1. Offline
    mgb4tim Noob
    Jul 8, 2009
    Message Count:
    1,002
    74
    Pittsburgh, PA
    Your Vehicle Year:
    Back in the mid/late 60's, some MGBs had aluminum hoods. Sure, they were lightweight, but they didn't like to be taken out of the garage.
    Good for me, since I make fiberglass reproductions, but bad for those who have to buy them.
    Fast forward 40+ years... who's idea was it to put aluminum hoods on the Prius???? Did anyone do their homework?
    I've found my second mini dent/chip on my hood this week. I could understand it if I heard something hit the hood, but I had no reason to suspect a dent! It would be different if it were just a chip, but a dent?!?
    Looks like I might be making a carbon fiber or fiberglass hood after all. But I'll have to fill the dents with clay to make the mold.
    Grrrrrrrr.
  2. Offline
    PaulHS New Member
    Feb 6, 2008
    Message Count:
    192
    SE PA
    Your Vehicle Year:
    Wow! That takes me back. I owned a couple MGTD's, a 1954 and a 1955. I wish I'd had access to fiberglass hoods and fenders for them. The original fenders were made of heavy gauge steel, like tanks, but when there was a fender-bender, they were almost impossible to reshape.
    Sounds like you may have a winning business idea!
  3. Offline
    ALS New Member
    Jul 15, 2009
    Message Count:
    336
    57
    Pittsburgh
    Your Vehicle Year:
    I have an aluminum hood on my 97 Volvo 960 with 110K miles on the clock and I'm having no problems with it. :confused:
    I keep hearing the Prius has an aluminum hood. It was a real surprise to me since it weighs so much. :rolleyes:
  4. Offline
    mgb4tim Noob
    Jul 8, 2009
    Message Count:
    1,002
    74
    Pittsburgh, PA
    Your Vehicle Year:
    I think it's the angle of the hood that catches everything. I'm gonna guess that the volvo hood is a bit thicker than the Pruis.
    I'm thinking some sound deadening material on the back, if it's accessible, could help.
    I'm also thinking a carbon fiber hood on my silver car might look sharp.
  5. Offline
    cossie1600 New Member
    Jul 25, 2009
    Message Count:
    806
    71
    CT
    Your Vehicle Year:
    Aluminum hood saves 15-20lbs easily, why not? It is also stronger than steel, resist rust. The hood is also higher than the engine, you want as little weight as possible up top
  6. Offline
    mgb4tim Noob
    Jul 8, 2009
    Message Count:
    1,002
    74
    Pittsburgh, PA
    Your Vehicle Year:
    there's no was that small hood save 15-20 pounds. A steel MGB hood weighs 27 pounds and it's a good bit bigger.
    How is the aluminum hood stronger?
    I would venture to say they are more costly, as well.
  7. Online
    qbee42 My other car is a boat
    Mar 2, 2006
    Message Count:
    17,752
    2,804
    Northern Michigan
    Your Vehicle Year:
    I would take an entire aluminum body if the price was right.
    Tom
  8. Offline
    mikepaul New Member
    Dec 2, 2003
    Message Count:
    1,764
    Columbia, SC
    Your Vehicle Year:
    More malleable than steel seems to be the issue here. A steel hood would probably spring back from hits that the current hood can't...
    1 people like this.
  9. Offline
    mgb4tim Noob
    Jul 8, 2009
    Message Count:
    1,002
    74
    Pittsburgh, PA
    Your Vehicle Year:
    try a land rover defender...LOL
  10. Offline
    Jul 25, 2009
    Message Count:
    806
    71
    CT
    Your Vehicle Year:
    Your MGB also came from the 50s, where they haven't figured out how to build a safe or a reliable car. The chassis on that thing is softer than a piece of noodle, jack up one side and try to open the door if you don't believe me.
    RX-7 was one of the few cars I know that came with the option of steel or aluminum hood from the factory, the difference was over 20lbs on that vehicle.
    I don't know the exact grade of aluminum or steel Toyota uses, but I am pretty confident that they would pick a piece of aluminum that is strong enough to be part of the front end of a vehicle......
  11. Offline
    Jul 25, 2009
    Message Count:
    806
    71
    CT
    Your Vehicle Year:
    The car would also be 15-20lbs heavier, it would handle even worse. I would admit that aluminum does cost more.
  12. Offline
    Jim Calvert New Member
    Jul 30, 2009
    Message Count:
    256
    28
    Worthington, Ohio
    Your Vehicle Year:
    Aluminum is mixed with other metals to produce a variety of aluminum alloys, and these alloys are subsequently given a spectrum of heat strengths. So just because the Prius hood is made of an aluminum alloy does not necessarily mean it is more prone to denting than some other material. For decades aircraft structure and aircraft skin have been made from aluminum alloys - quite successfully.
    As for my 2010 Prius - no dents so far.
    Jim
  13. Offline
    mgb4tim Noob
    Jul 8, 2009
    Message Count:
    1,002
    74
    Pittsburgh, PA
    Your Vehicle Year:
    Softer than a noodle? Check this out - http://www.tgnagy.com/mgb/images/200007/spit1.jpg (from http://www.tgnagy.com/mgb/progressPages/199912.CFM)- mounted on the bumper supports (still there today as I havn'et been able to work on it lately) that are part of the unibody chassis.
    Sure, all the MGB's rusted at the thought of water, but that's imported Russian steel for you.
  14. Offline
    mgb4tim Noob
    Jul 8, 2009
    Message Count:
    1,002
    74
    Pittsburgh, PA
    Your Vehicle Year:
    I realize that aircraft use aluminum skins. I'm just making the statement that I've not had a car hood dent so easily. I've seen paint chips from. highway rocks, but they've never dented like this. Especially when I didn't even notice the rock hitting. You'd think that a rock that hits like that would startle you, like when they hit a windshield.
    My intent is - if you are on the fence about the clear plastic bumper and hood protection, get it.
  15. Offline
    Jul 25, 2009
    Message Count:
    806
    71
    CT
    Your Vehicle Year:
    that's right. so stiff that most of them are totalled. there is a reason why miata are great sports and race cars and why mgs aren't
  16. Offline
    HI MPG New Member
    Aug 25, 2009
    Message Count:
    758
    115
    Orange County, CA
    Your Vehicle Year:
    I've actually contacted a few of the import tuners in the Southern Cal area to see if they make a CF hood for the new Prius. I guess my initial reason for it would be lighten the car (although the weight savings would be barely substanital), but then my ulitmate reason would be to have a something that looks different. I have a winter grey metallic with the solar panels, so the look of a black carbon fiber hood might match the blackened glass and solar panels... Too bad none of them have contacted me back.
  17. Offline
    john1701a New Member
    Jan 6, 2004
    Message Count:
    5,511
    968
    Your Vehicle Year:
    118,185 miles of driving my 2004 makes me wonder about cause. Since all I had was a bunch of tiny pits from all the winter sand & salt, I'd suspect a non-driving event.
    For me, the color of aluminum & silver paint makes the tiny chips pretty much impossible unless you're standing on top of them. No rust bleed or steel flaking to ever wonder about (a big deal here in Minnesota) sure is nice. The reduced weight is obviously a perk too.
  18. Offline
    a64pilot New Member
    Aug 3, 2008
    Message Count:
    771
    56
    Albany Ga.
    Your Vehicle Year:
    All Miata's have aluminum hoods. Doesn't seem to be a problem there. I assume the angle of the Prius hood as well as aluminum being softer metal combine to be a problem.
  19. Offline
    mgb4tim Noob
    Jul 8, 2009
    Message Count:
    1,002
    74
    Pittsburgh, PA
    Your Vehicle Year:
    Are you serious? Nothing like a few decades of technological advance to give the Miata a bit of an advantage? Have you ever ridden in a sport tuned MGB? Have you ever driven a tuned MGB? They are a heck of a good time. Sure a Miata will outrun your average MGB, but it would outrun a Mustang of the vintage same era.
    I didn't think I'd have to defend my second child here, I'm just miffed at the hood of my car that has 2 dents within 3 months of ownership. I had my Caddy with a dent-free steel hood for 146k miles.
    Just trying to grieve a little. Thanks for the shoulder to cry on;).
  20. Offline
    cairo94507 New Member
    Dec 24, 2004
    Message Count:
    884
    San Ramon Valley, CA, USA
    Your Vehicle Year:
    My NSX was all aluminum and never had a problem with dents.
Share This Page
