DIY Cabin Filter Replacement - Anyone do this?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by nemrut, Oct 7, 2009.
  1. revhigh
    revhigh MPG Enthusiast
    986
    141
    PA - Pocono Mountain Area
    For an 08 .... but you get the idea ...
    REV
  2. rspriusiii
    rspriusiii Junior Member
    Vienna, VA
    NO.
    Gen II is a superior design
  3. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,476
    1,551
    Bay Area
    Here's the Gen III Cabin air filter replacement
    Kurt Davis likes this.
  4. abistro
    abistro Junior Member
    22
    Virginia
    Am I missing something? What does the cabin filter have anything to do with how the car runs? I thought it is just for filtering the debris coming into the cabin, such as pollen, smoke, etc.
  5. BruceInOKC
    BruceInOKC Member
    190
    Oklahoma City, OK
    No, you're not missing anything. They're probably thinking of the engine air filter, which can affect how the car runs.
    The cabin filter helps humans and pets breathe easier in the passenger compartment, especially if they have allergies. If you notice the air coming out of your vents smells musty or like mildew, it's time to change it. In my Civic Hybrid, this happened every 10,000 miles. In my Prius, it happens every 30,000 miles. Your mileage may vary. You decide when it bothers you.
  6. rdgrimes
    rdgrimes Senior Member
    1,740
    444
    New Mexico, USA
    2018 Prius Prime
    I've had 1st hand experience with a dirty/clogged cabin filter in a Toyota. It significantly reduces the air output from the vents, much worse cooling in hot weather and less heating in cold weather. If you have your air system running all the time, changing the filter at 15K is highly recommended. A clogged filter also loads the blower, resulting in increased power consumption, although how much this might effect anything other than blower life is an open question.
    When in doubt, change it. I tried to get 30K out of one and it was almost completely clogged. I do not drive in dusty places either.
    BruceInOKC likes this.
  7. BruceInOKC
    BruceInOKC Member
    190
    Oklahoma City, OK
    Great observations. You offer some compelling reasons for changing it sooner rather than later.
