1. Offline
    ggood ggood
    Jan 17, 2004
    Message Count:
    1,917
    276
    Houston, Texas
    Your Vehicle Year:
    This Denso website has descriptions of many of the parts, sensors and ECUs used in the Prius (though Toyota is only mentioned by name a couple of times), including descriptions of lane keep assist, collision avoidance, etc.
  2. Offline
    p626808 New Member
    Mar 10, 2004
    Message Count:
    292
    Your Vehicle Year:
    Great find..
    thanks.
    Scott
  3. Offline
    dick_larimore New Member
    Feb 8, 2009
    Message Count:
    35
    Central Indiana
    Your Vehicle Year:
    Re: Denso electric A/C
    I read the description of the electric A/C for hybrids. The description of the A/c mentions that it runs at 7500 RPM regardless of the engine RPM and since it runs so fast, only a small refrigerant charge goes thru the compressor on each revolution.
    Does anyone understand show the electric A/C is powered on the Prius? Is this unit ran in an ON and OFF mode or is the RPM of the A/C compressor varied from low to high RPM in proportion to the amount of cooling required? The old engine powered A/C systems are typically the ON/OFF control.
  4. Offline
    Mar 8, 2008
    Message Count:
    9,152
    1,793
    Your Vehicle Year:
    2G Prius A/C compressor speed is variable, and controlled by the A/C ECU. The ECU takes into account interior humidity, the amount of sunlight, interior temperature, which vents are selected, and whether the wipers are operating.
  5. Offline
    Jul 12, 2007
    Message Count:
    10,558
    430
    Adelaide South Australia
    Your Vehicle Year:
    But the Honda Insight is better because it has rear vents!
    Well according to a reviewer.
  6. Offline
    Feb 8, 2009
    Message Count:
    35
    Central Indiana
    Your Vehicle Year:
    Thanks Patrick on the explanation on the control of the A/C. A variable speed control of the compressor insures that only a minimum amount of fuel is used to cool the interior of the car. This is way better than mixing hot outside ambient air with the cooled air to control the interior temperature of the vehicle. It will be interesting to understand the "improvements" to the A/C efficiency of the Gen III Prius compared to Gen II.
Share This Page
