1. Offline
    Godiva AmeriKan Citizen
    Start a Conversation
    Apr 8, 2005
    10,340
    Your Vehicle Year:
    PDF I did when I installed a backup alarm in my left rear taillight. Includes step by step and pictures. Starts with disabling the reverse beep if that's all you want. Some of this was copied from others and then compiled. Don't remember who to give credit to anymore.
    1 people like this.
  2. Offline
    ckbarnard New Member
    Nov 8, 2005
    56
    Bakersfield, CA
    <div class='quotetop'>QUOTE(Godiva @ Apr 14 2006, 03:22 PM) [snapback]239893[/snapback]</div>
    At the risk of sounding ignorant, What is a backup buzzer/alarm? And how is that different from the reverse beep? I'm wondering if it is a gizmo that starts making noise when you get close to something?
  3. Offline
    Apr 23, 2005
    3,841
    Your Vehicle Year:
    <div class='quotetop'>QUOTE(ckbarnard @ Apr 14 2006, 03:43 PM) [snapback]239902[/snapback]</div>
    The difference is that the reverse beep can only be heard on the inside, while the buzzer will be heard outside while the Prius is backing up (in order to warn people). JC Whitney has several types, including one that says, "This car is backing up!"
    The gizmo you're thinking about is a reverse backup sensor, which again would only be heard on the inside.
  4. Offline
    walt New Member
    Jan 14, 2006
    195
    Bel Air, MD, USA -=- Blair, Merlin, Merka
    Your Vehicle Year:
    Godiva,
    thanks for the clear and simple directions - and with photos!
  5. Offline
    A2_Prius New Member
    May 7, 2008
    Your Vehicle Year:
    Is this pdf still available? I'd find it to be of immense help!
  6. Offline
    alanx3aa New Member
    May 30, 2008
    rifle, colo
    Your Vehicle Year:
    Hi, I new to chat rooms and the like. I am trying to find out how I can get a copy of the PDF with instructions on disabling the reverse beeper. Thanks, alanx3aa
  7. Offline
    ruralrt1 New Member
    Mar 26, 2008
    central ny
    Your Vehicle Year:
    How to shut off the beeping
    1. Power on the car to IG-ON or READY. IG-ON will do for this purpose.
    2. Using the Trip/ODO button, set the Trip/ODO display to ODO (not Trip A or Trip B)
    3. Power off the car.
    4. Now power the car to READY (brake on). This is required so that step 6 works correctly.
    5. Within 6 seconds of powering on, press and hold the Trip/ODO button for 10 seconds or more.
    6. WHILE STILL HOLDING ODO *after* the 10 seconds, shift the "gear" selector from P to R, then back to P. Now release the Trip/ODO button.
    7. If the last step was successful, "b on" or "b off" should be displayed in the location where the Trip Odometer or Odometer is normally displayed. "b on" is beep on, and "b off" is beep off.
    8. Press Trip/ODO to toggle the mode.
    9. Now power the car off to exit the toggle mode.
    10. Power the car on to READY and confirm the reverse beep status by shifting to R. The beep should not be audible if "b off" was selected, and should be audible if "b on" was selected
    This should work if follow the directions carefully. V.
    found it
  8. Offline
    Apr 8, 2005
    10,340
    Your Vehicle Year:
    Have no idea where the original PDF went. We have a link at PriusclubSD on the info page.
    I'll upload the pdf again.
    Disabling the beep is at the beginning of the document. Installing a backup buzzer is next. I got a buzzer from Radio Shack. Installed it in the rear driver's side taillight. It can be heard outside now, not load but it can be heard.
    I'll do this to the next Prius I own also, unless Toyota starts to build them that way.
    2 people like this.
  9. Offline
    ruralrt1 New Member
    Mar 26, 2008
    central ny
    Your Vehicle Year:
    1 people like this.
  10. Offline
    ruralrt1 New Member
    Mar 26, 2008
    central ny
    Your Vehicle Year:
    it is so nice not to have the beeper disturbing the quietness of the cabin. Toyota screwed up by not putting the beeper on the outside. I like the after market one telling people the car is backing up
  11. Offline
    Helio New Member
    Dec 3, 2008
    160
    Columbus, OH
    Your Vehicle Year:
    Thanks, Godiva!
    I saw other instructions regarding disabling the back-up beep on Priuschat that omitted a couple minor details. Now the cabin is ahhh-so-quiet.
  12. Offline
    shanghaiwind New Member
    Nov 10, 2010
    Your Vehicle Year:
    When I first drove away Prius IV 2010 from the dealer, it started beeping. I saw something wrong. Right the way, I called the sales rep to check, and ask when the beep is not on the outside. Now I know the Toyota screwed up the designed. Question, I have 7 year bumper-to-bumper warranty from Toyota. If disable peeper and install alarm, would this void the warranty? Thanks,
  13. Offline
    BhamPrius Member
    Jan 19, 2011
    106
    16
    Bellingham, WA
    Your Vehicle Year:
    has anyone successfully done this on the G3s yet?
  14. Offline
    Bruteforce New Member
    Jan 27, 2011
    St. Cloud, Florida
    Your Vehicle Year:
    Just did this on my wifes 2008. It drove me nuts (only had the car 1 week). It worked great..I'm not gonna tell the wife and see if she notices :)
  15. Offline
    tanprius New Member
    Feb 3, 2011
    Your Vehicle Year:
    This works great until you let someone borrow your car or leave it at the oil changer place where they don't know how to read a gearshift knob... I had to re-enable mine because I forgot that "others" use my car as well.
  16. Offline
    jfanfulik New Member
    Apr 15, 2011
    Your Vehicle Year:
    This does not work on my Prius 2010.
  17. Offline
    ZooDad New Member
    May 9, 2011
    Southern California
    Your Vehicle Year:
    I know this is a Gen 2 thread, but the search keeps bringing me here for this Reverse warning beeping. Any chance someone knows the steps for the Gen 3?:confused:
  18. Offline
    Apr 14, 2009
    5,777
    1,594
    Greenwood MS USA
    Your Vehicle Year:
    I do. Take it to the dealer, and ask that they disable reverse beep.
    Toyota made it require ODB-II hardware. If you have an ODB-II device like the scangauge II, you can use that.
    2 people like this.
  19. Offline
    ZooDad New Member
    May 9, 2011
    Southern California
    Your Vehicle Year:
    Good to know - Thank you!:thumb:
Share This Page
