1. Offline
    chickenhawk New Member
    Start a Conversation
    Sep 13, 2011
    27
    CA
    Your Vehicle Year:
    don't remember any tabs sticking out will check and take a pic..
  2. Offline
    sfv41901 Blizzard Brigade #164
    May 5, 2010
    2,279
    632
    Palmdale, Ca
    Your Vehicle Year:
    GPG, here is the pic I took........no tabs sticking out:
    [IMG]
    GoldPianoGarden likes this.
  3. Offline
    GoldPianoGarden Bling Meister
    Oct 6, 2010
    838
    58
    Brunswick, GA
    Your Vehicle Year:
    hmmmm... It looks like the oem bottom of the mirror is black. The way they put mine together, there is a tab on the bottom part of the white cover that they have lapped over the black bottom, right by the mirror stalk (between the stalk and the lens/light part of the cover). It's just a small tab, but it obviously needs to be stuck inside the mirror instead of poking out. I woulda never noticed it if I wouldn't have been underneath my mirrors doing something out in my garage. Looks like they just missed the slots inside each mirror where those tabs are supposed to stick.
  4. Offline
    stearicom Junior Member
    May 4, 2008
    59
    Your Vehicle Year:
    I just purchased my Prius and looking to do this to it. I miss having puddle and signal lights on this car.
  5. Offline
    Oct 6, 2010
    838
    58
    Brunswick, GA
    Your Vehicle Year:
    did you have an older Prius that had them on it?
  6. Offline
    May 4, 2008
    59
    Your Vehicle Year:
    I had the gen II that had the signal mirror covers. It didn't have puddle lamps. I have a Lexus that has them both with the power fold.
  7. Offline
    bielinsk Gremlin
    May 4, 2012
    464
    97
    Anaheim
    Your Vehicle Year:
    Had Tommy install mine this weekend. Look amazing and work perfectly. Tommy is really good, took about 80 minutes.
  8. Offline
    May 5, 2010
    2,279
    632
    Palmdale, Ca
    Your Vehicle Year:
  9. Offline
    Sep 13, 2011
    27
    CA
    Your Vehicle Year:
    wow 80 mins that is record time ... but then i guess once you do a few it is alot faster :D. i just finish putting in the puddle lights and yeah the wire behind ecu is not for the guy with thick fingers or big hand or tall guy.
    Here is what i figure out is that the connector that you will be tapping will be the lower one/ connector closest to the floor. What you do is start with the top connector. You place your finger on the top edge of the connector and move little down with fingernail to metal indentation tab and push down then you can push the top edge down and pull the black piece of the connector out and the rest of plug comes out. This is the first time i see this kind of plug. Once you have the top plug out then you proceed to the bottom plug and repeat the process of removal.
    Here is example of the metal tab that you push down.
    [IMG]
    Once you have it off then take the pink/red tape off the connector and for MODEL 2 the blue wire is located between 2 black wires as shown in the following pic from another member here.
    [IMG]
    Go ahead and tap that blue wire with the black wire from both left and right puddle. I combined the 2 black wire into splice in one end and have one black wire on other end of splice to tap into the blue wire of ecu. Make sure to have the tap atleast 1 inch away from the connector to allow bend of connector into ecu.
    Then I combined the 2 white wires from puddle into splice again and one white out of splice going to pin 24 white wire with little red stripe on connector on driver side.
    [IMG]
    Go ahead and close doors and make sure puddle lights work and then tie wrap and close up all panels.
    Man now the car looks nice :D Glad to finally have it done. I will take a pic of puddle light when i can.
  10. Offline
    jess New Member
    Jun 21, 2012
    Your Vehicle Year:
    thanks for the writeup! Installed them this week, and great at night. The only negative are the lights are pretty dim during the daytime.
  11. Offline
    dkim48 Junior Member
    Apr 14, 2010
    30
    Torrance
    Your Vehicle Year:
    anyone want to sell me their stock blizzard pearl ones? i had my passenger side one crack from my garage. Please PM a price. I also have some Tein Springs that I could do a trade for plus cash on whoever has the covers. Thanks in advance!
  12. Offline
    ucsmfu Senior Member
    Sep 21, 2011
    1,406
    301
    canada
    Your Vehicle Year:
    I have 2 brand new blizzard pearl covers, but it doesn't have the cut out for the led turn signals
    let me know if ur interested
  13. Offline
    Sep 21, 2011
    1,406
    301
    canada
    Your Vehicle Year:
    my blizzard pearl painted covers were fading, so I complained to MIT acessories, the paint job was poorly done, he could only refunded me $10 back :(, total he refunded me $20 for the painted covers
  14. Offline
    May 5, 2010
    2,279
    632
    Palmdale, Ca
    Your Vehicle Year:
    $20 is better than nothing.
  15. Offline
    32kcolors Senior Member
    Jul 14, 2009
    4,910
    684
    Redondo Beach, CA
    Your Vehicle Year:
    $20 is how much the ebay seller charges for the paint job so he got his money back.
  16. Offline
    Sep 13, 2011
    27
    CA
    Your Vehicle Year:
    i clay bar mines and then put tech wax on top hopefully it lasts :p
  17. Offline
    May 5, 2010
    2,279
    632
    Palmdale, Ca
    Your Vehicle Year:
    At least he got his back out of how many people including myself
  18. Offline
    jess New Member
    Jun 21, 2012
    Your Vehicle Year:
    I had a auto body shop paint my side mirror covers and the cost was 140.00 for blizzard.
  19. Offline
    Steve Robinson Junior Member
    Aug 21, 2012
    36
    40
    Mississauga, ON, Canada
    Your Vehicle Year:
    Tim, I was going over this very long thread preparing to add signal mirrors to my 2012, when I noticed your comment on a tilt passenger mirror. I just successfully added a KP Technologies mirror tilt module and it was pretty easy (although I customized a bit). Without reading every post in every thread, it is hard to tell if you went ahead with this or not. I too liked the tilt function from an old BMW and wanted to try it again.
  20. Offline
    Sep 21, 2011
    1,406
    301
    canada
    Your Vehicle Year:
    how did you add the tilt ?
    i'm interested
Share This Page
