cruise control in prius 1
Discussion in 'Prius c Accessories and Modifications' started by outhouse, Mar 30, 2012.
  1. outhouse
    outhouse Member
    125
    35
    auburn ca
    OK folks im starting thi smod, and i'll let you know how it goes.
    purchased CC switch 84632-08021 from ebay with teh connecting wire for $64.99. it should be here any day.
    this should be a 20 minute job tops anyone can do. I'm almost certain everything is pre-wired and all thats missing is the switch.
    a how to do and photos coming soon.
  2. SquallLHeart
    SquallLHeart The Techie Guy
    825
    234
    San Jose, CA
    afaik, there's no pre-wiring..
    so.. if you do get it to work.. please prove me wrong.
  3. outhouse
    outhouse Member
    125
    35
    auburn ca
    well installed the switch and the steering wheel is pre-wired for the switch.
    but no go as far as it working.
    sent a email to the guy selling switches on ebay, im hoping for a wiring diagram that will show where I need to make the connection from the steering column to the ECM
  4. Breogam
    Breogam Junior Member
    Chicago
    Any word whether you've gotten it to work? I've made a couple of long distance road trips on my C 1, and now realize really need to get Cruise on this thing before I go cross-country this summer
  5. outhouse
    outhouse Member
    125
    35
    auburn ca
    I talked to a tech here at work, he said it should be pre-wired and may be missing a fuse.
    There is no fuse listed as CC so ill take pictures from a #2 fuse panel and see if there is a difference.
    im also going to check the wiring from the switch to the steering wheel and make sure I have the right one.
    One has a ground, mine does not. I need to see what the #2 has installed.
  6. outhouse
    outhouse Member
    125
    35
    auburn ca
    you know this how??
  7. SquallLHeart
    825
    234
    San Jose, CA
  8. outhouse
    outhouse Member
    125
    35
    auburn ca
    thanks for the heads up
  9. SquallLHeart
    825
    234
    San Jose, CA
    if it was to be my best guess.. anything that's critically missing... is inside the ECU itself... i mean.. if you got the controls and all the wires are connected correctly to the ECU... and the ECU isn't responding...
    then.. yea.. that's the only thing i can think of that's left.
  10. F8L
    19,149
    4,038
    50
    Sacramento, CA.
    2013 Chevy Volt
    I have to bring my car in for it's 5,000 mile service next week. Maybe I'll see you there. Do you work in ther service dept?
  11. SquallLHeart
    825
    234
    San Jose, CA
    down in Stevens Creek? I work mostly detailing cars and stuff.. however have had a long connection to their service and parts dept... and am very familiar with working on vehicles. :p
  12. F8L
    19,149
    4,038
    50
    Sacramento, CA.
    2013 Chevy Volt
    Magnussen's Auburn. :p
  13. SquallLHeart
    825
    234
    San Jose, CA
    oh.. talking to the other person.. lol.. oops! my mistake :p
  14. outhouse
    outhouse Member
    125
    35
    auburn ca
    Na im in sales.
    Im the only John here LOL
    stop in Ill buy you a cup of coffee
  15. cadillackid
    cadillackid New Member
    Columbus Ohio
    old thread but if you didnt already get your CC working normally you have to scan it into service as in many cars the hardware is there but the computer has to be flashed to recognize it has CC.. this is so the computer doesnt fault at the lack of the switch being there...
    -Christopher
  16. outhouse
    outhouse Member
    125
    35
    auburn ca
    thanks ill have them look into it.
  17. KartBoy
    KartBoy New Member
    I know this is old, but it is very good information. Outhouse, what ever came of this? The wife and I just bought a brand new Prius C1 after being told that cruise control can be added. Did you ever get it to work?
  18. CAlbertson
    CAlbertson Member
    99
    24
    What's left? Software. I'd bet the computer simply does not look at the CC inputs on the PC1. I've worked as a software developer for many years (decades really) I've never worked on automotive firmware but have done a few things that fly. I bet the PC1 firmware lacks the CC logic
  19. outhouse
    outhouse Member
    125
    35
    auburn ca
    its possible about the firmware
    one of the techs here said they might be able to switch it on in the ECM from their side of things. But he was vague and had never attempted this.
    So still at a loss
    Not sure if there is even a different part # for the ECM's from a 1 to a 4
    O was told a fuse may be missing, but that was incorrect, all C's have the same exact fuses
  20. CAlbertson
    CAlbertson Member
    99
    24
    Likely that the ECM boots up then looks to see what trim level the car has and then enables features based on trim level. This would allow Toyota to keep just one P/N. Also by checking the trim level the computer would not light up a service light for a failed component that is not present on that trim level.
