1. Offline
    MANNYGRIZZLE New Member
    Start a Conversation
    May 25, 2012
    San Francisco
    Your Vehicle Year:
    Does anyone know if there is a simple plug and play DIY speaker replacement solution? Would love to be able to drive down to BB or local audio store, pick up some speakers and replace them today.
  2. Offline
    xs650 Senior Member
    Jul 2, 2010
    4,418
    1,300
    Northern California
    Your Vehicle Year:
  3. Offline
    May 25, 2012
    San Francisco
    Your Vehicle Year:
    Can someone point me in the right direction? I've been searching online for instructions and/or videos to show me how to remove the door panels and replace the door speakers but not having any luck.
  4. Offline
    May 25, 2012
    San Francisco
    Your Vehicle Year:
    bump. I'm really trying to replace my speakers this weekend. If someone can be kind enough to point me to directions on how to remove the door panel AND replace it without having any rattles, I would REALLY appreciate it. Or should I pay to have someone install them?
  5. Offline
    buckaroo Junior Member
    Aug 28, 2011
    64
    Austin TX
    Your Vehicle Year:
    Not being very handy, I am going to have someone do the job for me.
  6. Offline
    impossible New Member
    Jun 1, 2012
    24
    Your Vehicle Year:
    This stereo is strugglin'. I'd be curious to see some additional aftermarket options.
  7. Offline
    hsnyder Junior Member
    Dec 10, 2007
    Annapolis, MD
    Your Vehicle Year:
    In lieu of speaker recommendations, I may just take the Kappa Infinities & Kenwood sub I removed from my '05 (see sig block) after this happened and try 'em out in the V.
    They were an order of magnitude better than the factories in the '05. Same problem with this one.
    My sense is that there's enough power coming out of the head unit, but the speakers are typical Toyota "mush," especially the rears, as others have noted. And there's absolutely no midrange anywhere.
    Would be most obliged, however, if someone can tell me how to get at those tweeters up there in the dash to replace 'em? (FYI, I have a non-ATP model 5 but I don't think that matters, does it?)
    Anybody done this in the V or can you point me to instructions if they exist?
    Can't find any here or elsewhere.
    My ears will be eternally grateful!
    Even if you just get me going, I'd be happy to document it all nice and pretty for everyone else.
    Thanks!
    Howard
  8. Offline
    Mbern1008 New Member
    Jun 4, 2012
    East Stroudsburg, Pennsylvania
    Your Vehicle Year:
    I am looking at replacing the front speakers with these
    Kenwood Kfc-6993Ps 6X9 or Kenwood Kfc-1693Ps 6.5
    and the rears with these
    Kenwood Kfc-1393Ps 5&1/4
    My problem is trying to figure out exactly what size speakers I need as the info on the internet is not that great. Also I want to pull off the door to get to the speaker but it does not seem straight forward. Does anyone have experience and/or instructions?
  9. Offline
    xliderider Active Member
    Apr 19, 2012
    857
    152
    Honolulu
    Your Vehicle Year:
    Yeah, Crutchfield has the adapters that will plug right into the factory speaker harness in the doors, and they also have the mounting adapters that will allow you to mount the speakers in the OEM speaker cutouts in the doors. When you purchase from them, they provide lots of information about installation. You can see online what fits and what doesn't along with any installation notes for your car.
  10. Offline
    Jun 4, 2012
    Your Vehicle Year:
    When I checked crutch field it only shows 6.5s for the front but bestbuy and I forget the other site I saw showed 6x9s
  11. Offline
    Dec 10, 2007
    Annapolis, MD
    Your Vehicle Year:
    Crutchfield doesn't seem to have the v's specs quite right. Unless I'm mistaken, looks like the front doors are 6x9, rear doors 6. Have no idea what would fit for tweeters in the dash.
    And like Mbern1008, would be nice to know how to get those puppies out of there.
  12. Offline
    Apr 19, 2012
    857
    152
    Honolulu
    Your Vehicle Year:
  13. Offline
    Mac Prius Mod Junkie
    Feb 2, 2012
    202
    39
    San Diego
    Your Vehicle Year:
    I replaced the fronts with 6x8s and the rears with 6 1/2. I decided to leave the dash speakers in place. I posted the detailed info in this thread:
    Completed Speaker Upgrade | PriusChat
  14. Offline
    Dec 10, 2007
    Annapolis, MD
    Your Vehicle Year:
    Thanks, xliderider, Mac Prius.
    OK, so we're fairly clear on at least the nominal speaker sizes (save for the tweeter) and I managed to find a PDF off one of the threads you provided (in french, of course, which I've translated and attached) that outlines how to get at the tweets on a Gen 3.
    Looks like it might be a similar set up on the v, so I'll give it a try, though might try to rent the Toyota Tech Manual that has these same instructions, en englaise pour le "v", from Toyota owner's web site (ugh, just read ... Mac's not supported ... guess it's gonna be en francaise a la G3).
    And I've most definitely taken to heart someone's very sage advice to disconnect the 12V before messing with the plastic that contains the curtain airbags. :)
    I suspect everything else I need to remove (door panels and pillar plastic between the front/rear doors to run wire for the self-powered sub from one of the rear speakers) is pretty much the same drill as it was for my Gen 2.
    Probably won't get to it this weekend, but will shoot for next. If anyone gets to it before me, would appreciate a sanity check.
    Thanks!
    Howard
Share This Page
