1. Offline
    mtnbkr New Member
    Start a Conversation
    May 4, 2010
    MD
    Your Vehicle Year:
    I'm thinking about tinting my 2010 Blizzard Pearl Prius with 20% all around (none for windshield). Should I tint the lower rear window? Since it's already tinted, would I want to tint it with a higher value tint like 30% to try and match the overall shade of the rest of the car? The local shop that I've been to in the past is using Global Quick Dry Plus (QDP). Any thoughts on this stuff?
    Thanks.
  2. Offline
    rlr66 New Member
    Mar 21, 2009
    87
    Orlando, FL
    Your Vehicle Year:
    It's not necessary. You won't miss anything.
  3. Offline
    ozarkgolfer Junior Member
    Apr 22, 2010
    76
    Rogers, AR
    Your Vehicle Year:
    I just had my 3G BP tinted with 30 including the rear window and excluding the windshield. The lower rear window visibility is still good and I like the look of the black spoiler and rear lower window 'melding' into one black unit. Are you sure 20 is legal or do you care? 30 seems plenty to me - YMMV!
    I have a copy of the receipt stored with my insurance and title in the car in case I get pulled.
    I also pulled the wheel covers and installed mudflaps and center caps. I like the look a lot.
  4. Offline
    32kcolors Senior Member
    Jul 14, 2009
    4,911
    684
    Redondo Beach, CA
    Your Vehicle Year:
    The lower rear hatch glass is 29%, so it won't be exactly equivalent if you tint 20% all around (for an aggregate of ~15%, since the Prius is already tinted ~75% all around in the glass). It's also a different color (dark gray versus green in the other windows).
  5. Offline
    josh2008 Hyundai Tech
    Sep 2, 2008
    363
    132
    Princeton, WV
    Your Vehicle Year:
    I didn't tint it on my 2005 I had and regretted it (had 20% all the way around). On my 2010 I have 15% and also tinted the lower rear window, I like it much better. Dramatically helps to cut down on headlight glare through the back windows at night.
  6. Offline
    drees Senior Member
    Oct 31, 2007
    1,774
    239
    Your Vehicle Year:
    Had the windows tinted in my 2008 and if the 2010 is like the 2008, you'll definitely want it tinted to match because of the color difference at least - went a shade lighter for it and came out pretty good - definitely better than without (it wasn't tinted initially).
  7. Offline
    nahtanoj New Member
    Mar 7, 2010
    36
    san diego
    Your Vehicle Year:
    i went 30 in the back, little windo included. you can only tell a difference from the inside. from the outside it all looks black. i would recommend tinting it, but wouldn't worry about making it a different shade.
  8. Offline
    thatguychristian New Member
    Apr 15, 2010
    22
    Redondo Beach, CA
    Your Vehicle Year:
    I had my car tinted. At first I didn't have him tint the lower window since at night and in the shade it looks the same. However, in direct sunlight and an average sunny day, you can see through the little hatch. I don't know the exact % since I had him tint at "dark" but the visibility through the lower hatch didn't reduce at all.
    Overall, I recommend it. But, it's up to you. Try it first without, then take a look at it in direct sunlight.
  9. Offline
    ajc Member
    Aug 11, 2009
    340
    34
    pa
    Your Vehicle Year:
    Had my Blizzard White tinted 20% on all windows but he front windshield. The tint shop said the bottom back window has tint from the factory and did not have to be tinted.
  10. Offline
    mtnbkr New Member
    May 4, 2010
    MD
    Your Vehicle Year:
    Does anyone have a picture of their tinted prius showing the rear window? Please specifiy if you had it tinted or not. About the lower window, since it's tinted to 29% from the factory, would adding a 50% tint to it make it have a net tint value of around 15%? Does it work that way?
  11. Offline
    Jul 14, 2009
    4,911
    684
    Redondo Beach, CA
    Your Vehicle Year:
    Yes, it will have an aggregate of ~15%.
Share This Page
