dash noise
Discussion in 'Prius c Main Forum' started by Singingdriver, Apr 14, 2014.
  1. minor rattle/vibration
    81.3%
  2. constant rattle/vibration
    31.3%
Multiple votes are allowed.
  1. Singingdriver
    Singingdriver New Member
    2014 Prius c
    I'm on the fence about purchasing a prius c, the only factor being that i read some other posts stating a common problem with rattle noise coming from the dashboard. I have a problem with rattle noises....can't ignore it! Especially in a new car. What's the buzz on this folks?
  2. DKTVAV
    DKTVAV Active Member
    510
    101
    Whaaatt? I can't hear you, let me turn down my music.
    Problem solved.
  3. ewaboy
    ewaboy Active Member
    693
    205
    Hawaii
    None.
    YMMV
  4. Brad K
    Brad K Member
    168
    53
    I got no rattle
    Singingdriver likes this.
  5. citroenjohn
    citroenjohn Active Member
    139
    103
    Mid-Michigan
  6. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    Same here, after two years.
  7. Ashley7
    Ashley7 Active Member
    545
    222
    Oregon
    2019 Prius
    I've got lots (maybe from the first year living in an apartment with brutal speed bumps?). Dealer improved it a little bit at my first maintenance appointment, but I generally have music loud enough that I don't notice it. I pretty much expected it with the cheap plastic interior.
  8. coyote303
    coyote303 Member
    112
    64
    Colorado
    I do have a slight rattle that has developed after 6,000 miles. I don't hear it if I'm playing music, so I'm not sure if it's consistent or not.
  9. Mark323
    Mark323 Junior Member
    69
    Not a peep from mine... I'm not sure where you store your marbles though.
  10. ewaboy
    693
    205
    Hawaii
    You talking 'bout me?!:D
    Actually - you may be on to something - my '97 Prizm rattles like you wouldn't believe.
    Some stuff is loose but I think some small change or screws or something fell into the dash vents years ago.
    I don't think I lost my marbles in the car.:)
    Now it shakes, rattles and buzzes.:(
    YMMV
    Mark323 likes this.
  11. Phil 29 Palms CA
    119
    44
    Twentynine Palms, CA.
    I can solve your dash board rattle problem! Put about 2 tablespoons of ARMORALL in a dish. Open the Prinus C dash board door. With your finger, dip it into the dish and then start coating the inside door lip where it comes into contact with the dash with the ARMORALL. Also, coat the area of the dash where it comes in contact with the door when the door is closed. IMPORTANT - after the door and dash serfaces are coated with a film of ARMORALL solution do not wipe any excess solution from the panels. Let the ARMORALL film dry on the door and dash before closing the door. The thicker the layer of film the better. After a few hours close the door. The ARMORALL acts as a lubercator and stops sounds forming between the two surfaces... This solved my door noise problem. Hope it works for you...
    koipond and ewaboy like this.
  12. los panda
    los panda Member
    155
    23
    i get a slight rattle from my glove box, possibly another area near the windshield, but it's nothing major.
    music at a low/moderate level overpowers any dash noise.
  13. bitch ima prius c
    bitch ima prius c Junior Member
    29
    LA ish
    right, so I wasn't sure if I had a dash rattle or not, because usually the radio is on...but I drove for the past 3 days with no music and I am glad to report, no rattle.
  14. tzx4
    tzx4 Active Member
    164
    148
    I had a persistent soft rattle that sounded like it was coming from the dash area. Looked there, pulled the glove box off, taped a wire, and padded where the glove box meets the dash board, padded my right hand mud flap, all to no good effect. Just a few days ago I pushed the shotgun seat forward and reclined the seat back all the way, and VOILA!.
    The next day looked under the seat. There are three electrical connectors that control the airbag and sensor. They are surprisingly rickety by design. double side taping a 1.5 inch foam pad on top of them between them and the seat bottom did the trick. I LOVE conquering rattles.
    This same commentary is going on its own thread here too . . .
  15. garyyamane
    garyyamane Junior Member
    50
    Taos, NM
    I have a soft rattle around the overhead lights - sounds like loose wiring.
    Nexus 7 ?
  16. orenji
    orenji Senior Member
    5,884
    3,486
    I hate cars that have rattles. My car had a slight rattle in the dash when new, but went away. I think some of the plastic dash parts have to settle in. Also outside temp plays a part in the amount of rattles. Hot days no rattles. Cold mornings more likely to have rattles. But over all not anything to annoy me when driving.
  17. minkus
    minkus Active Member
    369
    125
    Cleveland, OH
    There's a Toyota Safety Bulletin (or something official like that) out about that dash noise for some models. I think it's only the earlier ones. Regardless, the fixes mentioned here should work for anything that pops up. I've noticed a slight rattle a few times, but that's probably in fairly weather-specific conditions, and it seems to have gone away over time.
