Dealership Maintenance Questions
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by mr_yellow, Nov 25, 2015.
  1. mr_yellow
    mr_yellow Junior Member
    66
    Technology
    Hey guys,
    So I reluctantly took my 2010 Prius to the dealership to get an Oilchange cause I've been too busy with two kids to research and do it myself (I do maintenance on my subaru where i can). I get upsold on one of their maintenance packages where the brake fluid is going to get replaced and yadda yadda, various things will be checked. The car only has ~70,000 km's and was last serviced 2 years ago when I bought the car used and all the fluids were changed then. I'm too tired to argue and without looking at the maintenance schedule, I go for it. but I suspect the brake fluid does NOT need to be changed in only 2 years. anyways,
    Now they're saying the rear rotors need to be changed, the rear pads replaced, and the front rotors machined. I have not noticed any warping or vibration or noise during braking so this is a surprise to me. They also say I should get an alignment and an injector flush as well.
    So a simple oilchange ballooned into a $1500+ service change. Yay Stealerships.
    the kicker? they want me to buy a new set of lug nuts cause I'm getting them to mount my winters on and the stock prius lugs (with the washer) "don't fit properly". which is hogwash because I checked here people have said the stock lugs are fine with steelies.
    anyways, I'm just ranting now...
    Am I being taken for a ride here? I haven't had to deal with dealership mechanics in a long time so my spidey sense is going nuts here...
    Thanks
  2. Stevewoods
    Stevewoods Senior Member
    659
    1,135
    Seattle, WA
    Art's Automotive has a 30K recommended services page for Prius, but it's Gen II. They recommend brake fluid and transaxle at 30K. Of course, you are at about 44K and if those things were done a couple of years ago, which was probably around 30K, you probably answered your own question.
    Art's also says something about pads on Prius' brakes lasting into the 100,000 mile range....
  3. JC91006
    16,769
    8,567
    Stealerships prey on the weak. Unless you notice an issue with your car, why would you throw $1500 at a perfectly running car? Your owners manual will list what you need to do and there's nothing but oil changes that's needed.
  4. Mendel Leisk
    41,473
    There's a fair amount of truth in what they're saying. I'll deal with a few of the points:
    1. Your stock lug nuts will look kinda silly on steel rims, oversized and with loose washers. They're primarily meant to grip with the washer along their length. They have the correct tapered seat at the end, but primarily so it can be used with the temporary spare. I'd splurge for the $20~30 for utilitarian galvanized nuts for the snows, keeps the stock nuts off the car during winter.
    2. Toyota Canada now recommends a brake fluid change every 3 years or 48,000 kilometers. This is inline with other manufacturers that have recommended similar, for decades. You say all the fluids were changed two years back: did that include the brake fluid? If so you're ok for some time, but I'd verify that: they've just recently changed policy.
    3. There may well be an issue with the rear brakes. They're a design with incorporated parking brake, and if anyone has previously opened them up, there's a good chance they were put back together wrong, you're getting uneven pad pressure, brake drag, scored rotors. It's imperative to ensure proper alignment of the rear brake piston and the pin on the inner pad. That the pin falls between the cross ridges on the piston, and stays there.
    Regarding the alignment, front rotor machining and injector flush, that is likely just a wallet flush.
  5. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Sounds suspicious.
    But I'm not necessarily going to default to the easy idea that the dealership is wrong.
    Sounds like you have a 2010 that you bought used, and it hasn't really been checked out in 2 years.
    We really have no idea how it was used or maintained before you bought it.
    It is possible it needs the work.
    It is possible the dealership wants you to keep you arms and hands in the cart at all times, and you are about to be taken on a MAJOR ride.
    Since we are talking about some real tangible (and important) things here such as brake rotors and pads, what I'd want is a second opinion.
    I'd try another repair venue or dealership and see what they say. I might even request to see the rear pads and front rotors.
    You'll either get the same diagnosis, OR find out that indeed you were about to go on "Space Mountain".
    2nd opinion is I think the best way to proceed.
  6. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    I just changed to my steelie winter wheels, and was recommended by the supplier (TireRack.com) to use the lug-nuts supplied (free) with the steelies, for exactly the reasons Mendel Leisk mentioned.
  7. Eclipse1701d
    Eclipse1701d Prius Enthusiast
    645
    224
    Nature coast, Florida
    Three Touring
    I would be very surprised if they changed the fluids when/right before you purchased it... With that said, one could argue that you now have all new fluids, and the car is properly maintained. However, I am sure you paid at least double what you should've. It is my belief that when you show up at a dealer every two years, they are going to try and sell you every possible service they can, because you are considered one and done. On the other hand, someone who comes to the dealership for regular maintenance are most likely treated differently.
  8. mr_yellow
    66
    Technology
    Thanks guys for the advice.
    I'll have to check exactly what was done when I bought the car. The brake fluid looked pretty prestine when I bought so I assumed it was changed and I recall they said a full service was done. Maybe it wasn't in the Toyota system so the dealership thinks it's still the stock fluid.
    I was able to check out the rotors while the car was on the lift and indeed there was uneven pad wear and the rear left rotor was pretty scored. I'm still going to get a second quote from a local mechanic I trust and we'll see what the price difference is. As for the lugs, the mechanic explained that regular lugs have a larger conical surface area vs the stock Prius lugs and that helps with preventing warping of the steelie rims.
    So the dealership wasn't too off their rockers but I'm definitely going to get the work done elsewhere.
  9. Mendel Leisk
    41,473
    Uneven wear and scoring on the rear rotors is exactly what I had. I was responsible for the mess up, had removed and re-installed calipers/pads, without paying attention to the inner pad pin having to land between the piston spokes. This will screw up the rear brakes. What happens is when you apply the parking brake the piston rotates, if it's allowed to, due to the that pin not locking in between the spokes. From then on the piston is pushing on the pad on one edge, and the pin. This grossly skews the pad, creates terrific wheel drag, and causes rotor scoring. If they remove the inner pad and find it has only 50% contact area worn, and the inside face of the rotor has a corresponding rusty/unused zone, and the pin on the pad looks all chewed up: that's your culprit.
    I wouldn't be too quick to change dealerships. Just tell them what you do and do not want? Jumping to a new dealership is not without it's downsides.
    (Note in the above, less than 50% of the pad is actually making contact with the rotor, the top half. The pin on back of pad is just behind my thumb in this pic. You can also see chunks of the pad breaking loose in at least a couple of spots.)
    (This is the rotor surface corresponding to the above pad. Again, the rusty area is not getting any decent pad contact.)
    Pin on back of inner pad, chewed up:
    Piston spokes:
    BTW, all I did with the above, was remove the rotors, and clean them with steel wool. Then install brand new pads and shims, properly. When I first test drove it, it sounded terrible. A few blocks, a bit better. A month later, no evidence anything had happened, even the rotor grooves healed themselves. :)
    #9 Mendel Leisk, Nov 25, 2015
    Eclipse1701d and ftl like this.
