1. Offline
    Soylent New Member
    May 2, 2006
    Message Count:
    346
    Miami Beach, Florida
    Your Vehicle Year:
    I just heard this at a Toyota dealer. Fact or Fiction?
    He also said the 2010 goes on sale in March.
  2. Offline
    qbee42 My other car is a boat
    Mar 2, 2006
    Message Count:
    17,752
    2,804
    Northern Michigan
    Your Vehicle Year:
    The head of Toyota USA and the Prius Chief Engineer stated that the Gen III Prius will use the same battery as the Gen II. The battery has been repackaged, and they are getting a little more power out of it, but it is still NiMH.
    Tom
  3. Offline
    bestmapman "Dream" Prius
    Apr 8, 2007
    Message Count:
    1,107
    127
    Kentucky near Cincinnati, OH
    Your Vehicle Year:
    Looks like the first one to dealers in middle May or early June.
  4. Offline
    Soylent New Member
    May 2, 2006
    Message Count:
    346
    Your Vehicle Year:
    Well, if people knew lithium was going to come out in November, nobody would buy a Prius until then. So Toyota wouldn't make that public information. So... who knows?
  5. Offline
    Soylent New Member
    May 2, 2006
    Message Count:
    346
    Your Vehicle Year:
  6. Offline
    Mar 2, 2006
    Message Count:
    17,752
    2,804
    Northern Michigan
    Your Vehicle Year:
  7. Offline
    JSH New Member
    Jan 23, 2007
    Message Count:
    2,543
    109
    The Heart of Dixie
    Your Vehicle Year:
    The plug-in Lithium Prius are for fleet sales only. It is part of Toyota's research into PHEV's. If I remember correctly they are building 500 worldwide.
  8. Offline
    Jan 17, 2006
    Message Count:
    6,034
    345
    Northern CA
    Your Vehicle Year:
    Yup. About 150 should come to the US. They will NOT be on the retail market until... well, nobody knows.
  9. Offline
    • Admin/Founder
    Danny Admin/Founder
    Nov 24, 2003
    Message Count:
    6,064
    821
    Charlotte, NC
    Your Vehicle Year:
    Even when the Plug-In is available, the plan is to offer the Lithium Ion battery in the plug-in and keep the NiMH in the standard Prius. There was a strong hint that by the time they would replace the NiMH with the Lithium Ion battery they would be ready to launch an even more advanced technology.
  10. Offline
    mitch672 Technology Geek
    Mar 10, 2004
    Message Count:
    885
    145
    Randolph, MA
    Your Vehicle Year:
    sure they will Danny, by 2015 we will all have onboard fission power plants (remember "back to the future", 'mr. fusion'?) :) only j/k
    I do wish they moved along a little faster though
    Mitch
  11. Offline
    miscrms Plug Envious Member
    Aug 21, 2007
    Message Count:
    1,436
    201
    Phoenix, AZ
    Your Vehicle Year:
    That doesn't surprise me much. There is very little advantage to Li-ion over NimH in a standard hybrid. Panasonic EVs NimH cells are pretty impressive. They put out a lot more Amps per Amp hour than most Li-ion would survive. We know output can be over 100A on full acceleration, from a 6.5Ah battery. Thats a routine 15C+ discharge! Many Li-ion are happiest around 3C, some can do 10C for short bursts. Li-ion will cut weight per Wh in half, but as the Prius battery modules only weigh ~60lbs, that wouldn't buy much of anything. Makes it hard to justify the 2x cost increase. You could also double the battery capacity for the same weight, but now you've 4x'd the cost, and the effect on mileage will probably still be negligible. The DOE ran a first gen Prius to 160k miles and found that even though its older style batteries were down to almost 50% capacity, there was no noticible impact on mileage. Similarly early gen2 hackers figured out how to put a second stock pack in a Prius, doubling the battery capacity and also got almost no improvement in mileage. The mileage performance of a standard HEV is just not that strong a function of battery size provided the battery capacity is much greater than the amount of energy stored/released in a standard deceleration/acceleration event, which in the prius case it is.
    I know most folks on here know this, as its been discussed a lot, but I think it bears repeating from time to time as there is a common public perception that Li-ion is vastly superior in all things and some kind of magic answer to all our problems. Li-ion becomes much more important for PHEVs, as battery size and weight becomes more of an issue. Larger NimH are also not available due to the Cobasys patent coverage, and building a PHEV pack out of smaller NimH cells get prohibitively expensive and complicated.
    Rob
  12. Offline
    Fibb222 New Member
    Apr 25, 2006
    Message Count:
    1,499
    97
    Your Vehicle Year:
    Rechargable Zinc-Air if I'm not mistaken...
  13. Offline
    Jan 17, 2006
    Message Count:
    6,034
    345
    Northern CA
    Your Vehicle Year:
    That's what I'm talkin' about.
  14. Offline
    • Moderator
    Message Count:
    27,008
    1,175
    Your Vehicle Year:
    Sounds good to me but I'd like to get a Prius before it becomes as expensive as a Lexus =P
Share This Page
