1. Offline
    infael New Member
    Start a Conversation
    Jan 23, 2008
    Colorado Springs
    Your Vehicle Year:
    My Prius alarm keeps going off. Only way to turn off is to put fob in car and start. Is there a fuse I can pull or a wire I can cut? I don't have the $ to get the alarm fixed.
  2. Offline
    northwichita .
    Sep 24, 2006
    425
    79
    Wichita KS
    Your Vehicle Year:
    Do you have an alternate fob to use, this would check your alarm problem is not due to the alarm button sticking on your current one, happened to me. Check your current fob, but you may not see an obvious problem with it, and it's good to have a spare if you don't.
    I do remember pulling up on the little alarm button on the fob to identify this was my problem, you could try that the next time the alarm goes off.
  3. Offline
    Avi's Advanced Automotive Independent hybrid repair shop
    Jun 28, 2012
    381
    125
    Your Vehicle Year:
    I have seen several key fobs with the panic button ripped out in order to fix sticking buttons. If you don't have a sticking button, you might try using one key at a time while wrapping the other in aluminum foil to see if the problem is limited to one key.
  4. Offline
    infael New Member
    Jan 23, 2008
    Colorado Springs
    Your Vehicle Year:
    The panic button was sticking. Thanks all!
Share This Page
