2 CC info:
    [​IMG][​IMG]
    [​IMG][​IMG]
  17. kevinwhite
    kevinwhite Active Member
    333
    200
    Los Gatos Ca
    Don't forget that even if the switch does fail (or even break off!) the independent switch on the brake pedal will cancel the cruise control.
    kevin
  18. dogfriend
    7,512
    1,189
    Carmichael, CA
    You can also disable CC by shifting to any other mode except D, i.e. you could shift to N or B
  19. bwilson4web
    16,113
    So this evening, I drove to the lab and checked the cruise control states. The CRUISE switch, jumper to ground, is the ON/OFF are on the end of the stalk. The other switches move to open in all cases before another can be engaged. Even if the stalk is held in RES/ACC state, pressing OFF on the end of the stalk grounds the resistor stack and turns off the cruise control.
    To reach ACCELERATE state:
    1. The CRUISE must be turned on, tied to ground, with all other switches off and cruise control already OFF. It is a toggle.
    2. The SET/COAST must be engaged mechanically.
    3. Then RES/ACC can be engaged and the car goes faster.
    RES/ACC requires SET/COAST before it can have an effect. The hypothetical bridge-jump must achieve three distinct resistance values and somehow block the "CRUISE", jumper to ground, that would turn it off.
    "Crap in the gap" of the "CRUISE" switch might be able to play the sequence of values needed to: turn on cruise control, set cruise control and enable accelerate. I would not recommend spilling a beverage over the cruise control stalk (aka., the Homer Simpson defense.)
    A second hypothesis, a broken wire between the Power Controller and switch might also 'play the tune' if vibration could chafe the wire against a ground. In such cases, it would be an intermittent and sometimes exciting ride as the stalk wire would likely be isolated and have no ability to short to ground. However, moving the shifter to "N" or pressing the brake would be quite effective. It is one reason why wiring harness damage should be treated as a critical safety element.
    But this is idle speculation unless we can find someone who is having a problem with their cruise control. If the vehicle has a salvage title or history of an accident repair, all bets are off.
  20. Harold Bien
    Harold Bien Member
    113
    39
    Stony Brook, NY
    I really doubt one would find such a hardware fault, at least within a reasonable number of car samples given the low probability. But this all goes to my original question:
    Should there be some sort of malfunction in the CC "logic" (not the hardware), what fail-safes are in play to prevent "run-away" car? This was the very same question posed during the webinar and the answers were vague.
    I understand that the "Stop light switch" or "Transmission switch" should disable CC, but my question is: who's checking these "cancel" requests? The CC unit itself, or some other supervisory circuit (I hope)? If the CC unit gets in some weird software loop and cannot respond to the cancel requests, does the Power Management ECM disable the CC when the cancel request comes in (possibly through an alternate source like stop light switch)?
    My original question and simple concern is that if all CC-related inputs go only through the CC unit, then that would be concerning. I highly doubt this is the case, and am glad to see that on the Gen2 wiring diagram it's clear the Stop Light switch is a separate pin on the ECM (who knows how the logical units are setup, but I'll bet the Toyota engineers are no dummies and have already accounted for this).
    All these speculations could be avoided if during the webinar they gave us more concrete examples of safe-guards just as much as they did focusing on the accelerator pedal (which I've felt all along may be a red herring and in any case would be very difficult to differentiate from manual (user) error - perhaps why the lawyers focus on it so much and Toyota must defend against it so rigorously).
    In the current design scheme, I don't think it's always clear what a short to ground would do on the CC switch. If CC were already enabled, it would probably disable it (assuming the logic were to switch on a HIGH->LOW transition), on the other hand, if CC were OFF then it would turn it on (again, assuming HIGH->LOW transition) but presumably NOT cause the car to accelerate or even try to maintain set speed (that takes 2 actions I'm guessing: CC ON, then SET or RES). In that manner, I feel the hw is pretty well safe-guarded against problems, and my guess is the the CC logic is so deeply embedded in the Power Man ECM that it would be impossible to isolate it and shut it down - so there goes my theory of a CC circuit breaker.
    [Just re-read your earlier post more carefully - you're saying it would take three steps: ON, SET, then RES/ACC. Intersting - in my VW w/Motronic ME7.5, you can simply hit "RES" and it would resume at last set speed (v dangerous I think, esp. if you don't recall what that last SET speed was) even after vehicle is OFF. I like the Prius mode better.]
    Gotta say though, I wonder what pilot would feel ok flying an airplane equipped with the simplest 3-axis autopilot that DOESN'T have a circuit breaker to disable the AP/trim?
