Cruise on C One base
Discussion in 'Prius c Accessories and Modifications' started by Ecobill, Jul 29, 2014.
  1. Ecobill
    Ecobill Junior Member
    94
    Berea OH
    2014 Prius c
    What do I need and will it work. At this point just considering OEM parts.
  2. tk1971
    tk1971 Active Member
    253
    133
    SG Valley, CA
    Read and study this:
    http://www.rostra.com/manuals/250-1836_Form5350.pdf
    Then, just get the OEM stalk, wiring and connectors to hook it up.
    I've seen the Rostra kits for less than $150 shipped from ebay. Doesn't look bad, since all wiring and connectors are included.
  3. Ecobill
    94
    Berea OH
    2014 Prius c
    Thanks, I can get the OEM stalk with a wire for $57., this would be for the 2014 Prius C One base. It just seems too simple and that I would be missing something.
  4. tk1971
    253
    133
    SG Valley, CA
    The key is that you will need to wire up connections to the ecu. The connectors required are probably hard to get. Looks like an easy mod though... just a little bit of homework getting the connectors and pins for the connectors.
  5. Delta Flyer II
    Delta Flyer II Active Member
    547
    248
    69
    A few people on here have done it already…. When I can afford it I'm going to add it to mine…. Already added mud guards and center armrest. So half way to a C2 lol (y)
  6. Ecobill
    94
    Berea OH
    2014 Prius c
    Where did you get mudguards? Anyone have muffler tips?
  7. Delta Flyer II
    547
    248
    69
    Here is the thread and my install…. there are also pics here….
    Mudguards for the C? | Page 2 | PriusChat
    As for tips, I'm debating getting one on my C too but am unwilling to pay the prices I have been seeing… The lift back tip is tucked further in so its pointless IMO but I hate the way the C sticks out the back it needs something…
    Hope this helps...
  8. PeterHaas
    PeterHaas Member
    152
    29
    Monterey Bay, CA
    What you receive in a generic Rostra Toyota automatic kit is the control with its connecting cable (which is to be modified before installing it into a c) and a baggie with four different colored wires with pre-crimped connectors, only two of which are applicable to the c.
    The connectors are impossible to get otherwise, and that fact apparently justifies the difference between the $35 for the control and the $135 to $200 for the complete kit..
    So, taking the $200 high price and subtracting the $35 for the control, and you have $165 for the four pre-terminated wires which are supplied in the harness baggie, and that's $41.25 per wire, which is highway robbery in my book.
    The beauty of the c installation is most of the hardware is already in the ECU, so all that needs to be done is to install the control and the two wires which connect to the ECU.
