Dirt on sills under doors
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by PriusRos, Apr 9, 2016.
  1. PriusRos
    PriusRos A Fairly Senior Member - 2016 Prius Owner
    1,973
    218
    Rockville, MD
    So far, I love my 2016 Blizzard Pearl but she is proving quite a high-maintenance type of girl.
    Of course, one would expect white to show dirt easily but what I find unusual is that the way the seals on the doors are designed, there's a gap underneath the doors and during wet weather, dirt and moisture seems to splash up under the doors and onto the sills. We've had quite a bit of wet weather recently, and they are always dirty.
    I even found some dirty rainwater in the gas cap compartment (although the little door was closed).
    Is this normal?
    Coast Cruiser likes this.
  2. fotomoto
    fotomoto Senior Member
    5,597
    3,771
    So. Texas
    Actually lighter colors are better with day to day road grime type dirtiness; however, dark mud or red clay type soils will show up better on white. It just really depends on your local environment. Around here most dirt is a dark white to brownish color (caliche) so our 06 in driftwood metallic does really well at looking clean even though it isn't. My white CMax just gets duller looking while our dark blue metallic Outback starts looking dirty almost immediately after a wash. LOL
    Generally the higher the speeds traveled, the more grime will work its way into the sills.
    PriusRos likes this.
  3. PriusRos
    1,973
    218
    Rockville, MD
    You're right that dark cars can show dirt but my last car, Winter Grey 2010 Prius, didn't show too much dirt at all. It would get duller but you couldn't really see the dirt unless it was mud or white bird doo (which was a problem). What I'm referring to isn't mud that kicks up from the road, but dirty wet spots splashing up and getting trapped under the doors. You can't see it until the doors are opened. I don't think that occurred on the 2010, but then maybe it just wasn't so noticeable.
    And I've also found that the doors on the 2016 don't close as easily. You have to push/pull them quite hard for them to close properly, which wasn't the case with the 2010. The seals are quite different.
  4. DonDNH
    DonDNH Senior Member
    1,711
    654
    Nashua, NH
    Four Touring
    Part of making the car a bit quieter?
  5. GaryD1
    GaryD1 Active Member
    302
    138
    Seagrove, NC
    was on gen 3, glad you shared, was hoping this had improved. Its part of the wash job on gen 3, especially blizzard pearl around door jambs, it seems to show up more
    Coast Cruiser and PriusRos like this.
  6. Kenny94945
    Kenny94945 Active Member
    767
    392
    Sausalito
    2016 Prius v wagon
    I have noticed this dirt in the door sill and jam issue too.
    With Chevy C4 year Corvettes, they also had that issue. The aftermarket came up with a secondary weatherstrip.
    Not sure if a second ws is adaptable to a Prius....you can try.
    Else nature of the beast, we all just have to wipe those sills/ jams clean
  7. xliderider
    xliderider Senior Member
    7,848
    3,102
    Honolulu, HI
    The rain water/dirt that runs down the window, drains into the door, then out the bottom drain holes in the door, out on the door sills. Not much you can do about it.
    kithmo likes this.
  8. PriusRos
    1,973
    218
    Rockville, MD
    Hmm...maybe...
    Merged.
    Hmm... so you're saying, it's the rainwater draining down from the top, not splashing up from the bottom ...
    #8 PriusRos, Apr 9, 2016
  9. xliderider
    7,848
    3,102
    Honolulu, HI
    That's exactly what I'm saying...
    Think about it, how likely it is for outside water to squeeze into the narrow gap under the door vs water running down the side of the car. If you look under the doors, they all have drain holes for water. If they didn't, the doors would fill up with water.
  10. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    I'm glad you brought this up, PriusRos. It's odd. I've never had this happen on any other Toyota product I've owned, or any car for that matter. I also have a fairly large amount of dirt being thrown up on the lower body panels, behind each (Toyo) tire. Looking forward to getting Mudguards when available. (This is after a light rain.) image.jpg
    #10 Coast Cruiser, Apr 9, 2016
    xerox6135 and PriusRos like this.
  11. PriusRos
    1,973
    218
    Rockville, MD
    Yep, just have to keep wiping, I guess. I asked the dealer whether there was something such as weather stripping or rubber treads and they couldn't find anything. The salesman showed me that there was a gap between the bottom of the door and the jam and the seal was higher up. I really don't think it was like that on the 2010 but of course I don't have it now to compare.
  12. Coast Cruiser
    2,267
    2,571
    image.jpg What is that lower piece... for "ground effects?" Sure attracts a lot of dirt. The upper door sill is clean.
    I keep hitting my foot/ankle on it when exiting the car. You can see how far it extends out. I have to take an extra second, and remember it's there. (Along with mudguards, I'm looking for those stick-on metal door sill protectors. None available yet.)
    #12 Coast Cruiser, Apr 9, 2016
  13. Tideland Prius
    16,068
    It's there in the 2010. I know cause I'm anal and I wipe all the door sills with a different cloth to remove the oils and water marks. Sometimes, i'll just open the door and run the wash mitt along the door sills as well with the car wash soap.
    No, it's just how the door is built. Anything inside of that part is covered/blocked by the rubber door seals.
  14. Coast Cruiser
    2,267
    2,571
    These are Toyota OEM "Euro" Mud Flaps:
    2016 Toyota Prius Mud guards and Mud Flaps and Splash Guards | JuicedHybrid
    I think that dirt on the door sills is image.jpg coming from the front tires. The dirt goes right through that crack underneath the door.
    Experiment completed.
    I washed everything, and got all the door sills clean. (Water does not drain down through the doors. Where did that idea come from? The seal is tight around the windows on my Gen4.)
    Light rain stopped last night. I found a wet road in the park with several puddles. Drove on that road, and sure enough, the inside door sills are wet and dirty again. The water/dirt is coming up off the front tires, and going through the crack under the door.
    None of my 3 other Toyota's did this. Nor my Honda. What's up with this Prius?!? :cautious:
  15. DonDNH
    1,711
    654
    Nashua, NH
    Four Touring
    There are drain holes on the bottom of the door (at least on Gen-III). I get water draining after washing the car.
    kithmo and xliderider like this.
  16. Mendel Leisk
    38,220
    On our 3rd gen it gets grubby in that area. I think worst case would be when it hasn't rained in a while, there's a lot of soot and brake dust on the roads. Maybe a matter of degree, more pronounced on 4th gen? But yeah, 3rd gen is not impervious to this: any time I wash the car, albeit infrequently, the sills are kinda grungy.
  17. Coast Cruiser
    2,267
    2,571
    How the hell can Toyota make a car, that let's water inside the door?! I never heard of such a thing. I'd be afraid to pull the door panel off, and see what's in there! :ROFLMAO: Rust???
  18. DonDNH
    1,711
    654
    Nashua, NH
    Four Touring
    Most cars have drain holes; the seal between the door glass and the door isn't perfect and if you didn't have a drain, you'd get a bit of standing water accumulating in the bottom of the door.
  19. Mendel Leisk
    38,220
    All cars get water inside the door. Owner's Manuals typically caution you to ensure the drain holes at the bottom of door are clear, whenever you're washing the car. Door windows are the reason: a rain soaked window can be rolled down, taking water in, nothing can be done about it, except to ensure the water doesn't get into electrics, get hung up somewhere, is able to drain easily.
    kithmo, xliderider and Coast Cruiser like this.
  20. Coast Cruiser
    2,267
    2,571
    Makes sense. But I never noticed any of my previous cars draining water under the doors. Now I gotta go outside, and lay on the ground, and find those door holes! o_O:confused:
    This is what I found, guys. The hole is shaped like a slit. One slit under the front and back door. (Those two black rubber things on each side of the slit are little cushions, I guess.)
    Paul, from juicedhybrid emailed me, and said they will adding more accessories for the 2016 Prius hatchback next week. Including door sill protectors, and mud guards/splash guards.
