Diesel Engines
Discussion in 'Diesels' started by durallymax, Feb 27, 2010.
  1. Offline
    durallymax New Member
    Start a Conversation
    Feb 19, 2010
    142
    Under The Hood
    Your Vehicle Year:
    as of now all on and off road Diesel is ULSD. ultra Low Sulfur Diesel. Less that 15ppm. Now some Marine diesel fuel has higher sulfur concentrations. But most of it is still under 500ppm.
    Now many people overlook the very few advantages of Acid rain, actually most people dont know there are advantages. Certain plants such as alfalfa, require sulfur as a nutrient. Acid rain always provided this, but with acid rain gone, we now have to apply it to fields.
    The above is true, but somewhat of a joke. Acid rain is bad, its not very hard to apply sulfur to fields, it just gets mixed in with other fertilizers.
    As for NOX. That is also controlled now. That is what the 2010 emissions standards focused on for on-road diesels. Many OEs opted for the easy way out by using Selective Catalytic Reduction. (SCR). Know by many as Urea Injection. Basically Liquid Urea (Diesel Exhaust Fluid (DEF)) is injected into the exhaust stream in a catalyst after the Diesel Particulate filter. The urea reacts with the NOX and converts it to Nitrogen, Water and a small trace of CO2. Its a very simple setup. It does add an additional upfront cost due to the cost of the equipment and it does also require an additional maintenance cost throughout the vehicles life. DEF is $4-7 per gallon and on passenger vehicles, the tank gets refilled every oil change (manufacturers suggested miles). This is mandated by the EPA that the tank be large enough to allow this. On commercial trucks the tanks usually last for a few tanks of fuel which on a commercial truck is a minimum of 100 gallons of fuel on board and can be as high as 400 gallons. How much DEF these systems burn i really cant say, they are brand new in the US(except for the Mercedes Benz Diesels). But I do know the new Duramax has a 5.5 gallon tank, and the OCI is 7,500 miles. Thats on a 397hp/765lb tq engine. So the added cost isnt a lot.
    Now there is AdBlue, MBs DEF. Its something ridiculous like $35/gallon. But its no different than generic DEF.
    Truck stops are in the process of installing DEF pumps.
    Now if you are a farmer reading this, you cannot just put granular UAN urea into the tank.
    And for some of the people who payed attention in chemistry, no you cannot pee in your DEF tank.
    The tanks have sensors in them to determine what is in them ,and if the wrong fluid is in there it will shut down the vehicle. Same happens if you run out. Now it does give you a grace period to get to a DEF station. But it does this under reduced power. and if you run out in the middle of the desert you may be out of luck.
    Other manufacturers such as Cummins, relied on in cylinder technology on their 6.7L to meet the emissions standards. But in order to accomplish this they had to reduce the compression ratio, increase the EGR cooler size and put more Exhaust gas into the cylinder. All of this is done to reduce the combustion temperature. a cooler burn in the cylinder reduces NOX emissions, but it also reduces power and reduces fuel economy. Which is why the B series cummins jumped .8L.
    SCR will always provide better fuel economy than a large EGR system with lower combustion temps. A hotter burn is more efficient and SCR allows a very hot burn. A hotter burn also reduces particulate emissions meaning fewer DPF regens.
    Then there is the VW TDI. They went one step further and come out with the best of the best. They put cylinder pressure sensors in the glowplugs and used Piezo injectors to alter the amount of fuel put into each individual cylinder for each injection event. By only giving the cylinder the amount of fuel it needs, and by using piezo injectors to inject the fuel multiple times per event, they were able to meet the stringent 2010 emissions standards.
    Now for Off-Road vehicles the same emissions regs are coming. 2013 is the date. 2011 is when the NOX standards go into effect, 2013 is when the particulate emissions go into effect. Agco has already put SCR on their tractors. CNH announced it would also be using SCR, and Deere announced they would be going the rout of Large EGR coolers and lower compression.
    However currently, off road emissions regulations only cover engines up to 800hp. Engines over 800hp are exempt, thus why most large ships dont have emissions regs.
  2. Offline
    hyo silver Away
    Mar 2, 2005
    14,882
    1,190
    Sunset
    Your Vehicle Year:
    Not to change the discussion, but I have a question about diesel fuel. This seems like the right thread. My limited knowledge of diesels and their history tells me Rudolph designed his engine to run on just about anything, and it wasn't as popular after the use of petroleum became more common.
    Is it possible to run a diesel on a completely benign fuel? Not 5% bio, not 50%, but 100%? What modifications are necessary to the engine? Is it possible to make or derive small amounts of fuel in your own backyard? What would be needed to do that? I'm thinking more of a small sailboat diesel with a modest appetite, which I'd guess is more feasible than full scale production for a trucking company or something like that. Any thoughts? :)
  3. Offline
    Feb 19, 2010
    142
    Under The Hood
    Your Vehicle Year:
    Rudolf built his first engine to run on coal dust.
    Now there is a myth that he designed it later on to run on peanut oil and such. But that is not true, it was just running on peanut oil at the worlds fair.
    Whether or not he designed it to run on anything I do not know. But the petroleum craze wasnt as big back then.
    Any diesel engine will run on 100% biodiesel. The reason you see many scares about it is because it will eat away rubber hoses not designed for it, and it is also a very powerful detergent meaning it cleans out the fuel system and plugs fuel filters.
    So if the diesel in your sailboat was built before 1996, replace all of the rubber hoses with new hoses designed to be compatible with biodiesel. Might be safe to just do it anyways unless it is very new.
    Then get a box of fuel filters. If it is a very old diesel that has run petro Diesel its whole life, you will need a lot of them, if it is a newer diesel it doesnt have as large of a buildup in it.
    Then change the fuel filters extremely often. And the lengthen the intervals from then on.
    If the fuel system does not have an inline pre filter, I would install one when you redo the hoses and keep plenty of these on hand. These filters are cheap to replace and will help your more expensive filters last longer.
    With B100 the initial cleaning is fairly quick. Once you get through the initial cleaning then you can go back to regular fuel filter change intervals.
    I should add that the "cleaning" is automatic, the fuel does it itself, you dont actually clean the system.
    Also make sure to not spill it on paint, as it will eat it away,
    There is one other issue with Biodiesel and that is its cloud point. Diesel already has a low cloud point, and Biodiesel is much worse. But unless your sailboat is an icebreaker sailboat, you wont have to worry. But I see that you are in BC. So when in storage during the winter, if it is not in a heated garage/shop, it may be wise to drain the system of Biodiesel and store it with winter blend diesel fuel. You can store it with B100 but it will "gel" and you will need new fuel filters come spring.
    There is no set number on when B100 gels, so if you plan to do some chilly sailing, you may need to run a lower blend of it.
    Also, there are no additives to prevent biodiesel from gelling yet. Just mixing in #1 and #2 diesel.
  4. Offline
    hyo silver Away
    Mar 2, 2005
    14,882
    1,190
    Sunset
    Your Vehicle Year:
    Thanks, Max.
    I don't have the sailboat yet, so cleaning out the old motor isn't a problem. ;) I'm just starting the research process, and considering different types of systems for it. I'd very much like to do without petrochemicals completely. It's possible an electric motor, batteries, and a trailing generator will do the trick, but I'm not sure. A standard diesel with clean fuel is intriguing, but it sounds like it would not work year-round.
    Tell me more about B100. It can't be as easy as cleaning out the fat fryers from the local fast food restaurants, can it? What does it do to fibreglass?
  5. Offline
    seftonm Member
    Apr 7, 2006
    325
    42
    Winnipeg, MB
    Your Vehicle Year:
    True, but it won't necessarily run very well or long. Rudolf's engine would probably run on almost anything. Even engines from 10 years ago are much more forgiving when running B100. Modern engines pushing fuel at 30000 psi through 100 micron holes, then into complex catalysts and aftertreatment systems are a different story. I would only put certified biodiesel in my car, and adhere to the manufacturer's recommendation of <5%. Some manufacturers allow 20% now.
    hyo silver, you seem to be thinking about waste vegetable oil. It's very different from biodiesel. Vegetable oil requires engine modifications in order to be burned.
  6. Offline
    hyo silver Away
    Mar 2, 2005
    14,882
    1,190
    Sunset
    Your Vehicle Year:
    Yes, it seems that is what I'm thinking about. Part of my confusion is that what's called 'biodiesel' really isn't biologically derived - it's just a bit of something added to regular diesel. Is B100 basically vegetable oil, or are we still talking about two different things?
  7. Offline
    qbee42 My other car is a boat
    Mar 2, 2006
    18,043
    2,916
    Northern Michigan
    Your Vehicle Year:
    Biodiesel is non-petroleum diesel. The confusion comes from the fact that most people mix it with regular dino-diesel, which helps minimize some of the problems. Straight biodiesel will burn fine in a normal diesel engine. The main problems are making sure that all of the seals and hoses are compatible, and eliminating glycerin and any other gunky components. Most biodiesel and waste oil fuels have a number of gummy components which will cause fouling. You either need to remove them, or mix in regular diesel fuel to keep the percentages manageable. In general, diesel engines will burn anything combustible that you can squirt through the injectors.
    Tom
  8. Offline
    2,397
    297
    Your Vehicle Year:
    Biodeisel is an ester made from a fat. Usually vegetable, but you could make it from lard or butter if you kept them liquid for the reaction and really wanted to. The alkaline reaction is pretty straight forward. Just shake up the right amount of fat, alcohol, and base in a bottle, and ta-da, biodiesel. The work is in seperating out the glycerol by product and washing the biodiesel of other impurities.
    Technically, it's modifications to the fuel system. Vegetable oil, either unused, straight(SVO) or waste(WVO) will burn in warm engine. But it's thicker and has lower gel point than biodeisel, so it can easily clog the fuel lines. Conversion kits put in a second fuel tank so you can start on deisel, switch to the oil when warmed up, and then switch back to clear the lines of the oil before shutting the engine off.
    If you are going to be securing the fuel yourself, the upfront cost of small home biodeisel reactor and vegetable oil conversion kit seem to be about the same. Both require pre-filtering of WVO used. The conversion kit doesn't require the purchasing, storing and handling of none too safe reagents (mostly methanol and lye). Then again, you need a seperate one each vehicle. The biodeisel can also more be readily used in an oil heating system. The waste glycerol is another issue to contend with, but I've seen several uses for it on a biodeisel forum.
  9. Offline
    seftonm Member
    Apr 7, 2006
    325
    42
    Winnipeg, MB
    Your Vehicle Year:
    Thanks, you're absolutely right. A diesel engine will burn almost anything. Modifications must be made to the fueling system, not the engine, to run veggie oil.
  10. Offline
    Feb 19, 2010
    142
    Under The Hood
    Your Vehicle Year:
    Sefton and Shellyt both hit it on the head.
    The short and skinny
    Biodiesel is what you could call a "refined" fuel made from sources other than crude oil.
    The list of things to make Biodiesel from is a mile long, as you can make it from almost anything. The weirdest thing I saw was somebody in california making it from used car parts.
    Soy continues to be the most common, but it is also one of the more inefficient ways of producing it. Im a farmer and I dont think soydiesel is the way. There are so many other better uses for soy and so many more efficient ways to make biodiesel, like Algae. Its simple to grow as long as you have a lot of sunlight. And yeilds 1,000 gallons per acre for one year whereas soybeans only yeild 60.
    Any diesel engine will run on 100% biodiesel providing the rubber hoses and seals will handle it. But the actual mechanical parts of the engine whether it is an older diesel running 4,000psi in the fuel system or a new common rail engine running 30,000psi in the system, will run it. As for its compatablilty with DPFs and SCR, I do not have very much information on that yet.
    Now SVO, straight veggie oil is commonly the practice of putting used cooking oil straight into your take, and not extracting the glycerin. This requires more modifications to the vehicle which is explained above.
    There are also people running diesels on many other things, one guy runs his on used ATF.
    The key is the fuel temperature, and the filtration of it. Its has to be clean and kept at a proper temperature where it will flow through the fuel system.
    Home grown biodiesel is catching on and is actually fairly simple to make. But there are hazardous chemicals to store which like to explode. But if you keep the barrels properly grounded this will not be an issue.
    Soap makers love the glycerin, and maybe if someone in your family is bored, they can use the glycerin from your biodiesel facility to make soap and sell it as an eco-friendly soap. This will help you get a return on investment quicker.
    Feedstock is becoming harder and harder to get these days. Waste fryer grease has been gobbled up by large biodiesel facilities, but if you are diehard about it, there are many local co-ops that will sell you feedstock by the tote.
  11. Offline
    jayman Senior Member
    Oct 21, 2004
    13,448
    587
    Winnipeg Manitoba
    Your Vehicle Year:
    I actually strongly support the research now being conducted on algae to make biodiesel. This is a VERY efficient and novel approach to making fuel, and should prove to be quite adaptable to large scale production
  12. Offline
    Mar 2, 2006
    18,043
    2,916
    Northern Michigan
    Your Vehicle Year:
    I wonder if we can use this technique in our marina. We have plenty of algae. :rolleyes:
    Tom
  13. Offline
    Oct 21, 2004
    13,448
    587
    Winnipeg Manitoba
    Your Vehicle Year:
    Indeed. For some reason, algae acts like crabgrass on a lawn. When you don't want it, it's EVERYWHERE.
    No doubt once you expect the algae to grow inside plastic tubes, it will refuse to do so
  14. Offline
    hyo silver Away
    Mar 2, 2005
    14,882
    1,190
    Sunset
    Your Vehicle Year:
    Ah, now this is getting interesting. Fuel from algae? The answer to our problems has been sitting right there in the primordial ooze all along. :)
    What needs to be done for this to replace petroleum?* Is the engineering ready to go, or is more research needed? Could this really be the beginning of the end of oil? Given the choice, I can't imagine people would prefer to give their money to BP and Exxon instead of running their vehicles on pond scum. How do we go about giving them that choice?
    * Sure, call me naive and idealistic. Then say it's impossible, just to encourage me to try harder. :D
  15. Offline
    Mar 2, 2006
    18,043
    2,916
    Northern Michigan
    Your Vehicle Year:
    Odd things happen in nature. The influx of non-native Zebra Muscles and Quagga Muscles have severely depleted the plankton in the Great Lakes. At first glance this appears to be a good thing. Our already clear water is now crystal clear, but behind this clearness is a sinister cycle: The clear water allows deeper penetration of sunlight, which allows algae to grow at deeper depths. The extra algae depletes its own resources, which causes a large die off. The dead algae decomposes inorganically, forming a stinky sludge that fouls the beaches. The inorganic decomposition also creates botulism, and the toxins from this are absorbed by the muscles.
    Lacking a sophisticated nervous system, the muscles aren't bothered by the botulinum toxin. Small invasive fish (sculpins) eat the muscles and succumb to the toxin. While the fish are thrashing around around on the surface dieing, seabirds swoop in for an easy meal. The result of all this: lots of dead seabirds floating in to the beaches. All because of pesky muscles and slimy algae.
    Tom
    2 people like this.
  16. Offline
    Feb 19, 2010
    142
    Under The Hood
    Your Vehicle Year:
    there was one researcher who declared that if all americans switched to diesel vehicles, and relied on algae biodiesel we would only need 100,000 acres of algae to produce enough fuel.
    This is a far stretch but interesting none the less.
  17. Offline
    Oct 21, 2004
    13,448
    587
    Winnipeg Manitoba
    Your Vehicle Year:
    Yep, many things in nature are a Paradox
    Though quite frankly, I can't STAND seagulls
    We need WAY more research before throwing out a WAG like that. But I am all in favor of that research.
  18. Offline
    Mar 2, 2006
    18,043
    2,916
    Northern Michigan
    Your Vehicle Year:
    We call them "Rats with wings." They have very few redeeming qualities other than being good to look at against a blue sky. Terns are just as pretty (better, I think), and they lack most of the obnoxious traits so prevalent in seagulls. I say we replace them all with terns.
    Tom
  19. Offline
    Feb 19, 2010
    142
    Under The Hood
    Your Vehicle Year:
    yes much more, the thing is that not every american is going to switch to diesel, probably not even half of them, because diesel alone isnt the answer for everybody, even though it is more efficient than gasoline.
    Im sure it would still take way more than 100,000 acres to produce enough fuel. Because im sure his figure was in a best case scenario. Well things are never best case scenarios. The biggest issue is the same issue solar powered cars have, sunlight. Algae needs it to grow.
    We do have a lot of desert where we could set up these plants, but we still need to get salt water to them.
  20. Offline
    Oct 21, 2004
    13,448
    587
    Winnipeg Manitoba
    Your Vehicle Year:
    I really like how they land on the roof and poop white poop all over it
    Perhaps not THE answer, but a good step in the right direction.
    The advantage of a closed cycle system is that - in theory - there shouldn't be any evaporation losses. Many desert areas already have a problem with brackish/salty water anyway
Share This Page
