1. Offline
    triumph1 Member
    Start a Conversation
    Apr 14, 2008
    275
    Your Vehicle Year:
    I didn't know it would work if the car was not on- As it stands, someone could break the window and get into my house... Is there a way to disable it?
  2. Offline
    qbee42 My other car is a boat
    Mar 2, 2006
    18,043
    2,916
    Northern Michigan
    Your Vehicle Year:
    Do you want to disable it permanently, or just at night when you aren't in the car?
    Tom
  3. Offline
    Feb 26, 2007
    7,464
    1,038
    Carmichael, CA
    Your Vehicle Year:
    If you never program it in the first place, then the burgler will have smashed your car window for nothing. :madgrin:
  4. Offline
    EZW1 Active Member
    Aug 20, 2008
    624
    35
    Phoenix, AZ
    Your Vehicle Year:
    It's an unfortunate fact of life. The opener - er, homelink, is setup to work whether nor not the car is on. This is done because many people park their car inside the garage and if they had to start the car to open the garage door, there will be danger of asphyxiation (CO poisoning).
    On another front, most people who have automatic garage doors and not a homelink, keep the opener inside the car. The are faced with the same paradox as you, Triumph1.
  5. Offline
    Mar 2, 2006
    18,043
    2,916
    Northern Michigan
    Your Vehicle Year:
    Another unfortunate fact is that garages are generally easy to break into, even without door openers. Unless you have an exceptional garage, don't expect it to be Fort Knox.
    Tom
  6. Offline
    ceric New Member
    Oct 30, 2004
    1,114
    52
    Fremont, CA
    Your Vehicle Year:
    Easy. Rewire the constant 12v to switched 12v. There are two power wires that come with the homelink/auto-dimming mirror. The auto-dimming one is supposed to connect to the switched 12v, while the homelink one to the constant 12v. You can tie them together and connect both to the switched 12v. That way, the ACC needs to be on before your homelink works (much like auto-dimming - which does not work while sitting in garage!)
  7. Offline
    Mar 2, 2006
    18,043
    2,916
    Northern Michigan
    Your Vehicle Year:
    Does homelink retain programming without power?
    Tom
  8. Offline
    Feb 26, 2007
    7,464
    1,038
    Carmichael, CA
    Your Vehicle Year:
    Wiring diagram.
  9. Offline
    Feb 26, 2007
    7,464
    1,038
    Carmichael, CA
    Your Vehicle Year:
    Probably not, but at least the burgler won't be rewarded for smashing the car window. :D
  10. Offline
    Mar 2, 2006
    18,043
    2,916
    Northern Michigan
    Your Vehicle Year:
    Program the homelink to open your neighbor's garage door. :D
    Tom
  11. Offline
    Politburo New Member
    Feb 15, 2009
    968
    207
    Your Vehicle Year:
    I don't think the 5 seconds of running with the door closed would really make a difference (and you could likely get the door open before S1 even starts).
  12. Offline
    Mar 8, 2008
    10,476
    2,406
    Your Vehicle Year:
    Yes. If you disconnect the 12V auxiliary battery, then reconnect, there's no need to reprogram the Homelink.
  13. Offline
    thedutchtouch prius is my SUV
    Jul 5, 2008
    181
    Baltimore MD
    Your Vehicle Year:
    wouldn't the burglar have to be inside your garage to smash your car's window? which... if it has the garage door programmed, would make sense to park... inside... the garage?
  14. Offline
    jayman Senior Member
    Oct 21, 2004
    13,448
    587
    Winnipeg Manitoba
    Your Vehicle Year:
    No matter if the clicker is on the visor or if the Homelink is programmed, if the car is parked outside and somebody breaks the window, they can open the garage door
    The best way to secure your garage door at night is to use the Lock feature on the interior garage operator. The basic operator has a single button, which is no help to you
    The optional operator has a large button to open/close the door, and two smaller buttons: one button is to lock the opener, the other button is used to manually turn the opener light on and off
    My 3 button interior operator is pretty basic. This one at Chamberlain is fancy
    398LM - Smart Control Panel®
    You press and hold the Lock button for 5 secs or so, and the LED on the operator and on the obstruction sensor both start rapidly flashing. The opener will now ignore all remotes assigned to it
  15. Offline
    triumph1 Member
    Apr 14, 2008
    275
    Your Vehicle Year:
    Thanks for the suggestions- My car stays outside, the Motorcycles stay inside. My priorities are in place, no doubt.
  16. Offline
    Oct 21, 2004
    13,448
    587
    Winnipeg Manitoba
    Your Vehicle Year:
    So, can you lock your opener as I suggested?
  17. Offline
    EZW1 Active Member
    Aug 20, 2008
    624
    35
    Phoenix, AZ
    Your Vehicle Year:
    No, wouldn't mind much but it's an incredible liability.
  18. Offline
    triumph1 Member
    Apr 14, 2008
    275
    Your Vehicle Year:
    I don't have a three button remote- I think I have a manual lock on the door itself that goes through the frame.
    I may look into getting it rewired.
  19. Offline
    Oct 21, 2004
    13,448
    587
    Winnipeg Manitoba
    Your Vehicle Year:
    If you have a Chamberlain opener with the orange programming button, you don't have to rewire anything. The same two wires are used for the three button opener control.
    My Chamberlain came with the basic lighted button. I picked up the three button (Includes lock button and manual light button) for $30, it just hooks up to the same two wires
    You have to get polarity correct. If the wires are reversed, the LED on the control doesn't work. Flip the wires around and the LED will work. It will rapidly blink to indicate that all remotes are locked out
    So even if the car is parked outside, and somebody breaks the side window to get the clicker on the visor or the Homelink, nothing will happen. The opener lamp will flash 4 times or so, indicating it received the remote request but is ignoring it
Share This Page
