Do I need a different wire harness for 05 with jbl and nav?
Discussion in 'Gen 2 Prius Audio and Electronics' started by Jeffrimerman, Oct 19, 2011.
  1. Jeffrimerman
    Jeffrimerman Member
    229
    45
    Pasadena
    Do I need a different wire harness for 05 with jbl, 70-8113 or TYTO-01?
    I ordered what the guide mentioned and when I got all the way to pluging it in, the factory one has a lot more lil connectors in the plug. Probably double the amount.
    Edit: Is this the one I need?
    Metra TYTO-01 JBL Amplifier Interface Harness
    or is this one ok
    Metra 70-8113 Radio Wiring Harness for Toyota Amp Integration 20 Pin
    I found Metra 71-8113 that seems to be a male plug to enable being able to keep the factory radio powered.
  2. Jeffrimerman
    Jeffrimerman Member
    229
    45
    Pasadena
    On a side note, is there a harness adapter that lets us take out the jbl amp and plug to that end of the harness so we can have to rewire everything?
  3. LIPriusFreak
    LIPriusFreak Can I haz JDM?
    449
    34
    Long Island, NY
    the extra connectors on back of radio are for steering wheel controls. you will lose most if not all
  4. Jeffrimerman
    Jeffrimerman Member
    229
    45
    Pasadena
    The non JBL and JBL amp stereos both have multiple plugs, but I think the plugs for JBL systems have more pins and they are smaller. I'm pretty sure I need a different adapter harness, but just wanted to make sure before I spend $50 on it.
