DIY install of Toyota Remote Engine Starter Kit
Discussion in 'Gen 3 Prius Accessories and Modifications' started by GreenMaterialism, Jul 12, 2012.
  1. GreenMaterialism
    GreenMaterialism Junior Member
    70
    PA
    Has anyone purchased the oem Toyota "Remote Engine Starter" kit and installed it themselves? Just looking to hear how the install is, and if there are any tips/tricks to it. (There's no DIY manual for the procedure yet...) FYI, the Toyota-supplied install directions are here:
    http://www.toyotapart.com/PT398-47091.pdf
    It looks like a reasonable afternoon project, although the clarity is somewhat lacking in a few steps. I'm trying to decide whether or not I'm going to do it, but for those interested in the same, here's a brief synopsis on the package, according to the various PC threads which touch on it:
    • PROS:
      • Works, and is a legitimate Toyota Part.
      • Will run heat or A/C to achieve preset auto climate-control temperature.
      • Will turn seat heaters on if left on when car was turned off.
      • Automatically turns defrosters on if below a certain temperature.
      • Install is less invasive than an aftermarket system.
      • No extra remotes to carry or lose, works with all SKS keyfobs.
    • CONS:
      • Range is limited to the range of your stock SKS keyfobs. (~80 ft)
      • Car runs for 10 minutes, and then shuts down.
      • Car shuts off upon opening the door.
      • Will not work if outside temperature is below -22° F or -30° C.
      • Expensive when compared to the cheapest aftermarket systems.
    And the kit can be purchased from any Toyota dealer, or via the Priuschatshop: https://shop.priuschat.com/product_info.php?cPath=12&products_id=138
  2. peterjmc
    912
    195
    Baltimore, MD
    In my research I've done, the installation can be DIY up to the point where the ECU needs to be programmed. I had a copy of the Toyota installation instructions, will have to look for it.
    The kit comes with the remote start brain box, one wiring harness, one hood switch, a bracket, and a few other misc things.
  3. peterjmc
    912
    195
    Baltimore, MD
    Regarding your Pros- Aftermarket systems can do a number of those you've listed. They wouldn't be Pros if you are comparing the OEM system vs an aftermarket system since both systems offer the same capability.
    PROS:
    Aftermarket systems will also climate control settings as they were left upon exiting the vehicle.
    Aftermarket systems will also heat your seats if left on.
    Aftermarket systems can also utilize the OEM remotes. Aftermarket systems also provide you with the ability of using the system remotes as well which provide ranges anywhere from 100ft to 1mile and even anywhere where there is celluar service (Viper Smart Start, Compustar Drone Mobile)
    Check out this thread Viper SmartStart & 2010 Prius? | Page 2 | PriusChat
    IMO if you have the money, buy the aftermaket system. Myself and Judgeless who posted in the referenced thread have had the OEM remote start and we both prefer the aftermarket system.
    My reason for going aftermarket is for convenience in being able to start the car from a significant distance so that the car is comfortable for my 14mo old daughter by the time we reach the vehicle. Many times I've had to have her sit in the hot car while I load groceries/bags in the back. Remote starting the car as I'm walking to it just doesn't do it for me.
  4. peterjmc
    912
    195
    Baltimore, MD
    I have a softcopy of the install instructions for the OEM remote start system in PDF format. If anyone would like a copy shoot me a PM and I'll email it to you. I receive an error to the effect of it being to large when i attempt to upload it to this thread. It's approx 3.5MB
  5. GreenMaterialism
    70
    PA
    Thanks - I'd read that thread as well. My list of "pros" above wasn't intended to be exclusive; it's simply a list of what will work. For me personally, the OEM system's shortcomings are balanced out by the fact it's a factory part and doesn't require any modification, bypasses, etc. Now I may change my tune considerably after the install, if I actually do it, but for now the OEM system seems fine. Plus, you can find the complete OEM system for less than $300, so it's cheaper than the higher-tech systems and there are no annual subscription fees.
    My primary use is getting the defrosters going to speed my de-icing of the car - which I understand the OEM will actually do better than a Viper system, since the Viper can't turn on the rear defroster. (Or so I've read here: the issue being that the Prius auto-cancels the rear-defroster switch when the car is turned off, so upon restart it won't come on again, unless you have the OEM remote starter, which specifically tells it to turn on if cold enough.) I may be wrong on this though - if you can get the Viper to turn on the rear defroster, do let us know!
  6. GreenMaterialism
    70
    PA
    Is it the same PDF that's posted in the OP, or is it a better one?
  7. GreenMaterialism
    70
    PA
    Roger that. A friend of mine has techstream on a laptop, so we're hoping to activate it with that. As for the instructions - they're linked in the original post!
  8. sfv41901
    sfv41901 Blizzard Brigade #164
    3,957
    3,422
    Palmdale, Ca
    This install looks pretty straight foward. The signal mirrors are a lot more complicated.
  9. GreenMaterialism
    70
    PA
    Currently in the middle of the install, and hit a roadblock. On Page 14 of the above directions, Fig. 4.4, it says to install the red wire into the pictured bay, however on my car, that slot is already occupied by a yellow wire. The directions are very clear that it's the 4th position on the second row, which is definitely occupied on my car. Any ideas?
  10. sfv41901
    3,957
    3,422
    Palmdale, Ca
    Maybe find out what the red wire is for then see what the yellow wire provides......if its the same just tap into it.
  11. GreenMaterialism
    70
    PA
    Just figured it out - I had the wrong connector. There are two identical connectors used in the same spot, one immediately above the other, and I didn't see the top one since it was obscured by other wires! Rookie mistake - but at least I figured it out in due time!
  12. peterjmc
    912
    195
    Baltimore, MD
    :) I was gonna suggest that you may have pulled the wrong connector... but I thought to myself... nah he is probably locating the right one.
  13. kiseattle
    kiseattle New Member
    Northwest
    How do I find out if my 2010 Prius III has V4/V5 add on ?
  14. Judgeless
    Judgeless Senior Member
    1,825
    234
    Cleveland, OH
    I strongly recommend you give up on installing the OEM unit and install a Viper unit yourself.
    I ordered the OEM unit before I got the car and had the dealer install it for free when I bought the car as part as the deal. I hated it and had a Viper unit installed 2 months after.
    - It only starts from 40 feet from the car. Viper is 1 mile.
    - The car only runs for 10 minutes then shuts down. Viper unit is 60 minutes
    - You can only start the car twice. Viper unit there is no limit.
    - The Viper unit has a Pitstop mode that lets you keep the car running and lock the doors. This is perfect for running into a store to pick something up.
    - The Viper unit has a feature to start my car using a cell phone app
    - I have the Viper unit set to turn off the head lights when the car remote started. That way it does not stand out in a parking low showing people it is running.
    - There are many other great features of an aftermarket Viper unit over the OEM unit.
  15. ucsmfu
    ucsmfu Senior Member
    1,489
    405
    canada
    getting my drone mobile installed tomorrow :p
  16. Electric Charge
    Electric Charge Active Member
    545
    133
    Syracuse, NY
    I have a 2-way CompuStar system in my RAV4, highly recommend it. That said, I do dislike the size of the 2-way remote on top of the OEM fob, makes my keychain really bulky.
    Was about to get Drone Mobile myself, but got a Prius instead, so now I have to figure out which car I am going to drive more often.
  17. GreenMaterialism
    70
    PA
    Just to update - I've had the remote starter installed now for a couple months with no complaints. The install was relatively straightforward, and my total out-of-pocket cost was less than $300.
    True, Viper and other systems have many more features, but this oem Toyota unit fits my needs perfectly. I like that it works with all my remotes and there's nothing else that needs to be on my keyring, plus the simple fact that it will automatically turn on the defrosters automatically in the winter is priceless. Although if the rumors of it not working below a certain temperature are true, I'll likely have a few cold mornings in the dead of winter!
    As many others have noted, you do have to be VERY precise with the timing of your button clicks to start the car...
    As for the range, it seems to me considerably better than 40feet, but certainly far less than most aftermarket units. For example, my house is set back from the road by 45' and I can easily lock/unlock/start the car even when it's parked on the far side of the street. (Which would be at least 75'+, depending on how many spots away it is!)
  18. rajesh
    rajesh New Member
    hi just came accroess your post
    i am intrested in having the wiring diagram pdf file for the installation of the remote start for my prius
    u can send it to my emil
    [email protected]
    regards
  19. chrisj428
    chrisj428 Active Member
    680
    142
    35
    Vernon Hills, IL
    I'm just curious where you live in PA that the weather gets to -22°F in the winter with any regularity?
  20. GreenMaterialism
    70
    PA
    Never gets that cold here in PA, but I'm often visiting family in Ontario. From what I've seen, once things get below -20 overnight, lots of cars fail to crank. I guess that's why most of the fam has engine block heaters installed!
